Go Back   Team-BHP > Indian Cars > Team-BHP Reviews > Long-Term Ownership Reviews
Long-Term Ownership Reviews Ownership reports, of Indian cars, spanning over several years and thousands of kms
Thread Tools
Old 1st April 2009, 16:50   #1 (permalink)
Default Tata Indica DLG turbo 30000K report
It is 1 Year and 30K Kms on ODO and it is time for long term report. Had the 30K KMS service done last week at Prerana Motors ,Peenya. Overall good experience with the service done. Had listed the below mentioned problems and it was rectified to satisfaction.
1) Check Engine indicator light used to glow sometimes. No certain pattern and in this way it was present for almost for last 8K Kms.
2) Had a small accident, a bike fellow came from nowhere had to break hard. Fog lamp was damaged and the fog lamp assembly was broken. Had asked to just replace the guard.
3) AC/Heater switch was not rotating properly. It used to get struck and it was possible to rotate after some time of engine run. I assume it was due heating-up.
4) Wheel- Balancing
5) Oil change
6) Decarburizing – I did not ask but the supervisor asked to me get this done as he mentioned it will increase the drivability.
7) Nitrogen air for the wheels
8) Dicky lamp was not working
9) Had asked to add coolant as the level was low.
All the above mentioned issues were fixed and the bill came-up to 4800/-. Coolant & Hose parts were replaced under warranty. Overall the service experience was good.
Now in the pros of the car.
1) Very spacious, good car for highway drives.
2) Getting mileage of around 16Kms with mix of highway and city driving
3) No major issues as such until now.
4) No major rattles as such.
Cons of the car:
1. Flat tire is major problem. I had this problem some 6/7 times until now.
2. Pick-up is not good in hot weather
3. Some niggle issues, can leave with it.
4. Looks like turbo is gone. Do not feel of it now at all. When the vehicle was new after around 2200 RPM used the feel the turbo turning on.
Overall I am satisfied with the car as of now not faced any major issues. It has been good drive for last 1 year. After driving friend’s Swift D, feel I should have gone for it. But still the 1.5 L difference makes sense I think, even though it needs some effort to drive a TATA vehicle.
srinivasmhn is offline   Reply With Quote
Old 1st April 2009, 17:04   #2 (permalink)
greenhorn's Avatar
Hi srinivas. have you followed the instructions about idling the engine for a minute before shutting off and after turning on? If you havent, the turbo would suffer from reduced life.
__________________
'07 Indica DLG - Almost a DLX
Old 1st April 2009, 17:57   #3 (permalink)
Hi!
I also have a 2006 April Indica turbo DLG. I have completed 1.00 Lakh + kms in 3yrs. My comments are given in bold.
[quote=srinivasmhn;1240906]
1) Very spacious, good car for highway drives. AGREE
2) Getting mileage of around 16Kms with mix of highway and city driving. I get 15-16. I have 175/65 tubless tyres. Earlier i had 185/60.
3) No major issues as such until now. +1
4) No major rattles as such. Rattles few
Cons of the car:
1. Flat tire is major problem. I had this problem some 6/7 times until now. Which tyres are you using? use tubeless. I have till now not used my jack 2-3 punctures was repaired after 2-3 days of noticing the air reducing.
2. Pick-up is not good in hot weather. I donot have this problem get it checked.
3. Some niggle issues, can leave with it. Agree
4. Looks like turbo is gone. Do not feel of it now at all. When the vehicle was new after around 2200 RPM used the feel the turbo turning on. I donot have this problem get it checked.
I donot idle the engine for a minute , however i keep my speed very low within 20-30 kmph for nearly 5 minutes before parking or after starting the car.
kiren is offline   Reply With Quote
Old 1st April 2009, 18:12   #4 (permalink)
greenhorn's Avatar
for the rattles, try replacing the plastic rear parcel tray with a wooden one. will also improve bass effect if you have oval speakers there.
also, wrap some insulation tape around the stub the rear seats latch onto.
check the spare wheel, toolkit and jack and check if they are properly secured. check if the centre stop lamp which is placed at the top of the rear window is not rattling
the pickup in hot weather issue , I've faced it too
__________________
Old 1st April 2009, 20:00   #5 (permalink)
Greenhorn,
I do follow the idling the engine most of the times. Sometimes in hurry just turn-off.
Kiren,
Goodyear tries, which came along with the vehicle. I think it will hold good for another 10K Kms, Which tubeless tires you are using. My plan is to go for tubeless when I go for the tire change.
Old 1st April 2009, 22:46   #6 (permalink)
Originally Posted by srinivasmhn View Post
Greenhorn,
Kiren,
I am using Apollo Acellere 175/65 for the past nearly 30 k Kms & Earlier it was 185/60 Goodyear NCT5 for more than 70 K Kms.
Old 1st April 2009, 22:59   #7 (permalink)
greenhorn's Avatar
kiren, how do the two tyres compare
__________________
Old 2nd April 2009, 10:52   #8 (permalink)
Size wise 185/60 is the best as the drive quality is great. But due to problem with my alloys offset with load i.e 5 people & luggage the tyres were rubbing the suspensions hence had to reduce the width.
Regarding make i really didnt find much of a difference between the two.
Old 28th July 2009, 21:08   #9 (permalink)
Default Indica 40K Kms Report.
My vehicle has completed 40K Kms and rather in a quick time. Had taken the vehicle in Mar 2008. It has given me trouble free service until now without any major problems. Had only a problem with the check light glowing-up. This was fixed during the service and was mentioned that it was problem with potentiometer and was replaced in extended warranty.
I use it everyday for round trip to office for 105 Kms and 80% of the drive is trough highway(NICE road Bangalore) and getting around 16.5 Kms/L. Pick-up is good and have some minor rattles.
Major problem is only with the Flat tires. I had almost around 12 flat tires during this periods and I think this problem will not get solved until the tyre’s are changed to tubeless. I think current tyre’s will hold good for another 10K Kms.
Service total came-up to to Rs 7700/- . Service details is mentioned below and it was serviced at Prerana Motors , Peenya. The service supervisor was good and all the aspects mentioned were taken care.
Bardahl Engine Tuneup 675.47
Dry Sheet 80 12.44
Diesel Engine Oil 1271.11
Transaxle Oil 604.26
WD40 Rusk Leak 22.13
Grease Ball Brearing 8.44
Cotton Waste 11.25
Coolant 600
Assy Oil Filter-TC 141.33
Fuel Filter 134.22
Rubber Boot 31.11
Poly V Belt 314.67
Break Oil 56.89
30GM Wheel Weight 29.55
25 GM Wheel Weight 8.23
15 GM Wheel Weight 5.53
10 GM Wheel Weight 12.53
CA Wiper Blade 311.11
Alternator Belt 200
Nitrogen Air 125
Clean Catalytic Converter 125
Coolant top Up 400
Major Service Labour 650
Break Sytem Check 150
Front Wheel Aligment Check & Adjust 200
Balance Wheel(Wheel Removed) Each 350
Gold Club Membership 460
Tax on Parts 531.29
Serivce tax 266
Total 7707.56
Old 30th July 2009, 07:21   #10 (permalink)
Srinivas,
Looking at your 40K service report, you are totally being ripped off by Prerana motors. Why did they charge you 400 for coolant top up on top of 600 for coolant. Also, it seems like they almost changed everything they could get their hands on.....I also hate dealers who charge for things like "Cotton Waste 11.25". Learn to do things like "CA Wiper Blade 311.11". Its very easy to do.
Theyota is offline   Reply With Quote
Thread Tools
Tata Indica Turbo DLG - 117000 kms report discoverwild Long-Term Ownership Reviews 36 5th August 2009 14:12
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599
