Old 2nd April 2016, 09:01   #7366
Thanked: 119 Times
Default Re: Honda Civic : Maintenance, Service Costs and Must dos
Originally Posted by aa_asif View Post
I am taking my Civic for the periodic service (basically oil change) to a near workshop. Can anyone help me with the replacement interval of fuel filter and airfilter? Last time I changed them were 10,000 Kms back.
Also just want to confirm that the engine oil capacity is 3.75 Litres?
Thanks!
Hello Asif,
Please change your Oil Filter only if you are changing your Engine Oil.
For air filter, cleaning with compressed air should suffice. Unless you have used your Civic in very dusty conditions.
skdking is offline   (1) Thanks Reply With Quote
Old 2nd April 2016, 10:43   #7367
aa_asif's Avatar
Thanked: 35 Times
Changing oil filter goes without saying . I wanted to confirm the quantity whether it's 3.75 Litres?
aa_asif is offline   Reply With Quote
Old 2nd April 2016, 14:41   #7368
sumeethaldankar's Avatar
Thanked: 811 Times
I think it should be around 4 litres.
sumeethaldankar is offline   Reply With Quote
Old 2nd April 2016, 20:37   #7369
Thanked: 811 Times
How many cat cons does the Civic has ? I am flirting with the idea of a cat back system free flow from automech but i do not want the catcon deleted.
Old 3rd April 2016, 09:38   #7370
aa_asif's Avatar
Thanked: 35 Times
There's one right outside the integrated header which can be seen from the hood itself. I am not sure about a second one midway underneath. I have read in many forums that Cat-Delete + Cold Air Intake can negate the initial torque problem to a certain level. I've been contemplating on this for quite a long time.
aa_asif is offline   (1) Thanks Reply With Quote
Old 3rd April 2016, 10:53   #7371
smartcat's Avatar
Thanked: 7,680 Times
There is a very interesting article in the latest issue of Autocar India (April 2016) on page 150.
Apparently, a pre-owned Honda Civic is now the cheapest way to get to 200 kph.
smartcat is offline   Reply With Quote
Old 3rd April 2016, 20:49   #7372
Default AC clutch
My Civic (8 yrs old, 60k done) is having an issue with AC. Sometime, ac compressor stop working, and it come back after sometime.
HASS checked and said "AC field coil, clutch set" to be replaced. It seems its electric magnet is loosing its power when temp in engine bay raises..
Has anyone faced this ?
swageo is offline   Reply With Quote
Old 3rd April 2016, 23:12   #7373
pixantz's Avatar
Thanked: 435 Times
It is a possibility, technically, but on a Honda? Not sure. But being an electronic component, you cannot really rule anything out. This symptom can point to compressor relay malfunction too. It also acts the same way when it heats up.
Take a guarantee from the ASS that their diagnosis is the final solution to the issue and not anything else. Otherwise these people tend to point out to another component if the issue doesn't get solved later and the story continues until your pocket gets a lot lighter in the process.
pixantz is offline   Reply With Quote
Old 4th April 2016, 09:03   #7374
Thanked: 163 Times
Any link/ screenshot of that article?
coolkurt is offline   Reply With Quote
Old 4th April 2016, 09:08   #7375
Thanked: 163 Times
Default Re: AC clutch
For starters, check the relay. It's usually the first place to check.
Old 4th April 2016, 10:57   #7376
1lokesh's Avatar
Thanked: 354 Times
Originally Posted by 1lokesh View Post
Thanks pixantz. I am going to get this checked this weekend. HASS guys have highlighted "AC fan jammed" for a couple of times but I have never experienced car heating up abnormally - which should be the first cause of fan failure. So this cooling coil seems to be the issue.
Not yet Sumeet. I will have that too looked into this weekend. Planning to go to Unicool.
Ok, so took the car to Unicool yesterday. Diagnosis - Condenser fan motor was indeed jammed - as highlighted by ASS guys earlier. Got it changed with Denso, one that is used for zen, CRV etc. Perfect fit. Damage: INR3.2k.
Anis and his staff insisted on full AC service also, since they observed a lot of things are choked up inside like blower etc. Agreed to that as well. Additional dent of INR 2.8k including refrigerant top up (as told by them). In total spent INR 6k to get the AC back to normal.
Payoff observed today when that irritating AC kick in vibration went almost unnoticed throughout my drive from home to office. Cooling also seems to be better and more powerful.
1lokesh is offline   Reply With Quote
Old 4th April 2016, 12:30   #7377
Thanked: 11 Times
Dear All,
A learner uncle kissed the right side of my immaculately maintanined 1.8S Alabaster Silver 2007, Honda Civic and left his cars imprints on my car front and rear door and also damaged the modings in the process with minor paint peel and good dent (repairable) ones though.
I have few queries on getting the job done, and need your help.
1. Door moldings are quite costly from HASS, 5k approx for each, can I get OE or original sourced from somwhere? part no. is 75302-SNB-T01ZH (R, FR), 75303-SNA-A01ZF (R, RR).
2. Also the dent on the door skin, though not that bad, I am pretty sure there will be some wave patterns post the re-painting. Could I by any chance ensure that there are no waves on the doors post the dent and paint?
3. As an alternative are door skins for the door's outer panel available anywhere in India which I can source, otherwise can I source doors as such for the car from outside HASS? Each door (complete panel) at HASS would be approx 40k, so don't think its a viable expense due to the cost involved.
Please advise.
Thank you,
amitsatpathy is offline   Reply With Quote
Old 4th April 2016, 15:04   #7378
petroguzzler's Avatar
Thanked: 68 Times
Bhpian's
I have another query:
I had drained out excessive oil filled (about 0.5 lit) yesterday. The drained out oil was black in colour. I thought only diesel engines have the oil blackened. Is it normal?
P.S. I had filled in Honda Synthetic oil.
petroguzzler is offline   Reply With Quote
Old 4th April 2016, 21:43   #7379
laluks's Avatar
Thanked: 6,124 Times
It has been my way ever since I owned it, but after burning Yokos in 10K Kms, I stopped having such fun...too expensive on the pocket, and way too silly now
laluks is offline   Reply With Quote
Old 5th April 2016, 14:17   #7380
Thanked: 68 Times
Originally Posted by amitsatpathy View Post
There seems to be air in the brake pipeline leading to the spongy effect. Usually Honda Civic brake pedal feel is spot on and other drivers driving it usually complain while applying brakes saying its just too sharp.
Thanks for the response amitsatpathy.
Originally Posted by petroguzzler View Post
Bhpian's
Do you have any answer for the above question?
VW Polo - Maintenance and Service cost and dos/don'ts gaurav_chopra04 Technical Stuff 1264 1st May 2017 01:12
