Old 30th March 2016, 16:30   #7351
Thanked: 112 Times
Default Re: Honda Civic : Maintenance, Service Costs and Must dos
Friends,
On Friday I gave our Civic for part painting and servicing to an FNG in Ambattur, Chennai.
The service was excellent. I am a satisfied customer.
However yesterday I found my younger son rolling on the floor with mirth. After controlling himself with great effort he pointed the upside down Honda logo to me.
A minor issue that I will get corrected soon.
However my query is that "What kind of glue they use for fixing such fixtures?. Hope it does not leave its mark on the freshly painted surface.".
Honda Civic : Maintenance, Service Costs and Must dos-civic.jpg
skdking is offline   (1) Thanks Reply With Quote
Old 30th March 2016, 18:04   #7352
WasavaTyres's Avatar
Thanked: 178 Times
Smile Re: Honda Civic : Maintenance, Service Costs and Must dos
It is usually a 3M or equivalent UHB (ultra high bonding) tape. The adhesive marks - if any - can be removed with a adhesive remover spray that most paint shops usually have.
WasavaTyres is offline   (1) Thanks Reply With Quote
Old 30th March 2016, 18:09   #7353
rr_zen's Avatar
Thanked: 240 Times
Friends,
Which FNG is this in Ambattur ? My rear bumper needs a fresh coat of paint. HASS is asking north of 4K INR for the same.
rr_zen is offline   Reply With Quote
Old 30th March 2016, 18:12   #7354
Thanked: 178 Times
Originally Posted by Pashin View Post
The most likely culprit is a non-working PCV valve. Have it checked and replaced, the problem should disappear.
The HASS here has not been able to source the PCV valve even after a month. The SA called today to communicate that it's a dead inventory item at Honda's end so he has no idea when they'll be supplied with one.
WasavaTyres is offline   Reply With Quote
Old 30th March 2016, 20:15   #7355
Thanked: 112 Times
MyTVS. Located near Olympia Honda.
Old 30th March 2016, 21:59   #7356
sumeethaldankar's Avatar
Thanked: 766 Times
Wow the car looks Hot. How much did it cost to paint king ?
Thanks.
sumeethaldankar is offline   (1) Thanks Reply With Quote
Old 31st March 2016, 12:43   #7357
Thanked: 112 Times
Thanks.
Thanks, Sumeet.
I got the entire right side, plus the dicky boot, painted owing to minor scratches.
Cost 10K.
Whole body polishing too. Cost 3K.
Thanks.
skdking is offline   Reply With Quote
Old 31st March 2016, 12:47   #7358
smartcat's Avatar
Thanked: 5,942 Times
Thanks, Sumeet.
Cost 10K.
Thanks.
Looks good. I think the dealer charges Rs. 80,000 for repainting the whole car.
smartcat is offline   (1) Thanks Reply With Quote
Old 31st March 2016, 12:51   #7359
rr_zen's Avatar
Thanked: 240 Times
Thanks, Sumeet.
Cost 10K.
Thanks.
The charges seem to be reasonable for the area painted. The only apprehension I have is if the FNGs are good at matching the color with the original and if they use a good brand of paint. HASS has the formula to mix different paints to arrive at the right match. This was demonstrated to me once during the first year anniversary celebrations of Olympia Honda.
Old 31st March 2016, 14:17   #7360
Thanked: 11 Times
Originally Posted by petroguzzler View Post
Bhpians,
I have two unresolved problems in my Civic.
The first one is the clutch judder which causes a noise and jerk in both the first and reverse gears. What would be the solution?
Dear petroguzzler, the clutch judder is a normal issue on Civic, if the judder is too high, please check the engine mount gap and replace if needed. Now if the engine mount issue is ruled out, for the normal judder you can overcome it with giving more gas in the 1st gear or in the reverse, it's a case of adjusting your clutch and accelerator modulation to overcome this.
Bhpians,
The second issue is spongy brakes. I had changed the entire front brake discs, calipers and pads. In spite of this the brakes are spongy and ineffective. HASS tells that it would improve with usage. Is it right?
There seems to be air in the brake pipeline leading to the spongy effect. Usually Honda Civic brake pedal feel is spot on and other drivers driving it usually complain while applying brakes saying its just too sharp.
I think in your case since you have changed all parts including the calipers, there is air in the pipeline as well as in the calipers, which needs to be bleeded out. To remove air from the calipers it needs to be hit with a rubber mallet to release the air bubbles clinging onto the caliper walls behind the piston and the piston needs to be compressed inside the calipers before you do so, hope this helps and your brake feel will be back to the sharpness it usually should have. You also need to ensure the technicians doing the brake line bleeding are following the proper process, you can find specific information for the same in the forum here and this thread will also have many posts with references on the same.
Cheers.
Amit
amitsatpathy is offline   (1) Thanks Reply With Quote
Old 31st March 2016, 15:23   #7361
Thanked: 112 Times
Yup. You are right. For repainting the car entirely, after stripping, one has to budget around Rs. 80000/-.
In my case it was only repainting of the panels. Thus less expensive.
....... The only apprehension I have is if the FNGs are good at matching the color with the original and if they use a good brand of paint. HASS has the formula to mix different paints to arrive at the right match. .....
rr_zen, you also are right.
Old 1st April 2016, 08:53   #7362
petroguzzler's Avatar
Thanked: 65 Times
Bhpians,
I have a query.
I have observed that Maruti engines, especially the wagon r on idling produces a lot of water droplets, while the civic produces less of water droplets. Any specific reason to this?
petroguzzler is offline   Reply With Quote
Old 1st April 2016, 09:32   #7363
nik0502's Avatar
Thanked: 91 Times
Bhpians,
I have a query.
I believe that is because of the length of the car. Civic is quite long as compared to wagon R and with that bigger engine it's supposed to generate lot more heat as compared to wagon R and all the water droplets would get evaporated because of the heat and length of the exhaust. I had my car on a jack at my mechanic's place because he was checking for the PS leak. And the engine was on. And then I noticed there were lot of water droplets coming out of the exhaust. Because as the car was on jack from the front the water drops would be travelling faster to the end of the exhaust before they get evaporated. I may be wrong but this is my understanding. Senior bhpians please suggest.
nik0502 is offline   (1) Thanks Reply With Quote
Old 1st April 2016, 16:23   #7364
Thanked: 150 Times
Okay. So the PS pump finally went kaput. Got an original Honda replacement for Rs 13500 from Rahul Motors at Palika Bhawan. Quite a steal, considering even Ghai Spares quoted 18-19k. Changed the PS fluid bottle too for Rs 1500 as the older one was clogged with dirt. Labour - 600.
Total damages - 15600. Peace of mind prevails
coolkurt is offline   Reply With Quote
Old 2nd April 2016, 08:36   #7365
aa_asif's Avatar
Thanked: 35 Times
I am taking my Civic for the periodic service (basically oil change) to a near workshop. Can anyone help me with the replacement interval of fuel filter and airfilter? Last time I changed them were 10,000 Kms back.
Also just want to confirm that the engine oil capacity is 3.75 Litres?
Thanks!
aa_asif is offline   Reply With Quote
VW Polo - Maintenance and Service cost and dos/don'ts gaurav_chopra04 Technical Stuff 1232 17th February 2017 14:34
