Old 4th March 2012, 15:02   #2941
smartcat's Avatar
Thanked: 8,348 Times
Default re: Honda Civic : Maintenance, Service Costs and Must dos
Originally Posted by skdking View Post
Hey,
The clutch of my 2007 V MT civic is very hard. I have use my entire foot to press it, with even the heel leaving the floor. My 10 year old Maruti 800 is butter soft in comparison.
There is no other problem with the clutch. No slipping of gears or strange sounds etc.
Will, as the first step, changing the clutch fluid help?
Deja Vu. My 2007 pre-owned VMT Civic had a hard clutch too.
The clutch basically needs replacement. Cost - Rs. 12,000.
smartcat is online now   (1) Thanks Reply With Quote
Old 4th March 2012, 20:47   #2942
sumeethaldankar's Avatar
Thanked: 837 Times
Hey,
Suggest showing the car to a service center if there is diffculty in changing gears. Also check there are no obstructions under the clutch pedal which could restrict the movment of the clutch pedal.
My 800's clutch would feel hard at times and i noticed it was because of the rubber mat had worn out and would obstruct proper movment of the pedal.Once i removed the worn mat the clutch felt good as new.
Btw how many kms has your car clocked ?
sumeethaldankar is online now   (1) Thanks Reply With Quote
Old 4th March 2012, 21:09   #2943
Thanked: 120 Times
My Maruti 800 - 34000 km, its clutch is butter smooth though it is 10 yrs old.
My Civic - 52000 km, only four years old but the clutch feels very sluggish and lethargic. Its clutch has no other issues. No excessive play or sounds.
The travel/throw of the clutch lever does seem to be excessive. When it is completely unpressed it is very high. So much so that when I use the clutch I am unable to keep my left heel on the floor.
I have checked the car for any mechanical obstruction around the clutch pedal. Zilch.
Will be grateful for some pointers.
skdking is offline   Reply With Quote
Old 4th March 2012, 21:15   #2944
dot
dot's Avatar
Thanked: 711 Times
Manual Civics do show this issue. I have seen quite a few old Civics with the same hard clutch problem. Do have a look at smartcat's older posts where he also reported a similar issue and clutch had to repaired.
dot is offline   (1) Thanks Reply With Quote
Old 5th March 2012, 00:01   #2945
jatinpatel's Avatar
Thanked: 191 Times
@sdking
Well it will help but not to such a extent that it will be as soft and smooth as 800 clutch.
how many kms your car has done ?
But do get the fluid changed and rebleed the complete clutch hydraulic system and then see the difference.
jatinpatel is offline   (1) Thanks Reply With Quote
Old 5th March 2012, 21:36   #2946
Thanked: 120 Times
Originally Posted by jatinpatel View Post
@sdking
Got the clutch assembly changed today, at MyTVS in Ambattur. Cost me 12000/-. The clutch is butter soft now.
Thanks for all the inputs, Guys.
skdking is offline   (1) Thanks Reply With Quote
Old 5th March 2012, 23:36   #2947
Thanked: 32 Times
We own a Honda Civic S AT, 2007 model, which has run over 100000 kms. It has been a relatively pleasant ownership experience but lately I have experiencing issues which are listed below:
1. There is excessive road noise filtering into the cabin. While I have expressed the same to the service centre numerous times, the SA says it is normal and returns the car back. What could be the possible cause for this?
2. During cold starts especially in the morning, there is a lot of clatter from the engine. The car almost sounds like a truck! But this clatter disappears within 5 mins of driving. Is this normal?
crux is offline   Reply With Quote
Old 5th March 2012, 23:56   #2948
Thanked: 13 Times
test drove civic today.first impression-the car feels damn sporty..and found it very comfortable to drive.but i find the pickup in 1st or second is good but car doesn't feel powerful say like at 80 in 5th gear.
procircuit_234 is offline   Reply With Quote
Old 6th March 2012, 04:11   #2949
gaurav_chopra04's Avatar
Thanked: 523 Times
Probably you didnt try 7k rpm in 4th gear, you will be surprised to see the speeds it does in 4th at 6.5+k rpm. 5th is just for overdrive, slot in and cruze on highway, more so for good FE.
What tires are you running on and how many kms have you done on them? Could be because of the tires.
Sounds like tappet noise. I believe civic has hydraulic (self adjusting tappets). Still ask the SA/Mechanic to have a look. Leave the car at ASC and go next morning and show them the noise on cold start. They might ask for replacement of some (if not all) lifters and tappets. But first get it checked.
gaurav_chopra04 is offline   (1) Thanks Reply With Quote
Old 6th March 2012, 09:21   #2950
smartcat's Avatar
Gaurav_chopra is right. Excessive road noise is mostly because of old/bad tyres. You could also check & replace rubber beadings on the door frames & the windows - their job is to filter out road noise.
Petrol engine that has run 100,000 km clattering like a diesel is mostly because of worn out timing belt/timing chain. Now Honda Civic has a timing chain which is supposed to be maintenance free. But if the chain is not being lubricated properly, it could cause some issues.
VTEC engine wakes up after 3000 RPM. I guess @ 80 kmph in the 5th gear, the engine is ticking over at less than 2000 RPM.
Another cause for the engine clatter could be worn out engine mounts. Costs around Rs. 8,000 to replace.
Old 6th March 2012, 09:51   #2951
vasoo's Avatar
Thanked: 206 Times
Renewed my car insurance online with Bajaj Allianz for 15,655. Earlier it was insured with Tata AIG and they never bothered to even inform me about the due date. Wonder how these companies get business if they are not interested in retaining their customers.
vasoo is offline   Reply With Quote
Old 6th March 2012, 13:46   #2952
Thanked: 523 Times
I didnt get the maintenance free thing, boss. Is it that it doent need change?
As far as I recall, the timing chain in civic is recommended for change at 1 lac kms?
Also if its timing chain and its bearing, it will make noise throughout and wont go after 5 mins. In this case, the noise is only on cold start and goes of when the oil is rotated fully across the engine. The lifters and tappets make noise noise until they get properly lubricated with oil.
gaurav_chopra04 is offline   Reply With Quote
Old 6th March 2012, 15:03   #2953
smartcat's Avatar
Timing chains last for a very long time. It's the timing belt (made out of rubber like material) that usually requires a change after 100,000 km.
http://www.team-bhp.com/forum/techni...-vs-chain.html (Timing (cam) belt vs chain)
My old Chevrolet Optra had the same "symptoms" at 80,000 kms. The problem went away after its timing belt was replaced.
smartcat is online now   Reply With Quote
Old 6th March 2012, 19:07   #2954
Thanked: 29 Times
Back from the A.S.S. Got the clutch free play adjusted, now feels much better to the feet as well as to drive. The wheels seem to get more power now. Also as against earlier, now I need not start accelerating from depressing the clutch halfway itself between the gears.
Also got the guys to work on the dash-board vibration noise. The culprit again was the horn pad. Rectified and now the cabin is back to its original calm self.
Last edited by swarooppatil : 6th March 2012 at 19:15. Reason: Missed the dots in the A S S. Sorry for the misunderstanding created.
swarooppatil is offline   Reply With Quote
Old 6th March 2012, 21:06   #2955
dot
dot's Avatar
Thanked: 711 Times
Recently I had fired up a 07 Civic with 137,000 Kms on it. It was a cold start and could hear a similar injector/ valve chatter. Suggest you to use a injector/ upper valve seat cleaner fluid available in auto accessories shops or good petrol pumps during a tankful and hopefully that the noise will reduce.
If not, timing chain could be the next source, just as the two gentlemen above were discussing. Valve adjustments may not be necessary as the noise goes down when engine is hot. This probably points out that gaps are fine.
VW Polo - Maintenance and Service cost and dos/don'ts gaurav_chopra04 Technical Stuff 1289 18th May 2017 16:51
