Go Back   Team-BHP > Indian Cars > Team-BHP Reviews > Long-Term Ownership Reviews
Long-Term Ownership Reviews Ownership reports, of Indian cars, spanning over several years and thousands of kms
Thread Tools
Old 2nd June 2009, 16:13   #136 (permalink)
tanwaramit's Avatar
good to hear the truck is back. Time to reclaim your life back again
__________________
“Don't drive as if you owned the road, Drive as if you owned the car”
Scorpio VLX AT 4WD to be booked in 2010 :)
tanwaramit is offline   Reply With Quote
Old 2nd June 2009, 16:22   #137 (permalink)
jaysmokesleaves's Avatar
Default Costs involved - breakup
Ok guys, here goes:
The following items were for the service light resolution:
  1. High pressure pump assembly
  2. Fuel rail assembly
  3. Injectors x 4
  4. Washers for injectors x 4
  5. Fuel pressure lines (rail to inj) x 4
  6. Pressure line(pump to rail)
The above components totalled = 57,528/-
The following components were replaced because they were unable to open the jammed injector from the head, so they had to replace the head. The following components i guess were part of the head replacement.
  1. Cyl head w/o injectors
  2. Cylinder head gasket
  3. Intake manifold gasket
  4. Exhaust manifold gasket
  5. Cylinder head cover
  6. Vacuum pump gasket
  7. Cyl head water outlet gasket
  8. Set back leak hoses
  9. Glow plug
  10. Intake manifold to pipe gasket
  11. Timing gear
The above components totalled = 37466/-
The following was charged to me. This includes cost of 30k service:
  1. Auto tensioner stud
  2. Hex flex nut Am 8
  3. Anabond
  4. Engine oil 15W40 Castrol GTX 7.5ltrs
  5. Oil filter
  6. System D (i purchased for future use)
  7. Wheel alloy covers x 4
  8. Brake pads x 2 pairs
  9. Brake pad fitting
  10. WD 40 rust leak
  11. Front wheel alignment
  12. Diesel(500/- for trial & testing)
The above components totalled = 9107/-
NOTE: Please dont ask for price of individual items mentioned above. The prices are available at the TASS. It would be sufficient to note the budget involved incase one were to replace the head or injectors outside of warranty.
FYI > Cost of brake pads = 3226/- + 400 labor.
Additional note> I was informed that TML decides parts replacement on a case by case basis. The above replacements were necessitated after all other trouble shooting failed. The trouble shooting process though is quite lengthy and reqires tons of patience and perserverance.
My footnote >
All in all I shall say that if one were to be using their vehicle everyday, then a 45 day visit to the workshop is not what you want or expect. It will get you totally stressed and put you off completely as a customer. I did get stressed as the days in the TASS started increasing. The TASS was apathetic to the situation, citing parts unavailability, weekend holidays, public holidays, etc. However, having said that, I must say that the support from TML customer care is good. If only TML had good quality control at the factory level in place then problems wouldnt arise in the first place. Work at the TASS moves at a very slow pace and without a push from TML customer care, you will end up waiting for Christmas. I now firmly believe that TML Customer care saves the day for TML. Without a good TML customer care, i would probably be left for dead at the hands of an apathetic dealer.
Alls well that ends well. Truck feels and sounds new. TRIP...????
__________________
Dream as if you'll live forever, Live as if you'll die today !!
jaysmokesleaves is offline   Reply With Quote
Old 2nd June 2009, 16:29   #138 (permalink)
Extremely disgusting from a consumers POV!
These happenings are not expected of modern cars, Tata needs to revamp/iron out issues with the Safari. Otherwise, it shall be left for dead, sooner than later.
Earlier I was thinking of going in for a Safari, but now after reading such stories, I better keep off it!
Life is so fast paced these days, who can afford to take time out almost on a daily basis to take the vehicle to Garages! Tata shall remain Tata, lot of work is required before their vehicles become trouble free.
bhp1 is offline   Reply With Quote
Old 2nd June 2009, 16:44   #139 (permalink)
Yes, I agree. But thankfully its TML is not a Skoda, else I would have to pay for all that and they(Skoda) would put all spurious parts to top it all.
Skoda... 'you' make 'me' feel good!!
__________________
Old 2nd June 2009, 17:27   #140 (permalink)
vivek.singh.73's Avatar
Originally Posted by jaysmokesleaves View Post
Ok guys, here goes:
  1. Wheel alloy covers x 4
Jay, what are these...wheel alloy covers?
vivek.singh.73 is offline   Reply With Quote
Old 2nd June 2009, 17:33   #141 (permalink)
tsk1979's Avatar
Allow wheeled safari's have small cups which cover the center part. They tend to fall off now and then, and cost 230/piece
__________________
Reclaimed, wrung dry and recycled....!
Old 4th June 2009, 11:20   #142 (permalink)
nvldvr's Avatar
Ok guys, here goes:
  3. Injectors x 4
  9. Glow plug
  11. Timing gear
Congrats on getting your safari back. 45 days is too long a time spend waiting for your vehicle to get repaired, specailly if its the only one. I am sure TATA could have done better. Hope your troubles are over and you start tripping again.
Of all the components amounting to 57000/- that were changed, i'm sure not had gone defective. Replacement of parts and hoping to nail the part
that actually is defective seems to be Tata's way of defect rectification.
Its all good as long as its covered under warranty. What about after the warranty has lapsed. I'm sure no customer would want to shell out thousands for this hit and trial method. Every defect has to be accountable to one or a few parts at the most, and not a long list like this. And finding that part / parts should not be as herculean a task as tata service people make it seem like.
Tata really does not to get its act together.
nvldvr is offline   Reply With Quote
Old 4th June 2009, 18:59   #143 (permalink)
4x4addict's Avatar
Infractions: 0/1 (7)
After warranty a Safari owner will need a very good independent Tata mechanic to own the safari. however, you still may still need to go to the dealer to read error codes. etc...
__________________
Life is what happens when you are busy making plans..
4x4addict is offline   Reply With Quote
Old 5th June 2009, 07:53   #144 (permalink)
That unfortunately is the worst part. Tata is unable to pinpoint the actual cause and the actual defective part or process.
One would be forced to go to a TASS for ECU & related problems, and they would just go on a parts replacing spree at the customers expense. This will lead to astronomical cost of ownership post warranty.
__________________
Old 5th June 2009, 08:37   #145 (permalink)
phamilyman's Avatar
I'm totally convinced (once again) that I did the absolutely smart thing by going with a Swift VDi - doing 17k in 7 months without a single sweat!
Old 5th June 2009, 13:19   #146 (permalink)
Well don't be so sure look at this thread on Swift Dezire
hitting a stone on road does not break cam shaft and to top it Insurance companey is not willing to pay
http://www.team-bhp.com/forum/indian...ml#post1332913 (Swift Dzrie Vdi Rightful Insurance claim denied - Beware of Royal Sundaram CHEATERS !)
So in Indian context we should keep fingers crossed always.
amitk26 is offline   Reply With Quote
Old 5th June 2009, 14:04   #147 (permalink)
Well don't be so sure look at this thread on Swift Dezire .
What a joke, can't compare Swift's reliability to Safaris, what a weired sense of comparison!
Old 5th June 2009, 14:13   #148 (permalink)
What's wrong with your reading comprehension ? Is it a comparison of reliability or what one may have to go through in freak cases.
And now you are on topic of reliability Why don't you check the Swift threads and cases of service lights / turbo hose coming off exactly same issues which are considered unreliable for Safari ?
How come clearing the error code in ECU is an acceptable solution for smaller cars where as service center goes all the way changing the parts on Safaris. Is it just because Maruti does not go on providing replacement parts they get away cheaply ? Points to ponder
Old 5th June 2009, 14:28   #149 (permalink)
Its just over the top paranoia & nothing else!
Maruti is far ahead/better than Tata in terms of reliability, after sales service, availability of spares, etc, etc. So much so, there's no comparison et all!
You can go to any lengths justifying your statement, but facts don't change, its a futile effort, lets compare apples to apples!
Moment doesn't seem far off when someone raises head & starts comparing Toyota here!
Old 5th June 2009, 15:04   #150 (permalink)
I do own a Maruti and Tata and have experience in visiting both A.S.S
and buying parts for Maruti any way i am not sure why you should consider that Dezire thing as something related to reliability in general rather then what one goes through if things go wrong in freak case.
And yes nothing changes whatever you and me say
Thread Tools
Suzuki Grand Vitara :100000kms in 24 months - Short Term report sudev Long-Term Ownership Reviews 194 21st November 2009 15:28
Tata Safari Long-Term Review Steeroid Long-Term Ownership Reviews 532 20th October 2009 22:35
January 2007 Tata Safari 3.0 DiCOR EX 4x4 Running Report dicorex4x4 Long-Term Ownership Reviews 127 23rd September 2009 16:14
Tata Sumo Victa GX Turbo: Long Term Report @ 45000km condor Long-Term Ownership Reviews 84 12th September 2009 12:36
Tata Safari DICOR 3.0 4x4 4x4addict SUVs, MUVs & 4x4s 16 21st April 2009 03:55
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607
