Old 31st October 2008, 18:03   #46
appuchan's Avatar
Thanked: 13 Times
Originally Posted by laluks View Post
Is our stock tyres safe with that psi. My manual says keep 30PSI. The link says he used 38 psi, just under the 40psi sidewall max for the tyre.
Next how does it affect mileage if we over inflate the tyre?
I am not sure about the tyre safety here. I don't have any problem so far with my over inflated ones.
Increasing air pressure inside tyre is expected to reduce the rolling resistance. This will have good impact on FE over longer period/drives. Of course this also may mean different dynamics, as in my case where the car feels more bouncy and less comfortable on rough roads at higher speeds. I dont mind a bit lesser comfort as I drive in a very sedate manner (assume that there is an egg between the right foot and gas pedal!). My FE improved from 13 to 15 by increasing pressure from 32 to 36 psi.
appuchan is offline   Reply With Quote
Old 31st October 2008, 19:07   #47
laluks's Avatar
Thanked: 5,918 Times
Originally Posted by iraghava View Post
Oh let it be man, not worth the time wasted. Use this as a future tool against the service station though!
Me too thinks the same. Definitely not worth it at all. Since those guys said it will cost 4000, ask them to give it you in a different way - by service, consumable or others. Definitely use it against them.
laluks is offline   Reply With Quote
Old 31st October 2008, 19:11   #48
navpreet318's Avatar
Thanked: 749 Times
Ishan Ji,Laluks: you guys are right.Not worth the time or the risk involved in case they mess up again.
I will though make use of it against them,as you guys have stated.I'll not ask for consumables but ask them for super quick service and interior detailing every time i go in for a service.i'll make them pay for this.
Ok another question since its tire talk right now.
How much air pressure should i keep in the 225/45 R17 tires which i have on my civic.
navpreet318 is offline   Reply With Quote
Old 31st October 2008, 19:15   #49
iraghava's Avatar
Thanked: 143 Times
What are you maintaining right now & are you facing any problems at that pressure?
Old 31st October 2008, 19:30   #50
Thanked: 749 Times
right now its 25.its ok.no problems as such.not too harsh.
Old 31st October 2008, 19:33   #51
laluks's Avatar
You have a 17 incher. Show some pictures. Is it already in the other section of alloy showing off?
How about the life of the tyre? Will it still stay the same? Any weakening of the side walls?
Old 31st October 2008, 19:53   #52
Thanked: 29 Times
36 psi on a 15"? Well isn't it a bit too high? The recommended level is 30 but I often see the workshop guys themselves pump it up to 34.
The ride quality would definitely deteriorate at such high pressures. I'm sure the overall dynamics of the car during a drive would change. Don't know if driving sedately will not effect anything.
Probably get one of the tyre experts to answer the question or post it in one of those threads.
csentil is offline   Reply With Quote
Old 31st October 2008, 19:54   #53
vinit.merchant's Avatar
Thanked: 734 Times
I read the initial pages of this thread and found a few queries about oil change at first service due to the metal pieces coming out of the new engines.
Though I do not own any Honda car, but I have read on some thread on T-Bhp that the Honda Engines are run-in in the factory itself. I think this should be the reason for no Oil Change at first service. Though I was curious whether the manual mentions anything about keeping the car below xxx Rpm for the first xxxx Kms. I think even that should not be there as the engines are already run-in.
Hope this helps.
vinit.merchant is offline   Reply With Quote
Old 31st October 2008, 23:38   #54
Thanked: 749 Times
here you go my friend
http://www.team-bhp.com/forum/tyre-a...nso-blitz.html (My Civic with 17 inch White Lenso Blitz)
Old 11th November 2008, 11:15   #55
Thanked: 13 Times
Well i have some really bad bad news.
well I too have some. My civic got a kiss from one of those trucks from the Hosur-road-BETL project. The impact was very small, but an ugly dent appeared exactly on the trunk door (what's should the exact word here?) where the honda 'H" badge is.
I thought I could live with it, but wife insisted for a change/repair. Ours is a black civic, 2008 April Model.
Went to Magnum Honda and those fellows said, impossible to repair/straighten-up, so go for change in boot door and it will cost 18K (including painting the new piece black) plus extra for the badges(civic, H, 1.8V and iVtech)
For a second check, went to Dakshin honda. They said change will cost 13K plus extra for badges or they can straighten up the dent at 5K plus taxes.
Well, the concern is how come there are completly different charges for same body part at two different dealers?
Did any of you guys have the bad experience of changing the boot-door of civic? And if so, how much it costed?
RakishRam is offline   Reply With Quote
Old 11th November 2008, 11:47   #56
Swifty2008's Avatar
Small dents in any body part can be straightened. I guess Magnum is trying to fool you. Good that you check with other dealers.
The estimate of Dakshin Honda also seems to be on a higher side. 5K is high, just for a dent repair. Does that cover the paint job ?
Swifty2008 is offline   Reply With Quote
Old 11th November 2008, 12:44   #57
Thanked: 13 Times
Infact, I was quite happy with Magnum honda till other day.
Yes, it does.
Old 11th November 2008, 13:31   #58
Swifty2008's Avatar
Yes, it does.
Okay. Then how can the total estimate be 13K?
Is it 5K(Denting and Painting) + Badges + Taxes = 9K max.
Denting and Painting = 5K
Badges = 2K ?
Taxes = 2k max
Ask them whether they can put the old badges back. I think they are either sticked on to the body.
Is my understanding correct?
Old 11th November 2008, 14:44   #59
Thanked: 13 Times
Nopes. Maybe I wasn't clear before. They gave two options.
1. Brand new trunk door at 13K + badge charges.
2. Repair (straightening + painting) at 5K + taxes.
Old 11th November 2008, 16:24   #60
Thanked: 749 Times
if your insurance is giving the money then get the trunk door changed.if you're paying the money get it repaired.simple.
VW Polo - Maintenance and Service cost and dos/don'ts gaurav_chopra04 Technical Stuff 1182 13th January 2017 01:28
