Go Back   Team-BHP > Indian Cars > Team-BHP Reviews > Long-Term Ownership Reviews
Long-Term Ownership Reviews Ownership reports, of Indian cars, spanning over several years and thousands of kms
Thread Tools
Old 26th November 2008, 22:53   #1 (permalink)
arpandiv's Avatar
Default Alto 1.1 Vxi - WIP Forever - 52,500km
I hope with this thread i am able to document my experiences with my first car. A secondhand Alto 1.1 Vxi. 2002 model.
Got the car in Feb 2008 when it had clocked 40,xxx km.
Currently the odo reads 52,500km.
On buying the car,the very next day i got the basic servicing done.This included :-
Engine Oil & filter change.
air filter change.
fuel filter change.
Throttle body cleaning.
At that time the car used to jerk a bit in low revs primarily while negotiating traffic.
we found that the TPS was faulty.(Thread is present on TBHP ) Now,Maruti does not sell TPS as a part.You need to buy complete throttle body assembly.So what followed was a month long hunt for the a Throttle Position Sensor. Finally got hold of one for Rs 750.
Jerking problem resolved.
As kms passed, gave car to SaiService(Borivali) to get timing belt changed. Cost of this including labour and some misc items came to 1800.
Somewhere in the meantime yet another service happened. Replaced Sparkplugs and brake pads too and got the injectors cleaned.
The car was running smoothly all this while no problems as such. Even did Mumbai-pune-Mumbai and Mumbai-Mahableshwar-Mumbai trips.
While coming back from one of the pune runs, decided to see how much the car can do,while the top speed attained was quite commendable,what happened next was least expected, the temp shot up!
Pulled over and gave it some time to cool down. Checked fan,was working perfectly sufficient coolant was also present. What could have gone wrong ? A check up once back home revealed a cracked radiator elbow pipe and a FALLEN thermostat valve! Anyways that was replaced ( 250 or so for the valve and 80 bucks for the elbow)
Given the free time i had during diwali, decided on getting some work done on the car, this included changing the driveshafts and getting the front suspension overhauled. Changed lower-arm etc. This cost me 5400 for the driveshafts and 3000 for the suspension. Also changed oil and oil filter yet again.
Now it was time to get new tyres, went in for 155/60 R13 Michelin XM1.
they were installed on rims from i10.(100PCD) spent 12K on tyres and rims.
In the last 15 days or so, had noticed that the car was unable to hold idle sometimes and used to hunt for idle.
Now considering that the car does not have a wild cam or a custom ecu or a turbo install, it was a cause for concern
Saiservice borivali cleaned the throttlebody and the problem seemed to have gone,but came back in next 400kms.
Gave the car back this sunday, they took their time trying to get to the cause,after swapping Idle control valve and throttle body also. They have come to the conclusion its the throttle body, so have paid 50% advance while they order the part from delhi.
Will update on this.
As you might have noticed i have spent a lot more on the car then what would ideally be needed,but my only philosophy is that if i have a vehicle it better run the way it should,otherwise whats the point ?
arpandiv is offline   Reply With Quote
Old 26th November 2008, 23:34   #2 (permalink)
vid6639's Avatar
The i10 has 4.5B bead and not the standard 4.5J rim. I'm not sure but that could be a problem.
__________________
Let's get "instigated".....
\ / ][ |) `/ [_] "!"
vid6639 is offline   Reply With Quote
Old 7th March 2009, 13:19   #3 (permalink)
My sympathy with you. Is all i can say. I too wanted an alto vxi. good visiblity, economical spares, and a powerful engine. Your review makes me think now.
kavesh55 is offline   Reply With Quote
Old 7th March 2009, 14:25   #4 (permalink)
loving_alaap's Avatar
well, usually Alto is considered as a safest buy, but this case might be an exception.
So, dont worry and buy alto.
__________________
Ferrari Enzo
loving_alaap is offline   Reply With Quote
Old 7th March 2009, 14:43   #5 (permalink)
muneemmk's Avatar
What does that mean in plain English ? and what could be the problem ?
muneemmk is offline   Reply With Quote
Old 11th March 2009, 16:44   #6 (permalink)
arpandiv's Avatar
Car has clocked 59,000kms now, got hold of a ceekay-daikin clutch straight from the factory, and a SGP clutch bearing, both installed. While the clutch work was being done also modified the gear shift linkage a bit.
Old 11th June 2009, 20:33   #7 (permalink)
kaushykutti's Avatar
Hi Arpan! I too own an Alto 1.1. I am curious about the clutch, bearing and the gear shift linkage. Could you pl explain in detail?
kaushykutti is offline   Reply With Quote
Old 13th June 2009, 11:20   #8 (permalink)
arpandiv's Avatar
The car's clutch was weak so decided to change in. Got in the stuff through friends. The clutch is smooth now.
Update: Car is undergoing some unplanned work (due to a shunt) and will be back with a color change (to white)
the repair work includes :-
Apron ( LH & RH )
New doors(Front RH, Rear RH)
New FR bumper,Bumper grill
Headlamps
Bonnet
Engine Mounting,
Brake booster kit,
A/C compressor etc.
Here is a pic!
Old 13th June 2009, 11:27   #9 (permalink)
vid6639's Avatar
Are you sure you'll have the same structural rigidity? The precision of fitting the whole apron will be a challenge I think. You may get suspension/alignment issues.
Find out the difference of getting a new shell after selling this.
Usually instead of total loss insurance will agree for new shell. I have seen this at Mitsubishi with many cars totalled but insurance never approved total loss, they approved a new shell with whatever can be salvaged from the old body to be fit on the new shell.
__________________
Old 13th June 2009, 12:19   #10 (permalink)
arpandiv's Avatar
In insurance i am getting only RH apron. LH apron(its not damaged in the accident) is out of my pocket (they say it cant be alinged to the new RH apron) I was given an option between half apron and full. I choose the full apron option because even though marginally expensive they are guaranteeing no allingment,suspension issues.
But yes like you said even i think its a bit of a gamble, but the workshop is good, does only accident cases etc, so fingers crossed.
Old 19th June 2009, 18:45   #11 (permalink)
arpandiv's Avatar
New bonnet fitted.
Both side aprons installed. along with the various mounting brackets in front, the cross member etc.
Slowly but surely the work is getting done.
Old 2nd July 2009, 17:03   #12 (permalink)
arpandiv's Avatar
Today, the engine area got painted. this was done using spray paint, post which tyres will be put and the car taken to another area of the workshop for filler work and then to the paint booth.
the engine has been tested fitted and the mounting with the new apron is fine, new bumpers,headlamps also test fitted and line-level is done
Old 2nd July 2009, 17:20   #13 (permalink)
sgiitk's Avatar
We bought a 2001 Alto VX (no i, ie no power steering) for my son in 2003, with barely 12000 on the clock. We sold it in 2007 after having done another (I think) 20,000 or so. It was in Manipal for three out of the four years, and we took it for holiday to Munnar etc. (4 up). It turned out to be an excellent car with very good performance.
In 2007 I had occasion to drive it from Delhi to Kanpur followed by my daughter's Zen (1997 Carb version) from Gwalior to Kanpur a couple of weeks later. Only when we compared the two we found the difference.
The Zen was a far sweeter car. Smooth Engine, better ride, handling wetc. Overall better in every way, even though it had only 50 horses compared to the 60+ of the Alto. Only then did the merits of the All Aluminium 1000 engine vis a vis the 4/3 version of the M800 engine, and the Zen package really dawn on us.
The Alto VX range was a beauty as compared to the 800, and is a rare beast to find. However, it paled when compared with the original Zen as a drivers car.
__________________
Life is short, do not make it shorter!
Accent GLS 2002
Santro Automatic 2005
Old 2nd July 2009, 17:25   #14 (permalink)
gpa
gpa's Avatar
A lot of work has been done indeed. If I may ask, why the shift to the white color?
Am keeping a keen eye on this thread to see the final outcome.
__________________
Maruti Suzuki Alto (May 08) - 23,000 KMS
Hyundai Santro (Feb 05) - 59,000 KMS
Old 2nd July 2009, 18:21   #15 (permalink)
Technocrat's Avatar
Sorry but I disagree, I agree that the old zen had lower & more driver oriented seating posture but no way was the zen better in performance than the VX.
__________________
The Holy Trinity: Traction, Torque and Tarmac
Thread Tools
Getting AN ALTO VXi (1.1L) in Cochin aravindwarrier Hatchbacks 6 3rd October 2008 23:36
Sluggish Alto VXI Ankur426 Technical Stuff 6 17th June 2008 00:09
Is this an Alto VXi Muffler? TDR Modifications & Accessories 3 26th May 2008 16:16
Alto VXi serious_maniac Long-Term Ownership Reviews 19 22nd April 2008 13:25
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607
