Closed Thread
Old 2nd September 2009, 23:24   #151
ph03n!x's Avatar
Thanked: 118 Times
Originally Posted by krish3 View Post
Good to hear that it wasn't anything with the tires or any other component. But, how did this happen in the first place?
Well, 5 average sized people in the car- doing about 120 - 140 KMPH to Cuddalore. GST on the way to, and ECR on the way back. The road that connects GST with Pondi after Tindivanam is not a great stretch and I was doing 80 - 100, until the car landed kinda hard after crossing a culvert. Nothing seemed to be wrong, we reached Cuddalore.
On the way back, right when exiting Pondi I started hearing scraping noises, panicked. Saw tire fragments cut, but hanging on to the tire and rubbing the arch. Removed all the fragments- and then the sound of the wheel fouling the arch was pretty well audible at each contour of the road...
Hopefully it is fixed now!
ph03n!x is offline
Old 2nd September 2009, 23:51   #152
Was it a manufacturing defect that caused this.
Shyam
ShyamSCrdi is offline
Old 3rd September 2009, 00:00   #153
kpzen's Avatar
Thanked: 1,599 Times
Originally Posted by ph03n!x View Post
UPDATE:
Had been to Hyundai on Monday (31st Aug). The wheel arch's inside top was bent towards the tire. This was set right and touched up. Tried the car at a considerably bad/ steep slope within the service center with 6 people (6!!) onboard, and it doesn't foul anymore.
Fingers crossed as of now- my next highway roundtrip should tell...
Glad that it was the just the wheel well.
btw how did it get bent ?
kpzen is online now
Old 3rd September 2009, 00:39   #154
ph03n!x's Avatar
Thanked: 118 Times
Shyam
Dont think so- the wheel arch's metal part was bent towards the tire- cant be a manufacturing defect, something else that I did :(
Not sure yaar. What the Hyundai people guess is that maybe a stone or small piece of wood (you get the idea) revolved around with the tire and hit the arch - but I cant see how the dent is towards the wheel, not away. One of those mysteries?
ph03n!x is offline
Old 3rd September 2009, 10:31   #155
krish3's Avatar
Thanked: 15 Times
Hopefully the mystery won't be back again. Doing 80-100 in that bad stretch is a bit too much. I had been that way on my bike and I had to keep the speeds lower in the stretch. Surprised that they haven't smoothened the roads as yet.
krish3 is offline
Old 12th September 2009, 21:20   #156
ph03n!x's Avatar
Thanked: 118 Times
Default Pampering day for the rocket!
I have been planning this day for a while now- and so I started off at 11 and headed to Tyrestore. Agenda?
1) Tyre rotation
2) Put the 5th (unsed) alloy instead of the one that fouled (I know, but just a try )
3) K&N Stock Replacement filters!
Was there till about 2 or so, and was nice meeting Pras.oct25 too!
After Tyrestore, called up D'BHPian Nitrous seeking help on upgrading her eyes to a 100/90. And headed to GP Road, and got Roots wiring harness & relay, and Philips Rally 100/90 bulbs.
Headed straight to IgNite, and met Raghav. Agenda here:
1) Mobil1 Delvac MX engine oil
2) Upgrading the headlights
3) Washing the car
Total spend-
K&N Filter- 4500
Rotation, Balancing and Alignment- 900
Harness, Relay & Bulbs- 850
Mobile1 Delvac MX 5.3 Litre- 1298.50
Monday is going to be yet another day for her- Original Fog Lamps from Hyundai
I have had a chance to really ride her as I would like, thanks to traffic, but the car is as smooth as always. There is a change in the engine note due to the K&N, and it sounds more eager...
A Question- those who upgraded to 100/90 in a rocket, how did u wire the harness? There is a sealing cover to the headlight, are u still using it? Or did you bore holes in it, and sealed the holes after passing the wires through them?
ph03n!x is offline
Old 12th September 2009, 21:47   #157
JayD's Avatar
Thanked: 1,996 Times
Be careful while drilling those covers, if not done properly, water will enter the light assembly while washing/rains.Am facing the same problem with my i20, so wondering whether to upgrade or not. I've seen more than a few i10's with waterlogged headlamps!
JayD is offline
Old 12th September 2009, 22:41   #158
krish3's Avatar
Thanked: 15 Times
Why dont you try Osram Nightbreakers? I replaced the stock on my Getz D with Osrams of same rating (60/55 W). The lighting is superb now and low beam is now enough for most conditions. Drove in rain yesterday night and the lights were enough.
krish3 is offline
Old 12th September 2009, 22:47   #159
The osram nightbreakers, are better than stock, but not as effective as 100/90 (Obviously!). Its kinda expensive( for a 55/60) too right?
johnjose70 is offline
Old 12th September 2009, 23:59   #160
ph03n!x's Avatar
Thanked: 118 Times
Right now I am worse off- that cover is lying in my dash!! Will take it up next weekend with Raghav and see whats the best that can be done...
The lighting with the 100/90 is perfect, no probz at all. The headlight's cover gets hot (real hot!), but I guess (and hope) it wont melt off!
ph03n!x is offline
Old 13th September 2009, 00:42   #161
pras.oct25's Avatar
Thanked: 7 Times
Can someone tell me the diff. between K&N and green cotton? Phoenix's getz sounds like it has a pretty angry monster residing under the hood. Man the noise that thing makes.
pras.oct25 is offline
Old 13th September 2009, 00:59   #162
ph03n!x's Avatar
Thanked: 118 Times
O yeah- there is a marked difference in the way the engine sounds. A bassy note of air getting in is getting added to the diesel clatter. That's normal with K&N?
ph03n!x is offline
Old 13th September 2009, 07:29   #163
undead's Avatar
Thanked: 165 Times
dude , if you are looking for better vision for night driving , you got try mine..
Those Hella Spot Lights are focussed directly on the road and it gets switched ON only on High Beam . On Low Beam , only the Head lights will be ON. I do have a control switch where i can turn it off or on fully .
Letz Getz Started (Hyundai Getz CRDi)- UPDATE: 40000, new alloys, tires!!! (page 30)-dsc00234.jpg
undead is offline
Old 13th September 2009, 13:07   #164
ph03n!x's Avatar
Thanked: 118 Times
But what about low beam visibility? The stocks do you justice? What I got now seems be fine- let me take a highway roundabout and let you know!
Howz the read giant, btw?!!
ph03n!x is offline
Old 13th September 2009, 14:05   #165
hellstar's Avatar
Thanked: 17 Times
Wiring is a breeze agreed , but my friend arent those blocking the air intake to your engine bay , i for one would not want to deprive my engine if even 5% of what its currently getting by installing after market fog light like that.
K&N and green cotton , i hear the air output of green cotton is slightly better than K&N, Peter gave me some reasons for it , actually he recommends the GC Stock replacement filter with the Petes box. What i personally found was that K&N is more widely available , with respect to the availability of the cleaning kits , K&N was better
yeah, i know and that's pretty sporty too , but sadly gets on the nerves of my family , so had to pull it out !
Yeah , try my headlights after a 1 hrs drive with the 130/110W on high beams .Sometimes me thinks in an urgent situations i can makes dosas on them
And about the dust covers , better put them back on as soon as possible , and dont allow the installers to cut it , cutting it kills the entire purpose of the dust cover and will damage / fade you reflectors in the longs run [experience speaks]
hellstar is offline
Closed Thread
40000 km = 80000 km. 2007 Verna CRDi. Got cheated, Now sold. sarthakgupta Long-Term Ownership Reviews 39 5th November 2014 17:21
My Red Pimento - Maruti Swift Vdi Euro IV review - 40000 Kms update ontheroad Test-Drives & Initial Ownership Reports 19 9th June 2013 20:01
The future of Hyundai Getz? EDIT : Bye Bye Getz (page 2) sathya_j2084 The Indian Car Scene 32 25th June 2010 10:19
Query : Tubeless tires / Normal Tires nicejits Tyre & Alloy wheel Section 12 10th June 2009 09:59
Verna Crdi Vs GetZ Crdi. EDIT : Finalising on Getz! aks_karthik Hatchbacks 74 17th May 2009 10:22
