Old 20th May 2013, 14:31   #4351
sgiitk's Avatar
Thanked: 3,345 Times
Default re: Honda Civic : Maintenance, Service Costs and Must dos
Originally Posted by 2000rpm View Post
The problem with using body cover is that it is never 100 % water proof. So during rains (especially Mumbai type rains) the water will get inside the cover thus dissolving the purpose of the cover.
In fact the cover keeps the car wet even when it has stopped raining, thus making it more prone to rusting.
I do not think one really wants a totally water proof cover. It should allow the car to 'breathe'.
Old 23rd May 2013, 12:39   #4352
car_crazy1400's Avatar
Thanked: 136 Times
Guys, need a little help here.
I have given my 2007 august civic today for replacing the engine mounting to Ace honda, noida.
Have just received a call from my SA. that my rear brake pads have gone & won't last me more than 600-700 kms.
The car has done 45,000 kms & the front brake pads were changed once as they had become hard.
The cost of replacement pads quoted is 6000+.
Can any one suggest some aftermarket good quality brake pads?? Also where can I source them in south delhi/ noida.
Please suggest a decent workshop/ mechanic for replacing the brake pads too.
Rishi
car_crazy1400 is offline   Reply With Quote
Old 23rd May 2013, 13:21   #4353
mukeshgoel's Avatar
Thanked: 348 Times
Hi guys,
There is some problem with my headlight control switch.
* If I select low beam or high beam, only low beam light turns ON.
* If I use dipper (day or night), the low beam light turns on.
* When I select high beam (permanent or dipper), high beam indicator (blue) on instrument panel turns on but headlight remains on low beam.
And it does not happen always. Last night, it was malfunctioning for first 5 minutes, then everything started working fine for next 30 minutes. Then again it started malfunctioning.
What could be the probable reason? Headlight control switch gone bad? Anyone got it replaced? Any idea of the cost?
mukeshgoel is offline   Reply With Quote
Old 23rd May 2013, 14:18   #4354
sumeethaldankar's Avatar
Thanked: 778 Times
Rishi
Hi,the aftermarket brake pads for honda are from the nissin brand.These can be had for around 3k or less for a pair.Make sure you get the original.Honda crv and civic has the same size for brake pads.
Please look up the team bhp directory for trusted garages.Also while you are there could you please share the cost of the engine mount.
Thanks.
sumeethaldankar is online now   Reply With Quote
Old 23rd May 2013, 23:00   #4355
Thanked: 153 Times
I was quoted 8k for the mount
coolkurt is offline   Reply With Quote
Old 24th May 2013, 10:56   #4356
Thanked: 56 Times
Could be the high beam fuse. Had a similar incident with a Innova and initially we just removed the fuses and refitted them and the high beam started working. After few kms same issue and we checked the fuse and it was actually burnt. When we refitted it we had accidentally closed the burnt gap and that's the reason it worked for a while. Replaced the fuse later and no issues since then.
alto99 is offline   (1) Thanks Reply With Quote
Old 24th May 2013, 12:24   #4357
mukeshgoel's Avatar
Thanked: 348 Times
Originally Posted by alto99 View Post
Could be the high beam fuse...
If high beam fuse is gone, will low beam light turn on if we use dipper/high beam ?
Old 24th May 2013, 12:33   #4358
Thanked: 56 Times
Sorry missed on that part. Then mostly it will be the switch.
alto99 is offline   Reply With Quote
Old 24th May 2013, 13:15   #4359
Bluebeem's Avatar
Thanked: 211 Times
Hey Guys,
I have a Honda Civic V A/T. The car seems to have a breaking problem. Every time I drive above 120 kmph and break instantly, the cars breaks make a lot of noise and the car starts shaking uncontrollably.
Drove an accord for about 300km, same problem. Drove another manual transmission civic. Same problem.
Also the breaking is very bad.
How to fix this ?
Bluebeem is offline   Reply With Quote
Old 24th May 2013, 15:49   #4360
Thanked: 98 Times
Originally Posted by Bluebeem View Post
Hey Guys,
How to fix this ?
Is it the ABS kicking in sound or feeling?
saurabhkum is offline   Reply With Quote
Old 24th May 2013, 15:56   #4361
Bluebeem's Avatar
Thanked: 211 Times
Nope. Not at all. It sounds like I'm running on a flat tire. And the steering starts shaking/vibrating.
Old 24th May 2013, 16:22   #4362
Thanked: 229 Times
I think you need a brake discs and pads replacement.
sandeep108 is offline   Reply With Quote
Old 24th May 2013, 18:11   #4363
manim's Avatar
Thanked: 324 Times
Hey Guys,
I had a similiar problem, you have to replace the front brake disc along with the pads.
manim is offline   Reply With Quote
Old 24th May 2013, 23:25   #4364
Bluebeem's Avatar
Thanked: 211 Times
How much will this cost ?
My car is under warranty. Will that cover It?
Old 25th May 2013, 08:13   #4365
Thanked: 153 Times
No. They get worn of due to normal wear and tear. You'll have to pay for the parts.
VW Polo - Maintenance and Service cost and dos/don'ts gaurav_chopra04 Technical Stuff 1247 21st March 2017 11:33
