Old 24th March 2016, 07:48   #7321
Thanked: 153 Times
Default Re: Honda Civic : Maintenance, Service Costs and Must dos
Originally Posted by nik0502 View Post
Hi pixantz,
The chilling is quite good when the compressor is working however it is not cooling the car down properly as the compressor is cutting off too frequently. So when the car is running on a hot sunny day the compressor has to work continuously for some time in order to cool the car down completely and that is how it was some days back. But now the compressor keeps on cutting off as soon as i start the car even if the temperature is 35 degree outside and car is quite hot.
Turns out to be low refrigerant. Also diagnose why its low. I got the refrigerant filled twice before i realized that the evaporation coil was kaput. Replaced it with a new Denso one and got the gas filled. No issues.
coolkurt is offline   Reply With Quote
Old 24th March 2016, 09:50   #7322
nik0502's Avatar
Thanked: 91 Times
Compressor continuously cutting in and out is often an indication of too low refrigeration, so try and top it up and see what happens.
Jeroen
Hi Jeroen,
I will go the AC mechanic tomorrow, however does not look like a gas issue to me because when the compressor is on and its damn chilling. if I keep my hand on the vent just to check if the compressor is cutting off or not I start feeling uncomfortable in about a minutes time. its that cold. Its just it is not staying on for enough long.
nik0502 is online now   Reply With Quote
Old 24th March 2016, 12:54   #7323
Thanked: 153 Times
Hi Jeroen,
I felt the same too. I did the AC diagnostic as well and the AC was a chiller. Low refrigerant doesn't affect the cooling at times. In my case the evaporator coil was leaking, hence the refrigerant got low.
Old 24th March 2016, 15:00   #7324
1lokesh's Avatar
Thanked: 351 Times
So had the same issue which crops up during every long drive. No/very less cooling with very little air blow even when blower set to high and temperature set to "24".
Opened windows, turned auto mode to "hi" for 10 minutes and switched it back to "24" in auto mode. AC started working fine. I'm fed up of this! Going to check if the ac is low on gas as soon as I'm back in mumbai.
1lokesh is offline   Reply With Quote
Old 24th March 2016, 15:19   #7325
pixantz's Avatar
Thanked: 401 Times
Your cooling coil is choked up. Period. Even the ASS guys don't tell you that until you register a complaint and then they charge the hell out of you.
OK, so a heads up for all AC related problems. Every issue is NOT RELATED TO INSUFFICIENT GAS!! There can be more than half a dozen reasons and it varies from car to car. So that's that.
Mod Note : Please use the EDIT or MULTI-QUOTE buttons instead of typing one post after another on the SAME THREAD!
To know how to multi-quote, click here (How to MULTI-QUOTE (when replying to a thread) on Team-BHP).
We advise you to read the Forum Rules before proceeding any further.
Last edited by Aditya : 24th March 2016 at 18:35. Reason: Merging back to back posts
pixantz is offline   Reply With Quote
Old 24th March 2016, 15:38   #7326
1lokesh's Avatar
Thanked: 351 Times
Default Honda Civic : Maintenance, Service Costs and Must dos
I'm now confused. What is the problem?
I'm thinking of if gas was low low how could it cool it again to optimum level?
Old 24th March 2016, 16:41   #7327
sumeethaldankar's Avatar
Thanked: 780 Times
Lokesh was the ac relay looked into ?
sumeethaldankar is online now   (1) Thanks Reply With Quote
Old 24th March 2016, 18:32   #7328
pixantz's Avatar
Thanked: 401 Times
Your problem is a classic choked up cooling coil problem. Get it leak checked and cleaned. Check if both fans up front are working at full speed during AC operation. Fill in fresh gas and comp oil topup. Have fun.
pixantz is offline   (1) Thanks Reply With Quote
Old 24th March 2016, 18:56   #7329
laluks's Avatar
Thanked: 6,068 Times
I just chanced to visit HASS. Checked the Condenser fan motor cost, it says ~12K. With the assembly including frame and fan it is 16K.
Anyways i will be traveling to Europe soon, I will pick it up there after sourcing it and check. Seems some 20Euros for Denso!
laluks is offline   Reply With Quote
Old 25th March 2016, 12:37   #7330
Thanked: 116 Times
Friends,
Anyone got his discs skimmed recently from an FNG?
I need an idea of the approx cost.
Thanks in advance.
skdking is offline   Reply With Quote
Old 25th March 2016, 12:47   #7331
Thanked: 153 Times
The power steering reservoir is half choked with dirt for some reason. My mechanic is trying his best to get it clear. There's a screen inside that acts as a filter and it seems to have stopped a lot of dirt, which is actually good as it stopped any particles from getting further into the system.
A new reservoir costs around Rs 1800 :/ Any ideas on how to go about cleaning this? Or is there a way to open the top portion of the reservoir? we tried but it looks like its not possible.
Old 25th March 2016, 15:56   #7332
sushrutha's Avatar
Thanked: 318 Times
Originally Posted by skdking View Post
Friends,
Thanks in advance.
I've got my rotors skimmed. Those were sent to Lathe for skimming.
Price paid for skimming was around 1200 for a pair of rotors
sushrutha is offline   (1) Thanks Reply With Quote
Old 26th March 2016, 15:25   #7333
petroguzzler's Avatar
Thanked: 68 Times
Bhpians,
I have another query regarding the oil level of the civic. I had recently changed to synthetic oil. On checking the dipstick, I find the oil level to be slightly more than the upper limit. Is this okay or it should be reduced?
petroguzzler is offline   Reply With Quote
Old 26th March 2016, 16:36   #7334
saket77's Avatar
Thanked: 3,424 Times
Originally Posted by petroguzzler View Post
Bhpians,
Depends upon how much more than the upper limit. If it is more like a couple of millilitres then I wouldn't worry. If substantially more then it can create more than required pressure and may lead to a leak in the head gasket leading to big service bills.
Regards.
saket77 is offline   (1) Thanks Reply With Quote
Old 26th March 2016, 17:51   #7335
sgiitk's Avatar
Thanked: 3,348 Times
If available then I will get it put into an ultrasonic bath. Works almost all the time.
sgiitk is offline   (1) Thanks Reply With Quote
VW Polo - Maintenance and Service cost and dos/don'ts gaurav_chopra04 Technical Stuff 1247 21st March 2017 11:33
