Go Back   Team-BHP > Indian Cars > Team-BHP Reviews > Long-Term Ownership Reviews
Long-Term Ownership Reviews Ownership reports, of Indian cars, spanning over several years and thousands of kms
Thread Tools
Old 30th September 2008, 11:59   #16 (permalink)
Originally Posted by HappyWheels View Post
I went from the stock tubed tyre (it was a JK) to tuberless on the stock rim and the change in handling, road grip and minimized bumb when going over pot holes was evident immediately!
Sri, this is a 796 CC engine. Expecting anything more of this well tuned engine is not fair!
Originally Posted by akroy
I run on 155/65 R13 Michelin XM1 and its handling is exceptional. Pls read my LTO, lots has been discussed there, specially on wet roads and during cornering at high speeds.
Even upgrading to Michelin tubeless or Turanza 145/80 R12 also makes a lot of difference.
Guys, thanks for your suggestions. I understand that this is a 796 CC, 47 BHP engine and I don't expect this to behave like a tiger. It is just that I have noticed a recent dip in pickup over the last few thousand kms( after my 10000 km service). So this has left me a bit baffled. Even in a stop-go traffic situation, I have noticed a gradual drop in getting off the mark.
I am due for 15 K service shortly and may be I will consult the service advisor.
I have been postponing the tyre upgrade for a long time, but I think it is time I got around doing this
sridharps is offline   Reply With Quote
Old 30th September 2008, 12:05   #17 (permalink)
gpa
gpa's Avatar
Originally Posted by sridharps View Post
Abhi, what tyre upgrades do you suggest?
Also, I feel that the pick-up in my alto is a little less. When 2 people sit in the back, I find that I need to shift to first gear when climbing an incline. It just dies if I am in 2nd gear.
Hi Sridharps,
Like Abhi says, it is relative. Your approach speed (initial momentum) when you approach the base of the hill also matters. My car climbed the thoppur ghat on the trip to Trivandrum with ease on second gear and the a/c with 4 people and a full boot.
Cheers,
Pritish
Old 30th September 2008, 12:15   #18 (permalink)
Originally Posted by gpa View Post
Hi Sridharps,
Cheers,
Pritish
Totally. I have been driving cars for donkey's years and understand that. ( even if my engineering college professor failed to get some 'momentum' going in me.)
As I have explained below, I have noticed a relative dip after the 10 k service, which has left me baffled.
Old 30th September 2008, 12:17   #19 (permalink)
gpa
gpa's Avatar
Yes, you do have to get it checked. The problem could be something as small as clogged injectors from bad fuel or even an choked air filter.
Do check it out at the 15 K service.
Cheers,
gpa
Old 30th September 2008, 12:47   #20 (permalink)
akroy's Avatar
Ya Sri, Pls do a checkup with the MASS. Change the filter if required. I have K&N stock filter but dustup in every 5K service which I do.
Abhi
__________________
2003 Bajaj Caliber115 | 2006 Alto LXi
akroy is offline   Reply With Quote
Old 30th September 2008, 13:36   #21 (permalink)
[quote=sridharps;996920]...It is just that I have noticed a recent dip in pickup over the last few thousand kms( after my 10000 km service). So this has left me a bit baffled. Even in a stop-go traffic situation, I have noticed a gradual drop in getting off the mark...[.quote]
I do not think this should happen. After 52k kms of driving, I have noticed it is not as peppy as it used to be, but then after so many kms, this is bound to happen. But not at 10k~ kms. I think it might be just that you got used to the pickup and hence not find the earlier kick!
But then, as GPA and AK said, the most common culprit for a drop in pickup is the air filter. do get that checked.
......I have been postponing the tyre upgrade for a long time, but I think it is time I got around doing this
With just around 10+k kms on the tyres, I would say you stick with them till they last (and last they did for me, till 40K and still were good for another 5k kms). But this is provided you are not facing any issues. But if you feel they are not giving enough grip, uncomfortable turns, etc, get them changed.
HappyWheels is offline   Reply With Quote
Old 30th September 2008, 13:48   #22 (permalink)
gpa
gpa's Avatar
Default Any change in your FE on upgrade of tyres?
[quote=akroy;996888]I run on 155/65 R13 Michelin XM1 and its handling is exceptional. Pls read my LTO, lots has been discussed there, specially on wet roads and during cornering at high speeds.
Hi Abhi,
As you mentioned about this, I'm just curious to ask. How has the tyre change affected the FE of your Alto. I've noticed that you've upgraded to a fairly large 155/65 set. Am sure this would have brought the car alive in terms of the handling characteristics, but what about the FE? Any considerable change?
Thanks,
Pritish
Old 30th September 2008, 13:59   #23 (permalink)
Technocrat's Avatar
Thread Moved to Test-Drives & Initial Ownership Reports section & title updated. Please PM any of the MODs to update KMs as & when the need be.
__________________
The Holy Trinity: Traction, Torque and Tarmac
Old 30th September 2008, 16:59   #24 (permalink)
akroy's Avatar
[quote=gpa;997154]
Hi Abhi,
Thanks,
Pritish
Pritish,
Request you to please check my xls sheets which I have posted in my LTO report. you will get an idea of all the FE details.
http://www.team-bhp.com/forum/long-t...dated-30k.html
Abhi
__________________
Old 30th September 2008, 19:27   #25 (permalink)
Hi gpa,
Can you please share your xls template for keeping track of FE? I will use it for my own Alto
aditya101 is offline   Reply With Quote
Old 30th September 2008, 21:35   #26 (permalink)
Good comprehensive ownership report Pritish. Glad to know that you are getting such good mileage figures on your alto. In this segmet, alto is the best car and you can never go wrong with it.
Congrats on your purchase and the amount of driving that you have done in such a short span of time, shows your passion for your car and driving in particular.
__________________
Pulsar 220 DTSi '09 | Honda Dio '09 | Sym Flyte '08
abhinav.s is offline   Reply With Quote
Old 1st October 2008, 15:40   #27 (permalink)
gpa
gpa's Avatar
Thanks abhinav,
Yes, I do want to contribute to this forum and hence I started this thread. Yes, I do enjoy driving and hence drive a lot. I find driving a big stress buster and hence drive a lot.
Stay tuned to this thread for many more detailed updates.
Cheers,
Pritish
Old 4th October 2008, 00:22   #28 (permalink)
Default Total Paid for Alto
I'm thinking of buying an Alto, can you guys please share with me a breakdown of the total amount paid? Cost + Insurance + Tax + registration etc.
thanks,
Hari
Chaps is offline   Reply With Quote
Old 4th October 2008, 12:00   #29 (permalink)
gpa
gpa's Avatar
thanks,
Hari
Hi Hari,
The best way would be to actually go to a dealership and check these prices out. Prices vary from dealer to dealer by atleast Rs. 5,000.
It would be best if you visited dealerships. I do hope you go in for the Alto. Like many members of this forum, I am the owner of one, and let me tell you it is a great VFM buy.
Cheers,
Pritish
Old 16th November 2008, 18:09   #30 (permalink)
gpa
gpa's Avatar
Hi HW,
Just curious to know which set of tyres are you talking about. I have a set of S 322 on my Santro and they still are in excellent shape after 49,000 kms on the clock. Am planning to change them in a few months, as they still have good usable tread depth left.
Do let me know.
Thanks,
gpa
Thread Tools
WagonR LXi 63000 Kms - Ownership Review paragsachania Long-Term Ownership Reviews 17 31st October 2009 07:30
Maruti Suzuki Alto LXi - Gearbox Question rajeshsundaram Technical Stuff 12 23rd July 2009 14:30
Maruti Alto LXi - 55,000kms review HappyWheels Long-Term Ownership Reviews 10 25th April 2009 23:02
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607 608
