Old 27th April 2010, 22:27   #91
mercedised's Avatar
Thanked: 177 Times
Hey, one question Are your Power windows working fine??
Mine front window glasses comes out of its position whenever they are closed??? The SC guys says that i need to change the window machines?? cost=4500rs per machine ..Any suggestions??
Originally Posted by AVR View Post
No. Not the whole gearbox. There are three shafts inside the gearbox that need to be changed for changing the mechanism. The cost included a complete overhaul while the gearbox was opened up along with new seals, etc.
Always thought the lights weren't good enough.
Our SAFARI has the best light in the whole SUV segment(Halogens). That's my thinking and What is your's after pencil beams are fixed?
Old 27th April 2010, 22:37   #92
AVR
AVR's Avatar
Thanked: 531 Times
Well the Safari Power Windows have a mind of their own. Start working and stop working on their own accord. About it coming out of its position, its more of a glass fitting issue than the motor. I felt that issue on the Expressway once with the noise even though all glasses were closed. When winding them up, try guiding them into the right place as they go up and that should sort it out.
Agree with you now. After the lights were sorted, I love the way the way jerks who drive with high beam switch to low beam when I switch to high. I wish people knew how irritating it is to have cars driving with high beam all the time.
AVR is offline   Reply With Quote
Old 18th January 2011, 21:22   #93
AVR
AVR's Avatar
Thanked: 531 Times
Default 125,000 Kms!
Last 8-9 months with the entry of the Jeep, the Safari has taken 2nd priority in terms of expenses so last week decided to do some TLC for the Safari in time with its planned service.
Things done since last update:
Late Summer of 2010
1) A/C compressor conked off: Well a new one seemed to cost a lot so the good ol' scrapyard came to the rescue. I learnt a very interesting thing while trying to wiggle a guarantee out of the scrap dealer. Basically, compressors bought from them have no guarantee but usually work. He had this to say: "Chalein to chand tak, warna shaam tak" i.e. If it works it works till the moon (forever) else it wud last just one day. With such a reassurance I got it fitted and voila its still working! - Cost ~ 5500 for compressor
2) Ordered a new black centre console + both door + rear + centre a/c vents + gear cover for about 2500 bucks from Mumbai thanks to a contact given by ACM. Car looks much neater than it was few years back!
Oct 2010
1) Changed disc brake pads after a screeching sound that came one day. Simple job.
Hassle free operation apart from the whistling sound that continues to bug.
January 2010
Issues:
1) Driver on an overnight drive ended up driving without clutch oil for about 300 km due to some leakage in the base of the slave cylinder. Resulting in a totally fried clutch plate with significant loss of pickup. For the time, changed the slave cylinder but mechanic was unwilling to change clutch plate but have not been enjoying the drive though it does move normally in idle (~750 rpm) in both 1st and 2nd. Should try the 5th gear test before replacing it.
2) Engine oil filler cap came off (must haven't put the cap on tightly) and it threw up all the engine oil. Don't know how he managed that but luckily stopped the engine and put enough oil to get to garage
3) Whistling sound has aggravated and now its been traced to a leak in the exhaust. Yet to solve this problem.
4) At around 3000 rpm in 2nd or 3rd there's a screeching sound when you are pushing the car hard. What could it be? I don't hear it when in 4th/5th when gradually picking up pace. Clutch issues? If engine, it should make noise in all gears right??
5) Engine oil changed (Mobil Delvac MX) along with filters at roughly 15k interval.
6) Also put a gear additive from Wynn as gear changes for the first minute post start were extremely tough. (Probably a thinner gear oil would help?). For the time, the additive seems to have worked but does anyone face this issue too?
TLC:
1) Bumpers have been regularly interacting with other vehicles on the road and had started hanging so went and found bumpers from the scrapyard and painted them and got them fitted. Safari looks awesome again with new bumpers and also new tail lights (old style, don't like the dicor taillights). Will post interior and exterior pics soon!
Cheers,
Adi
@Mods - Please update to title to 125,000 Kms from 110,000 Kms.
Old 19th January 2011, 07:47   #94
condor's Avatar
Thanked: 4,895 Times
AVR : 1) A/C compressor conked off: Well a new one seemed to cost a lot so the good ol' scrapyard came to the rescue. Cost ~ 5500 for compressor
A scrap-yard sourced A/c compressor costs that much ?!!
AVR : 4) At around 3000 rpm in 2nd or 3rd there's a screeching sound when you are pushing the car hard. What could it be? I don't hear it when in 4th/5th when gradually picking up pace. Clutch issues? If engine, it should make noise in all gears right??
1. What rpm are you at when you shift from 4th to 5th ?
2. If you shift from 4th to 5th at 3000 rpm, what speed are you at ?
(I change gears late, but 3000 rpm is still pretty high. Esp for a 4th to 5th change .. )
AVR : 6) Also put a gear additive from Wynn as gear changes for the first minute post start were extremely tough. (Probably a thinner gear oil would help?). For the time, the additive seems to have worked but does anyone face this issue too?
Do you warm up the engine after a cold start & before moving ?
Old 19th January 2011, 10:58   #95
AVR
AVR's Avatar
Thanked: 531 Times
Default Re: Tata Safari 2004 TCIC EX 4x4 110,000 KM Ownership Review
Well the peak summer did reduce my bargaining ability plus this guy is THE compressor guy in town so he refused to go down. Started at 6500!
I usually change gears at much lower speeds (~ 2-2.5K) but every few days I prefer to give it a high-rev drive just to understand if things are working
fine or not .
Today morning again I revved it while standing and sound wasn't there but while driving the sound did appear. Actually I had the opposite problem in my Tucson last month when the clutch plate was on its last legs. At lower rpm gear changes there was a lot of clanking noise which went after clutch change. The Safari has the opposite.
I give it about 15-30 secs of idling but not more. Actually the hard shift has reduced post additive + new gear oil (90 grade?)
Old 24th January 2011, 19:07   #96
mercedised's Avatar
Thanked: 177 Times
Default Re: 125,000 Kms!
Please Give me the details too. My car needs the console overhaul.
Oct 2010
The TURBO whistle is there in my car too. It is from a very long time (probably 50,000kms). No problems till now.
January 2010
Issues:
That's exactly the problem I faced a few days ago. The slave cylinder developed a leak. But, I quickly figured it out and drove home by topping it for every 10-15kms. Replace the clutch plates only if you are experiencing any clutch issues.
Where is the leak EXACTLY??
Yes, might be a clutch issue. BTW, I hear a ghrrr. ghrrr sound which is due to clutch while in 1st gear and car moving in IDLE, this is also from a long time but no problems faced.
I change at every 7.5-8K kms STRICTLY.
(This is recommended by TATA)
Yes, same behaviour from my Safari too. Infact for the first 1-2 kms it is very hard to shift to 2nd gear, I have to try 4-5 times till it engages. Again no problems faced due to this issue till now. But, I will try the additive certainly.
TLC:
Please post the pictures soon. I'm hungry.
Also, from where did you source the old type rear lights? And how much?
Cheers,
Adi
Answers in BOLD.
BTW, the Safari just got its oil change at 2.25Lkms (today), alongwith RPM setting to 750rpm at Idle.
Old 24th January 2011, 19:48   #97
condor's Avatar
Default Idling & revving
Started at 6500!
Wow ! What's the cost of a new one ?
Btw, a/c must be used atleast 5 minutes every month. Many of us dont do that also.
.. but every few days I prefer to give it a high-rev drive ..
min 3k rpm for 30 secs every week or two. Helps clear the exhaust system.
Pls do a 1 minute idling atleast in the morning, 30 secs later during the day.
Old 24th January 2011, 22:31   #98
AVR
AVR's Avatar
Thanked: 531 Times
Default Re: Tata Safari 2004 TCIC EX 4x4 125,000 KM Ownership Review
The place is Sunco Motors and they'll do cash on delivery
Sunco Motors - TATA parts shop at Opera house Mumbai:
+91-2223894602 / 2223876850
Just the black centre console frame is 1000 bucks but with all the switches etc its about 6k
Cost me about 700 each so ~ 1400 bucks. I can check if you want them. Else you can check with Sunco when you talk to them.
As per the price list compiled by IBM_Jennifer its 27k! so mine seemed to look like a good deal!
Thanks! Will keep it in mind.
Performance is sluggish and am hating it but am caught up with some stuff so can't get around to taking it to the garage.
Cheers,
Adi
Old 25th January 2011, 08:39   #99
mercedised's Avatar
Thanked: 177 Times
Thanks. I want to order the Centre vents and the middle vents. Everything else seems fine.
Oh yes. If you could find 2 extra it will be a great pleasure. Try if you could get.
Might be that you are not using correct grade of oil. I'm using Shell HX6 currently in Safari. Earlier I used Castrol GTX 15w40 Diesel with change interval of 8000kms.
Cheers,
Adi
Answers in bold.
Have you got the AC serviced? I have tried a few times but did'nt got time to leave the vehicle for cleaning purpose. Any idea about AC system servicing. Although the AC cools like charm without any overhaul too. But, I am thinking of cleaning as the AIR flow control system is not working (no functioning by buttons, I have to do it manually from the dashboard dickey). The heater knob also needs tobe controlled from under dashboard dickey.
Old 25th January 2011, 11:03   #100
AVR
AVR's Avatar
Thanked: 531 Times
Answers in bold.
You bring up a good point. Since its winter time haven't used the AC but I was trying today and while I could hear the blower running at full speed, the air flow system seems to have again messed up. I tried fixing it from left-side behind the centre console but its not helping. will have to get it checked. I did get the AC serviced when I changed the compressor. Made a lot of difference to the cooling.
Will check about the lights and let you know.
Cheers,
Adi
Old 25th January 2011, 11:39   #101
mercedised's Avatar
Thanked: 177 Times
Cheers,
Adi
For fixing it you will have to open-up the left front DICKEY. Then, there are 2 levers one for heater and other for air flow control, this is the only way to control flow if your knob-cables have messed up (which is the case with my car) . If you want I could post the pictures.
Old 25th January 2011, 21:46   #102
AVR
AVR's Avatar
Thanked: 531 Times
Have an idea but would be great if you could post pictures
Old 9th March 2011, 16:44   #103
AVR
AVR's Avatar
Thanked: 531 Times
Default AC Thermostat removed!
Last whole week my AC acted funny. All the wiring had been checked but on a purely random basis the AC clutch would not engage and hence no cooling would happen. After rechecking the wiring we started looking for any issues inside the dashboard. Now there's a thermostat in the AC which was acting up and cutting off the compressor resulting in no cooling.
To circumvent that we decided to just bypass the AC thermostat.
Result: Never had a more cooler AC!
Now What can be the damages? I don't think there could be issues on short runs but on a long trip with AC at full blast for 400+ Kms, how would it negatively impact the vehicle?
Old 10th March 2011, 04:25   #104
sumannandy's Avatar
Thanked: 219 Times
That's interesting. We should have a bypass switch which when activated would completely bypass the thermostat and would keep the AC always on
sumannandy is offline   Reply With Quote
Old 6th May 2011, 16:04   #105
AVR
AVR's Avatar
Thanked: 531 Times
So there was this whistling sound that had been continuing for a while and got louder by the day.
For the last week, thanks to the above problem aggravating, I don't reach anywhere but I make a loud entry that can be heard from a mile away
Well, finally traced it to the flexible joint that joins the exhaust pipe to the engine. It is flexible to allow for some level of movement. Need to get it repaired.
Small Joys of Life: Had taken some kids in the family for a joy ride to the riverbank. Decided to eventually cross it and water came inside the car but no issues except that the 4wd switch acted up and ended up crossing it in 2wd with some rather anxious moments. Nevertheless was a lot of fun! I guess I just introduced some young kids to their first OTR. They were so excited!! Nevertheless, I hate electronic transfer cases!
Tata Safari TCIC 2,30,000+ km review! mercedised Long-Term Ownership Reviews 334 25th April 2016 14:29
Reclaiming life - My Tata Safari TCIC. 13 years, 1,23,000 kms and counting sumannandy Long-Term Ownership Reviews 163 19th April 2015 07:54
Tata Safari VX 4x4 - Ownership review (at 40,000 kms) himavanth_m Long-Term Ownership Reviews 41 26th April 2012 10:17
Buying a used Tata Safari 2004 TCIC - 3 month report cyberpatrol Long-Term Ownership Reviews 51 13th February 2010 16:47
Safari TCIC 4x4 problem gd1418 Technical Stuff 5 11th July 2008 18:01
