Old 23rd November 2008, 17:28   #16
raj84's Avatar
Thanked: 147 Times
Update Time!!
The Beast(or rather Rattle Snake) has covered 687 kms. The enigine is pretty much the same as the first day. Smooth and Silent.
Issues?
Slotting into the third gear now feels different. It feels as if there is a curvy path from fourth to third instead of the earlier straight path. The same is the case from second to third. The third gear slot now takes a curved path instead of 90 degree paths from second and fourth. Wonder what the issue is?
Rattles
The car is now rattle free. But the ride is harsh with every craters on the road being felt inside.
Headlights
As already mentioned, the headlights are really bad and it feels like parking lights compared to even my bike. Very bad.Checked the spare bulbs provided by Maruti and found that it is some local unheard of brand.Need to switch to Phillips. Wonder whether it is available with the Maruti Dealer itself, so that I can be safe on the Warranty.
New Discoveries
Found that the car has an Airbag indicator as well.Ofcourse it does not work. This makes it clear that Maruti has used the same instrument panel for all versions(except LXi and LDI)
ABS- Four Channel or Two Channel
I have read many posts which debated whether Swift has a two channel or four channel ABS. I have no answer to that but I found something interesting as I looked underneath the Swift, which I guess is related to ABS. The ABS mechanism to control the brakes is there in both the rear brakes as well. Attaching the pictures for a better idea. Now can anyone confirm whether the Swift has two channel or four channel ABS?
raj84 is offline   Reply With Quote
Old 24th November 2008, 10:22   #17
ariendj's Avatar
Thanked: 83 Times
finally!!a new update.
was so waiting for it.btw,which philips are you getting and does it require a relay or just fitting into the stock ones?
and what about cost?!
ariendj is offline   Reply With Quote
Old 24th November 2008, 22:18   #18
raj84's Avatar
Thanked: 147 Times
Hi Ariendj, I am planning to go for the Philips VisionPlus.It does not require Relays. Maybe a better version if I can find one
Which lamp type you need
http://www.team-bhp.com/forum/modifi...g-here-30.html
Old 24th November 2008, 22:34   #19
live2drive's Avatar
Thanked: 25 Times
Originally Posted by raj84 View Post
Update Time!!
Issues?
Rattles
Headlights
New Discoveries
The brand of bulbs supplied by maruti is "JAGAN" or something like that . The name is very funny.
Switch to higher wattage lamp. A philips 100/90 would do. Relay and wiring would be required.
The pictures of the underbody shows the sensors for ABS which sense tyre locking. Hope i am correct.
live2drive is offline   Reply With Quote
Old 24th November 2008, 23:08   #20
faithless_1984's Avatar
Thanked: 217 Times
Just went through your thread about how you got your `Beast` and it felt like i was reading a movie script.
Glad to see that you finally got what you wanted.
A first car is really special.
Congrats.
Drive safe.
faithless_1984 is offline   Reply With Quote
Old 24th November 2008, 23:40   #21
ariendj's Avatar
Thanked: 83 Times
hey raj84..keep us updated on the philips lights!! and do give specifications of the bulbs used.
btw,thanks for the link..
Old 25th November 2008, 20:29   #22
raj84's Avatar
Thanked: 147 Times
@live2drive: Yes the brand name was Jagan or something like that. It was a name of a person rather than a brand. So we can expect the quality of the headlight
Can you specify the model of the Philips bulb you are saying. I will buy that if it is around 1200rs and if the dealer themselves can do it(Warranty issues)
@faithless_1984: Thank you sir!!.. Even for me the purchase experience was a roller coaster ride
@ariendj: Sure will update you on the upgrade
Old 25th November 2008, 21:20   #23
phamilyman's Avatar
Thanked: 3,526 Times
@Raj - Aren't you driving quite a bit too slow?
btw, the OEM is Halonix 60/55. Jagan is just the spare one! Why not figure out Osram Silverstar (350-370 a pair, 190 apiece)
Old 25th November 2008, 21:48   #24
philippose's Avatar
I have got a problem with my swift's brakes and i don't know if this is the right thread to tell this. Then again here goes. I took a new swift 2 weeks back and had no problems with the brakes. But now or a day or two whenever i apply the brakes i feel it is not sufficient enough to stop. I don't get any confidence and i feel the stopping distance have also increased. PLEASE HELP. The car has run around 1500 kms and the first service is over
philippose is offline   Reply With Quote
Old 25th November 2008, 21:52   #25
live2drive's Avatar
Thanked: 25 Times
Philips rally, not too sure though. I dont think the dealers will do it for you as anything above 60/55w is illegal.
Go for philips vision plus or Osram nightbreaker. They are of same wattage as the oem's are and there won't be any warranty issues.
Old 26th November 2008, 11:46   #26
ankit.jhamb's Avatar
slow :for the speed or for the kms.
ankit.jhamb is offline   Reply With Quote
Old 30th November 2008, 22:55   #27
Thanked: 7 Times
Hope it is just as what you have mentioned.Will get it checked
Any Idea as to what is the Ideal Tyre pressure on XM1+ 185/70/R14 on the Swift?
Hi Raj, Hope you are doing great and so do your beast as well.
regarding your query on tyre pressure i felt it would be opt if we keep a psi less than that of the mentioned tyre pressures for ZDI 185x70R14 as Maruti people would have calculated the same for Diesel engine..
I keep me tyre pressure wrt to the below pic-1 psi of Nitrogen gas which is available in IOC outlet in front of my house
hope this helps you..
thereal is offline   Reply With Quote
Old 1st December 2008, 05:48   #28
kuttapan's Avatar
Thanked: 12 Times
Just pop the hood and look at the ABS control unit. You can see four channels.
33F/31R used to work for me with same tyres. I used to go up 1PSI, if the car was fully loaded. Of course, ride is better at lower pressures, but I preferred this setup.
kuttapan is offline   Reply With Quote
Old 1st December 2008, 18:55   #29
Thanked: 7 Times
IMO since the Dzire ZDi is heavier than SWIFT VDi they suggest 32F,29R
As we drive a lighter car we shall go with 1 Psi less than mentioned.
As Kuttapanji rightly said these specifications mentioned by the Maruti are specifically for better ride feel and comfort, but some would like to have to have different setup for handling and driving pleasure
Old 1st December 2008, 20:17   #30
I drive my dzire vdi with 31F and 28R.The wheel used to bounce with the recommended 36F and 33 R.
My Red Blazer Maruti Swift VDI with ABS premjit Test-Drives & Initial Ownership Reports 27 30th March 2015 22:34
Stickers for bright red Swift vxi dodgeviper Modifications & Accessories 19 21st May 2010 22:41
Booked my Bright Red Beast- Swift VDI with ABS raj84 Test-Drives & Initial Ownership Reports 204 18th November 2008 09:52
For Sale : Zen Vxi 2005 (Bright Red) Freaky_Sid!! Shifting gears 1 14th December 2007 09:05
