Old 22nd March 2011, 19:08   #106
Thanked: 10,994 Times
Default Re: Skoda Octavia vRS woes
You might need to change them.
Try sales@skodaparts.com , give them your chassis no and the price of the part + delivery to india. Best is to buy 4 to reduce freight cost
My boot lock cost 17 pounds
Old 23rd March 2011, 15:48   #107
Thanked: 65 Times
Siddartha, I have had problem 1 occur on my rear right door. Same diagnosis by the *** - change all locks. i overcame that problem by squirting WD40 on the silver stud which goes up/down when the door is unlocked/locked and also in the central locking button on the driver side door.
My RS seems to have an appetite for WD40 (don't mind given its so cheap). A flickering xenon light was fixed by WD40 squirt in the connectors. The ECP light coming on and idling becoming rough was fixed with WD40 sprayed on the connector under the throttle-body.
My fuel gauge would dance between Empty and Full with the low fuel warning beep going off nowand then. This was sorted out by cleaning the terminals of the fuel gauge under the rear right seat cushion (behind the driver) and ofcourse WD40.
I had my suspension done byan independent garage in Mumbai. The guy knew what parts were required and where to find them in Opera House. I have Bilstein shocks installed now and they are great for chucking the car round corners.
Bomi
Bomi is offline   Reply With Quote
Old 24th March 2011, 15:40   #108
v&v
v&v's Avatar
Thanked: 1,099 Times
Originally Posted by siddartha View Post
The service advisor said i need to change the actuators, and they cannot be repaired or serviced even though its just a case of faulty contacts.
i have decided not to listen to whatever the service advisors say... trying to get my hands on a service manual. does anybody have one? please share the link, details.
Find an FNG and have it checked to get the actual diagnosis. I have read that this rear door problem is a common issue, can be of faulty cables or even dry solder with in the actuators circuit. I have read DIY at briskoda.com. Check that out.
v&v is offline   Reply With Quote
Old 4th October 2011, 16:22   #109
I had the same problem with my VRS. right back door would not lock using the remote. Skoda charges about 16k for replacement motor. I have found a electrician who has about 23-25 years of experience with all kinds of cars. He insulated all the 30 odd wires inside the left xenon headlight because they were brittle due to heat. He took a look at the motor and said he cannot make it work but he fit another motor and connected it to the car's rear door wiring. Now when i press the remote all 4 doors lock. cost me 650 for the motor and 200 for labour.
wilfax is offline   Reply With Quote
Old 4th October 2011, 17:54   #110
The motors for the rear boot costs only Rs 1200 if sourced from the UK
Old 4th November 2011, 16:29   #111
aditbelw's Avatar
Thanked: 40 Times
Default Assistance required Urgently
Guys, need assistance urgently.
Was driving down from Chennai to Pondicherry today, when a sudden mild shudder from the engine cropped up with the CEL came on. I am not able to exceed beyond 2000 RPM, and the CEL showing up, with 4 blinks and dying out randomly.
Called up Chennai service center who asked me to return , which was not possible since , I was almost in Pondicherry. Is there no service center in Pondy, where I can have this issue checked. Anything , DIY, which can be done to see if I can get the vehicle to chennai normally and get it checked there.
Thanks in advance..!
aditbelw is offline   Reply With Quote
Old 4th November 2011, 16:42   #112
v&v
v&v's Avatar
is the idling ok. if not then it could coil problem. Try ecu reset by removing -ve terminal.
v&v is offline   (1) Thanks Reply With Quote
Old 5th November 2011, 23:47   #113
aditbelw's Avatar
Thanked: 40 Times
thanks. It indeed was the coil problem. Had one delivered today from chennai, at an inflated cost, but could'nt have helped it. After fixing the coil, had the ecu reset, and bingo, the car was back to life. Finally, can head back to bangalore, directly.
Old 6th November 2011, 09:38   #114
You need to keep a spare one with you. My recommendation is that you replace remaining three and keep them as spares
Old 7th May 2012, 20:36   #115
Sprucegoose's Avatar
Thanked: 40 Times
Sorry to bump an old thread, but does anyone know where i can get a PDF of the service manual of the Octavia MK1 vRS from?
Sprucegoose is offline   Reply With Quote
Skoda Octavia vRS - Dreams do Come true!! ashish22 Test-Drives & Initial Ownership Reports 68 16th August 2013 15:06
Skoda Octavia II vRS skodaboy The International Automotive Scene 19 7th May 2006 20:17
Hot Skoda Octavia vRS nikibusa The International Automotive Scene 11 21st September 2005 12:58
