Old 26th February 2012, 18:28   #2926
sumeethaldankar's Avatar
Thanked: 784 Times
Default re: Honda Civic : Maintenance, Service Costs and Must dos
Not sure if this was posted before but came accross this website from Honda dedicated to Honda cars driven for more than 100K miles.
Honda Mile Makers - the Official Honda Web Site
sumeethaldankar is online now   (2) Thanks Reply With Quote
Old 27th February 2012, 11:58   #2927
sushrutha's Avatar
Thanked: 318 Times
Originally Posted by s.prashanth View Post
guys, need help. my car has done about 41k, the clutch shudders in stop and go traffic. especially in traffic jams when crawling in traffic. is this a sign of the clutch kaput. how much would it cost. the gurus please reply
Shuddering is not always related to Clutch.
Check your engine mountings, looks like time to replace them.
If the RPM raises violently without any great pickup then the clutch might have gone for a toss.
Just check, it may not be full clutch assembly, replacing the pressure plates might also help.
To check your car clutch plate if it has worn out,
On a flat surface from standstill, put your car into 2nd gear, move your car by relasing the clutch slowly, if the car stalls.. clutch might have worn out
sushrutha is offline   (2) Thanks Reply With Quote
Old 27th February 2012, 12:16   #2928
s.prashanth's Avatar
Thanked: 59 Times
Thanks shuhshrutha, but the shuddering only happens in stop and go traffic, engine mounts were just now checked at Magnum Honda now. They also say clutch is fine.How to personally check for engine mount failure. please advise
s.prashanth is offline   Reply With Quote
Old 27th February 2012, 12:30   #2929
sushrutha's Avatar
Thanked: 318 Times
^^ check some of the previous posts in the same thread.
laluks had posted the pics of engine mount going bust.
There was a long discussion on the same...
Check here
http://www.team-bhp.com/forum/long-t...ml#post2352049 (Honda Civic : Maintenance, Service Costs and Must dos)
Last edited by sushrutha : 27th February 2012 at 12:43. Reason: edit for the pics post
Old 27th February 2012, 23:23   #2930
Thanked: 71 Times
1.Visually inspect if you can spot any cracks on the mount.
2.Shake the engine assembly and check if the fittings are tight.
3.Start the engine and see if you find the symptoms shown below:
ramanak is offline   (3) Thanks Reply With Quote
Old 1st March 2012, 20:32   #2931
Thanked: 784 Times
For a 2007 model Civic does the power windows button marked as auto cause all the open windows to shut? I find that i have to manually close open windows one at a time.Is there a auto feature which would close all the windows , as the button marked as auto only closes the driver side window if held for a brief moment.
thanks
sumeethaldankar is online now   Reply With Quote
Old 1st March 2012, 20:42   #2932
Thanked: 29 Times
Since the time I have returned from the last service at the HASS, there is a noticeable increase in the clutch lever play. I brought this to the notice of the SA as well as the mechanic, but they said that is normal. However, if that is actually the case it was never right all along till now. Does anyone have the standard amount of play that should be there. I suppose the excess play would result in excess fuel consumption as well as excessive wear of the clutch plate.
swarooppatil is offline   Reply With Quote
Old 1st March 2012, 22:47   #2933
jatinpatel's Avatar
Thanked: 190 Times
@swaroop
They might have just bled the clutch and it might not have been done properly hence you can feel play in clutch. Civic has a hydraulic clutch hence manual play adjustment like which can be done in cable opreated clutch is not possible.
tell them to re-blead the system.
Btw which HASS in mumbai you go to ?
@sumeet
no there is no such provision for one touch all windows up feature.
But it can be installed as an Add on module which works in conjuction with the original security system of the car and as soon as the car is locked any window which is down would be rolled up automatically. Such modules are available in brands like Autocop etc.
jatinpatel is offline   (2) Thanks Reply With Quote
Old 1st March 2012, 22:57   #2934
Thanked: 29 Times
Originally Posted by jatinpatel
@swaroop
Yes the clutch was bled. I'll get them to do it properly again then. What exactly do they do in bleading? Would repeating it like this have any adverse effects?
As for the HASS I go to Apex Honda, Kurla.
Old 1st March 2012, 23:09   #2935
jatinpatel's Avatar
Thanked: 190 Times
No adverse effects at all. Go ahead and tell them to re-bled the system and if the clutch fluid is not changed in last 1-1.5yrs get that replaced too.
Clutch and Brake fluid must be replaced every year or at the max 1.5yrs to have proper braking and clutch action and also save the master brake and clutch cylinder from the formation of oil residues which affect the life of the cylinders.
And brake and clutch fluid replacement is cheap.
jatinpatel is offline   (1) Thanks Reply With Quote
Old 2nd March 2012, 07:22   #2936
laluks's Avatar
Thanked: 6,073 Times
thanks
Your observation concurs with mine.
Auto does it only for the drivers side as I have understood.
laluks is offline   (1) Thanks Reply With Quote
Old 2nd March 2012, 17:05   #2937
manoj_joseph78's Avatar
Originally Posted by hiren.mistry View Post
Yes, I have done the AUX-IN DIY.
And yes, I did have to open the dashboard, get the HU out and short the wires as mentioned on 8th Civic. It is fairly straight forward.
Unfortunately, I do not remember the steps from the top of my head but its exactly as mentioned on this thread on 8thcivic.
I did this last weekend, works fine. @hiren.mistry - Thanks!!!.
~Manoj
manoj_joseph78 is offline   Reply With Quote
Old 2nd March 2012, 17:26   #2938
rr_zen's Avatar
Thanked: 250 Times
Yes. The auto feature rolls up only the driver side window. That's how it is in my Esteem as well.
rr_zen is offline   Reply With Quote
Old 2nd March 2012, 20:08   #2939
Thanked: 7 Times
Auto roll-up feature must be combined with pinch guard for safety. Auto window rollup as part of remote locking (like in Skoda cars) will be very useful though.
SafeSteer is offline   Reply With Quote
Old 4th March 2012, 14:39   #2940
Thanked: 116 Times
Hey,
The clutch of my 2007 V MT civic is very hard. I have use my entire foot to press it, with even the heel leaving the floor. My 10 year old Maruti 800 is butter soft in comparison.
There is no other problem with the clutch. No slipping of gears or strange sounds etc.
Will, as the first step, changing the clutch fluid help?
skdking is offline   Reply With Quote
VW Polo - Maintenance and Service cost and dos/don'ts gaurav_chopra04 Technical Stuff 1250 26th March 2017 12:58
