Old 18th February 2011, 12:56   #61
mtnrajdeep's Avatar
Thanked: 101 Times
Default Re: Bright Red Beast(Swift VDI ABS) - The Real Story Begins
They had the guts to charge a diesel vehicle for petrol injector cleaning ? Why did you even agree to paying the bill in the first place with such mistakes in the bill?
mtnrajdeep is offline   Reply With Quote
Old 18th February 2011, 14:46   #62
raj84's Avatar
Thanked: 147 Times
I had asked the Service Technician about this.He said it is the same rate for Diesel vehicle as well. Since I was not much knowledgeable on the mechanicals of a car, I believed it.
raj84 is offline   Reply With Quote
Old 18th February 2011, 16:11   #63
skanchan95's Avatar
Thanked: 832 Times
Originally Posted by raj84 View Post
ABS
I do not know whether it has ever worked. Never seen the ABS indicator flashing while driving.
If the ABS light on the speedometer console ever lights up, it would mean a malfunction in the ABS and not that the ABS is kicking in.
If you drive a non-ABS Swift after driving your Swift, you will notice the difference braking feel between the two Swifts. I had a Swift ZXi. Once I drove an LXi, I came to know how differently the brakes in the two variants felt, the braking in the ZXi was much more crisper.
skanchan95 is offline   Reply With Quote
Old 18th February 2011, 17:07   #64
raj84's Avatar
Thanked: 147 Times
@ skanchan95 : Thanks for the info. I knew that the ABS light staying on after starting the car, indicated a malfunction. But I also thought that it would light up when ABS kicked in, just like the fog light or high beam indicator. So that is why I never saw the ABS indicator flashing.
I have felt the car moving in the proper direction even when I thought it would go out of track while braking in corners. This made me feel either ABS has kicked in or it is the Michelin magic.
Sometimes during heavy braking I have felt like the brake pedal has hit a metallic barrier with a crashing sound without effectively applying the brake discs. This gets rectified by releasing the brake pedal and then again pressing it. Initially I thought this was the pulsating effect of ABS but then if it cant reduce the speed then it would not be ABS. Have faced this three times in the last 2.5 years of ownership.
My Red Blazer Maruti Swift VDI with ABS premjit Test-Drives & Initial Ownership Reports 27 30th March 2015 22:34
Stickers for bright red Swift vxi dodgeviper Modifications & Accessories 19 21st May 2010 22:41
Booked my Bright Red Beast- Swift VDI with ABS raj84 Test-Drives & Initial Ownership Reports 204 18th November 2008 09:52
For Sale : Zen Vxi 2005 (Bright Red) Freaky_Sid!! Shifting gears 1 14th December 2007 09:05
