Go Back   Team-BHP > Indian Cars > Team-BHP Reviews > Long-Term Ownership Reviews
Long-Term Ownership Reviews Ownership reports, of Indian cars, spanning over several years and thousands of kms
Thread Tools
Old 16th November 2008, 18:19   #31 (permalink)
Hello GPA,
I am taking about the stock JK tyres that came with the Alto.
My driving was a bit on the spirited side and maybe would have been the reason for the wear.
HappyWheels is offline   Reply With Quote
Old 16th November 2008, 18:38   #32 (permalink)
gpa
gpa's Avatar
Originally Posted by HappyWheels View Post
Hello GPA,
HW,
When I took delivery of my Alto in May this year, the showroom guy explained that Maruti has done away with using JK tyres on the Alto based on customer feedback of poor perfomrance and early wear and have hence moved on to MRF ZVTS radials for all Altos.
Maybe your spirited driving was not to blame after all.
Cheers,
gpa
Old 16th November 2008, 18:56   #33 (permalink)
Originally Posted by gpa View Post
...Maybe your spirited driving was not to blame after all. ...
Ah, GPA, thanks for validating my gut feeling that I am a safe driver and it wasn't my fault!
Old 18th November 2008, 12:34   #34 (permalink)
Ramsagar's Avatar
Alto struggles only when AC is on and tries to pull in low speeds (city conditions).the rest is fine.
Guys, also check which type of fuel you use. My alto gives nice mileage with HP, it has been observed on many occasions so I sticked on to only COO HP stations where ever I go.
SHELL: it gulps like juice and strictly avoided (filled SHELL as there was new filling station opened in our home town.)
Never checked with other brands of fuel.
This same had happened to my friends Swift also. So HP seems to work well.
Kindly share your experiences too.
__________________
CAUTION!!!All the nuts in my car are tight,except the one driving it...Obsessed with CARS since 1981.
Last edited by Ramsagar : 18th November 2008 at 12:36. Reason: spell check & typos
Ramsagar is offline   Reply With Quote
Old 18th November 2008, 12:55   #35 (permalink)
Originally Posted by Ramsagar View Post
...Guys, also check which type of fuel you use. My alto gives nice mileage with HP, it has been observed on many occasions so I sticked on to only COO HP stations where ever I go...
My Alto is happy with HP. Used to be any bunk, then moved to IBP, and then for the last 1 year its HP. I get good FE. Have noticed it over many long trips.
And most of the HP bunks have electonic reading meters with thermal printers - which I love to believe are bit better off than other types of petrol meters.
Old 18th November 2008, 13:07   #36 (permalink)
Ramsagar's Avatar
How was IBP?
Any expirences with IO & BP?
__________________
Old 18th November 2008, 13:17   #37 (permalink)
How was IBP?
My ranking will be:
1. HP
2. IBP
3. IO
IO was the last one I would go to. But then, I was using it initially for some time before the 'Pure for Sure' came up and I moved to IBP. Had a better ride than IO, but then one fine morning filled at JP Nagar HP and the FE was a eye opener!
Old 18th November 2008, 13:44   #38 (permalink)
akroy's Avatar
For me it was Shell Normal throughout till increased the prices. Since last April, I fill in HP and the bunk is good and also FE didnt come down.
I had worst exp with BP pumps both for bike and car.
Abhi
__________________
2003 Bajaj Caliber115 | 2006 Alto LXi
akroy is offline   Reply With Quote
Old 18th November 2008, 14:14   #39 (permalink)
dont know about gulping habits, but the acceleration is even worse than my ex premier padmini, with the a/c on.
kavesh55 is offline   Reply With Quote
Old 18th November 2008, 14:19   #40 (permalink)
akroy's Avatar
Then there is something wrong in your car. I use AC consistently in highways and high speeds and also in city, never had such issues.
Definitely you should have known the gulping habits. It is the highest selling not by fluke.
Abhi
__________________
Old 19th November 2008, 20:18   #41 (permalink)
gpa
gpa's Avatar
The acceleration is not all that bad with the AC switched on. Once the car gets used to the load of the AC, it will perform better. A technique mentioned by Abhi, that I have tried, really works. You could be facing a problem due to a clogged injector or air filter. Get them cleaned and you will notice a perceptible difference in acceleration both with/without the AC.
Cheers,
gpa
Old 19th November 2008, 20:22   #42 (permalink)
gpa
gpa's Avatar
Abhi
Just like Abhi, I used to fill my Santro and M 800 only with Shell, but stopped due to high prices. Now, I fill my Alto and Santro at HP bunks. My worst experience was at BP and IOC bunks.
The petrol is so bad that the engine pings heavily on even moderate acceleration and worse still there is quite a noticeable drop in FE as well.
Cheers,
gpa
Old 19th November 2008, 20:28   #43 (permalink)
gpa
gpa's Avatar
Hey HW,
I just noticed that one HP bunk also had a density meter that showed if the petrol stored in the tank below was within the prescribed density limit.
I also have made note that the density meter's reading doesn't vary depending on the time of day at a IOC bunk that dispenses extremely bad fuel. The reading at 3.00 pm in the afternoon is the same at 6.00 am in the morning when the ambient temperature is about 15 deg celcius.
How can this be? Am quite certain that there will have to be a change in density with a change in ambient temperature right? Or is it possible for the bunk guys to manipulate this just the way they do with the petrol?
Guys, do give me your inputs on this.
Thanks,
gpa
Old 19th November 2008, 20:34   #44 (permalink)
gpa
gpa's Avatar
Hi Ramsagar,
I agree that HP does dispense the best fuel.. How do you differenciate between a 'nomal outlet' from a 'COO'?
Do let me know.
Thanks,
gpa
Old 20th November 2008, 08:53   #45 (permalink)
Ramsagar's Avatar
@GPA:every Company Owned Operated bunk has the hoarding COO and must be using DIGITAL filling units with thump impression.atleast it should have minimum of 4 filling units.
Eg:In B'lore,the one @ JP-NAGAR,another @ Near WOODYS,the one near St.Jonhs,Next to KR puram bridge...and many more.
__________________
Thread Tools
WagonR LXi 63000 Kms - Ownership Review paragsachania Long-Term Ownership Reviews 17 31st October 2009 07:30
Maruti Suzuki Alto LXi - Gearbox Question rajeshsundaram Technical Stuff 12 23rd July 2009 14:30
Maruti Alto LXi - 55,000kms review HappyWheels Long-Term Ownership Reviews 10 25th April 2009 23:02
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607
