| LinkBack | Thread Tools | Search this Thread |
| | #2956 | |
| Senior - BHPian | Quote:
| | #2957 |
| BHPian Join Date: Feb 2012 Location: Panaji
Thanked: 23 Times
| Sorry for the late reply,guys! My Civic runs on Bridgestone Turanza tyres on stock dimensions. I think they have run for around 10000 to 15000 kms. So I think its a little early to replace them. As for the shuddering issue, the SA did replace some of the tappets. The clattering has reduced to some extent but is still present. Will check if the injector cleaner fluid solves the issue. |
| | #2958 |
| BHPian Join Date: Oct 2007 Location: Gurgaon
Thanked: 152 Times
| I think the Civic has a timing *belt* and not a chain (please correct me if I'm wrong). Belts are best changed once every 3 or 4 years even if the car hasn't done 100k kms. The weather cycle will make the rubber brittle over this much time and can make the belt snap, leading to disastrous consequences. So it should be 4 years (3 if in extreme weather situations, just to be on the safe side) or 100k kms, whichever is earlier. Perhaps @manim could throw some light, considering his Civic has done 100k kms in a little under 5 years now. Regards, spadix |
| | #2959 | |
Civic has a timing Chain. So no need to replace it. Check the below pic ![]() | |
| | (2)
| | #2960 | |
Thanked: 152 Times
| Quote:
Going back to dot's Scorponok's issue of that flapping sound from the engine at idle, which was diagnosed to the "timing belt auto-tensioner", what was that about, then? Regards, spadix | |
| | #2961 | |
It's timing chain auto -tensioner. More info on the same here DIY: Timing Chain Auto Tensioner install - Honda Forum : Honda and Acura Car Forums | |
| | (1)
| | #2962 | |
| Senior - BHPian Join Date: Dec 2007 Location: Ban Chang
Thanked: 696 Times
| Quote:
BTW, the timing chain also has an auto-tensioner. | |
| | (2)
| | #2963 |
| BHPian Join Date: Dec 2011 Location: New Delhi
Thanked: 65 Times
| To all civic owners, Guys, if anyone has installed a 7" Touch HU with a good moulding on the civic, please post pics. I really need to see how it looks to make an informed decision. |
| | #2964 | |
Thanked: 152 Times
| Quote:
Regards, spadix | |
| | #2965 |
| Senior - BHPian Join Date: May 2007 Location: Mumbai
Thanked: 156 Times
Infractions: 0/1 (5) | Maybe off-topic for this thread but does anybody know the 0-100 timing for the civic manual/automatic. thanks |
| | #2966 |
| Distinguished - BHPian ![]() | |
| | (2)
| | #2967 |
| BHPian Join Date: Nov 2009 Location: chennai
Thanked: 44 Times
| Anyone using osram nightbreakers or Philips xtreme vision on Civic can give his feedback? I want to upgrade the low beam by changing only the bulb. |
| | #2968 | |
Thanked: 44 Times
| Quote:
Can you provide some feedback on your new bulbs and the difference they made? | |
| | #2969 | |
Thanked: 44 Times
| Quote:
Can you give the exact nomenclature. | |
| | #2970 | |
| BHPian Join Date: Oct 2008 Location: Mumbai
Thanked: 23 Times
| Quote:
| | (1)
Similar Threads | ||||
| VW Polo - Maintenance and Service cost and dos/don'ts | gaurav_chopra04 | Technical Stuff | 414 | 26th April 2013 11:26 |
| NHC maintenance costs | pow3r2dawh33ls | The Indian Car Scene | 0 | 16th June 2006 16:17 |
| Maintenance costs of the Ikon 1.3, Accent 1.5, etc | zazuaza | The Indian Car Scene | 4 | 20th November 2004 16:24 |
