Old 16th September 2011, 18:53   #2401
smartcat's Avatar
Thanked: 8,369 Times
Default re: Honda Civic : Maintenance, Service Costs and Must dos
Originally Posted by laluks View Post
From HASS? Inclusive of Clutch Release bearing, Clutch and Pressure plate? Inclusive of Service cost?
@ Magnum Honda, Yeshwanthpur.
The breakup of the bill I got -
Disk Comp Friction - Rs. 3,480
Disk Comp Pressure - Rs. 2,976
(LQ) BRG Clutch RLS - Rs. 1,596
Clip BRP Face - Rs. 312
Labour - Rs. 2,250
Service tax @ 10% on Labour - Rs. 225
Total - Rs. 10,839
smartcat is offline   (1) Thanks Reply With Quote
Old 17th September 2011, 09:48   #2402
patron's Avatar
Thanked: 97 Times
Does anybody know of a good paint shop in and around Bangalore West?
Need to clean up a few nicks on the civic.
patron is offline   Reply With Quote
Old 17th September 2011, 10:14   #2403
s.prashanth's Avatar
Thanked: 59 Times
Go to Fast Cars, next to atria.The owner Jai is a good friend and my civic and corolla goes to him only for any Accident related works
s.prashanth is offline   Reply With Quote
Old 17th September 2011, 14:08   #2404
sumeethaldankar's Avatar
Thanked: 841 Times
My civic's wiper blades were changed during the service in Aug last month.This morning when i went for a drive it started raining heavily.I swicthed on the wipers and they started to creak and groan during the downward motion.Upward they are fine but while going down they sounded as if they are trying to scratch out the windshield.
Anyone with a similar problem.Now the SA at my last service had mentioned about getting the windshield polished or something which i had refused.Does the windshield need any polishing etc to smoothen it out.The car is cleaned by the cleaner regularly and the screen was quite clean when it started to rain.
thanks
sumeethaldankar is offline   Reply With Quote
Old 17th September 2011, 14:39   #2405
laluks's Avatar
Thanked: 6,214 Times
thanks
Its all about the fitting of the blades -if you are sure it's new. Remove them and refit if you can by yourself. It's a simple method. Else get it done in front of you from the HASS.
laluks is offline   (1) Thanks Reply With Quote
Old 17th September 2011, 17:10   #2406
smartcat's Avatar
Ask the cleaner to be careful with the wipers. It's actually best if they don't touch it.
They pull out the wipers to clean the windshield and then go ahead to clean the wiper with their cloth. When they wipe down the wiper blade roughly with their cleaning cloth, it can mess up the wiper alignment.
Old 17th September 2011, 18:37   #2407
Thanked: 229 Times
I am also quite fed up with the chattering of the right wiper. A new blade lasts for like 6-8 weeks before it starts chattering on the down. The left is perfect. Next monsoon I am thinking of replacing the entire set with Bosch. If anybody has any solutions I really would be grateful.
On a side note, I must say that I am really very happy with my tire choice of Yoko dbs 205/65. Using them since about 5 months and entire monsoon. The upsize has helped in so many ways, that I cannot help but recommend to all civic owners to put this on their priority list. Probably any brand would work. 205/65 is probably the tire that should have been OEM.
In spite of horrendous road conditions, the extra sidewall cushioning has ensured that there are no new rattles at all. The ride is so much better for my back. Grip levels are super and braking has improved greatly. GC has increased due to slight larger OD. The car looks better since the larger tires fill up the wells. I am getting at least 10% better fuel efficiency.
sandeep108 is offline   Reply With Quote
Old 17th September 2011, 18:44   #2408
Thanked: 841 Times
IMHO the 10% FE is due to a 2% odo error.
Refer to below posts
http://www.team-bhp.com/forum/tyre-a...ml#post1547605
Old 17th September 2011, 19:43   #2409
Thanked: 229 Times
Yes, I am aware of the speedo error due to the 2% OD. From 6.5/7 kmpl I am now getting 8.5+. How would a 2% error result in 10% extra FE? It should be around 2% only. And as per that thread 2-3% speedo error is anyway the norm. In fact the 2% error works the other way around.
Old 19th September 2011, 10:27   #2410
vasoo's Avatar
Thanked: 206 Times
Happy to see Civic as having the highest IQ among all cars in the country as per JD Power survey
vasoo is offline   (4) Thanks Reply With Quote
Old 19th September 2011, 11:22   #2411
Thanked: 83 Times
That's an extremely interesting statistic. Honda has the lowest pp100 in all the segments it sells in. Also, the corolla - traditionally seen as a very reliable car - has a higher pp100 than the civic.
hajaar is offline   Reply With Quote
Old 19th September 2011, 14:49   #2412
hiren.mistry's Avatar
Thanked: 160 Times
Not just the Civic, even the Jazz and City are on the top in their respective segments. Well done Honda. Now that your cars are priced sensibly, do the same for the spares please.
hiren.mistry is online now   Reply With Quote
Old 19th September 2011, 15:17   #2413
sgiitk's Avatar
Thanked: 3,471 Times
Most probably the new blade is not square onto the glass. Have a good look and try to twist it a bit. Be careful, since you do not want to get a new arm as well.
sgiitk is offline   (1) Thanks Reply With Quote
Old 19th September 2011, 15:40   #2414
how much for the suspension (complete set up including dampers, springs, arms, ball joints, bushes)
kumargandharva is offline   Reply With Quote
Old 19th September 2011, 15:59   #2415
gaurav_chopra04's Avatar
Thanked: 523 Times
You are looking for around 50 k for complete suspension including tie rods, tie ends, boots etc and other items u listed. Better get the suspension checked at an independent garage and get only worn off parts replaced. You won't really need complete setup change..
gaurav_chopra04 is offline   Reply With Quote
VW Polo - Maintenance and Service cost and dos/don'ts gaurav_chopra04 Technical Stuff 1289 18th May 2017 16:51
