Old 14th October 2009, 12:44   #31
AVR
AVR's Avatar
Thanked: 531 Times
Default Updates
Guys,
Thought I'll update this thread with a few things that have happened in the past few months:
1) Got the Yokohama A/Ts fitted all around and am loving it though have had this strange issue of the A/Ts running into the mud flaps on 3/4th or full turns. the A/T front profile sure is different than the more rounded Ceat Rhinos (H/Ts??) earlier but didn't expect them to be running into the mud flaps either.
2) Had gone to the get the Cat converter cleaned and was shocked to see the completely clogged mesh which must have resulted in major back pressure. Eventually decided to just break it through and what a major difference that has made to the car. Earlier the car needed to be given a raise to get moving in the 1st gear with the a/c on and now it moves comfortably in idle in 2nd with the a/c on!
3) Got a complete Bardahl treatment done starting with the Bardahl Engine Flush and then the Bardahl Oil Additive along with a regular dose of Bardahl Fuel Additives. Am seriously very impressed with the smoothness of the vehicle off late.
4) Got the front suspension overhauled and raised with all bushes and the rubber suspension kit replaced.
5) Shifted to Mobil Delvac MX after hearing a lot of rave reviews on this forum.
6) Tried this magic pills (Viagra as my friend called it) that you add to the fuel - look like a medicine strip by a company called Forever Freedom International. Worked good for me. Has anyone tried it?
ere's the link
Forever Freedom International - MPG CAPS, Fuel savings, green, business
Its interesting how T-bhp has been influencing all my major decisions (tyres, oils etc) over the past few months and am seeing a majorly positive impact on my Safari
AVR
AVR is online now   Reply With Quote
Old 14th October 2009, 13:09   #32
Thanked: 146 Times
Good to note positive changes to your vehicle ride, AVR!
With respect to the CatCon, did you mean that you got it complete removed?
HappyWheels is offline   Reply With Quote
Old 14th October 2009, 13:16   #33
greenhorn's Avatar
Thanked: 1,516 Times
AVR - I'd suggest you try out System D. it is the tata recommended additive
Old 14th October 2009, 15:37   #34
AVR
AVR's Avatar
Thanked: 531 Times
Yes. So basically there's a mesh in the cat con that was just broken through for freeing the exhaust flow. mechanic strongly suggested doing that actually!!
Have used System D before getting the engine flush and I agree its been very good though I've been told through this forum that the OWS product is better. Haven't had a chance to connect with Farhan and get those products over.
Old 30th November 2009, 13:58   #35
ACM
ACM's Avatar
Thanked: 2,888 Times
AVR
Have got the same breakthrough process done with my cat con as well.
Will respond to your PM soon.
ACM is offline   Reply With Quote
Old 1st December 2009, 09:03   #36
sumannandy's Avatar
Thanked: 219 Times
I was having a discussion with a Lucas TVS guy. he asked me not to use System D as it would increase the water content in the fuel and might damage the pump.
Presently I am not using System D. I think my engine runs smoother with BP Hi Speed Diesel. IOC XTRAMile is not bad either.
sumannandy is offline   Reply With Quote
Old 4th December 2009, 13:56   #37
ACM
ACM's Avatar
Actually for a TCIC i think it is capable of handling most modifications to the diesel quite well, the worry is with the 2.2 dicor, so use system D or turbo jet or whatever one feels like. I have tried them all and have concluded that the additive helps in power and effecieny by a factor of about 7-10% and is worthwhile. Normally just go for Turbojet or ExtraMile, after some time do not notice any improvement but the moment I use normal diesel the effecieny drops by the mentioned % and so does power, and next time am back to the premium fluid, the seperate additives are too much of an hassel to both with each time.
Old 4th December 2009, 15:28   #38
AVR
AVR's Avatar
Thanked: 531 Times
Am not sure how System-D can be so damaging to a Fuel pump. I recently shifted to the Bardahl fuel additive and I see a much more positive impact on the drive as compared to System-D or any of the premium diesels.
Old 4th December 2009, 23:38   #39
mercedised's Avatar
Thanked: 177 Times
Hi guys
I am having problem with my Safari, In rainy days the rain water seeps into the car and the next morning i open the car the Mats, all thing on the floor are fully wet.
The water is coming from top upright corner(from near windshield) of the driver side gate Help.
Old 5th December 2009, 02:51   #40
AVR
AVR's Avatar
Thanked: 531 Times
Originally Posted by mercedised View Post
Hi guys
The rubber sealing on the windscreen does give way with time. Even a m-seal solution would be a quick fix for this.
Cheers,
Adi
Old 5th December 2009, 08:20   #41
mercedised's Avatar
Thanked: 177 Times
Cheers,
Adi
Did it happened with you too?
Old 5th December 2009, 09:17   #42
condor's Avatar
Thanked: 4,897 Times
@Mercedised, try Anabond in that area.
Old 5th December 2009, 11:13   #43
sumannandy's Avatar
Thanked: 219 Times
. Even I am not sure if System D can damage the pump since it is recommended by TML.
I think Xtramile/Hi Speed diesel also contains additive to clean the fuel system. Instead of carrying a bottle of System D, I usually fill up with Hi Speed diesel on every alternate trip to petrol pump.
Old 7th December 2009, 15:56   #44
ACM
ACM's Avatar
For the leakage check:
1) If the rubber sealing of the front windscreen has give way, then if the glass shakes when thumped with the fist at various points from the inside- get if refixed and the issue should go away.
2) If the glass is does not shake the beading itself could be leaking though it is fixed well, and the solution would be sealants that the glass fitter keep.
3) Lastly check for rusting on top of the glass shield or on the inside of the A-piller after the door is opened between the windscreen and door beadings. If there is rusting there then this needs to be repaired/ repainted and the front beading refitted / replaced in the process. (I have that issue and am about to get the work done.)
Old 14th December 2009, 13:13   #45
mercedised's Avatar
Thanked: 177 Times
Thanks for your valuable suggestions.
I will post the pictures of water seeping inside car, It will make the problem a bit clear.
Tata Safari TCIC 2,30,000+ km review! mercedised Long-Term Ownership Reviews 334 25th April 2016 14:29
Reclaiming life - My Tata Safari TCIC. 13 years, 1,23,000 kms and counting sumannandy Long-Term Ownership Reviews 163 19th April 2015 07:54
Tata Safari VX 4x4 - Ownership review (at 40,000 kms) himavanth_m Long-Term Ownership Reviews 41 26th April 2012 10:17
Buying a used Tata Safari 2004 TCIC - 3 month report cyberpatrol Long-Term Ownership Reviews 51 13th February 2010 16:47
Safari TCIC 4x4 problem gd1418 Technical Stuff 5 11th July 2008 18:01
