Closed Thread
Old 23rd April 2011, 22:32   #451
Thanked: 41 Times
Default Re: Letz Getz Started (Hyundai Getz CRDi)- UPDATE: 40000, new alloys, tires!!! (page
well the reason i ask is because Abhishek from Kiirus had mentioned me to do the same as my car is suffering from excess smoking after the kiirus remap, initially i thought it was it was the piper cross airfilter & the engine oil, replaced the air filter with a Bosch 1, and changed the engine oil to Shell Remula 4, put he problem still persists although not as much as before.
Could it be signs of Turbo failure, what measure should i take as the car is still under warranty for another two months.
Ravenblood is offline
Old 23rd April 2011, 22:49   #452
kpzen's Avatar
Thanked: 1,655 Times
How many kms have you done ?
Warranty after remap ?
kpzen is offline
Old 23rd April 2011, 23:09   #453
ph03n!x's Avatar
Thanked: 120 Times
Got the call by 5:30 PM, and headed to the service center with the precious Mobil Delvac 1 can. The check-list:
  • Change fuel filter cartridge - Done
  • Replace Engine Coolant (as suggested by the user manual) - Done
  • Replace Brake & Clutch Fluid (as suggested by the user manual) - Topped up
  • Check clutch play and bleed it (depends on the previous item too) - Done
  • Replace engine oil filter, I will bring in the oil when I come to collect the car - Done
  • Check the mild squeaking sound that comes from the steering when the car is cold - Done, but can't confirm until tomorrow morning
  • Check the screeching noise I get from the front right brakes when the car is cold - Done, but can't confirm until tomorrow morning
  • Check the dashboard, door and panel rattling - Done
  • Realign the rear bumper - Done, but needs a lathe work later.
  • Fix the lower lip of the front bumper (scrapped it, and managed to dislodge the left side) - Temporarily fixed, need the nips to hold it in place. Will arrive in a few days.
  • Inter-cooler and EGR Cleaning - I was told EGR was not required so early, maybe at 60k. Inter-cooler was apparently cleaned, but I don't see a separate charge for it - said to be covered in PMS?!
What else?
  • Transmission oil - Changed. This is not really something I wanted, but I did ask about the 30k change interval mentioned in the service chart
  • AC Blower Motor cleaning - Though the AC was fine, I did hear a mild burrr sound in addition to the fan's sound (The AC filter was washed clean a month or so back).
The cost break-up:
  • Transmission oil - 2.5 liter - 527.75
  • Coolant - 2 Liter - 426.60
  • Filter Cartridge - 1275.46
  • Oil Filter - 334.02
  • AC Blower cleaning - 110
  • Periodic Maintenance Service - 770
Total - Rs. 3855 (Including 12.5% VAT on parts and 10% Service tax on labour).
The Verdict:
I drove the car from the Service Center to my regular fuel station, topped up (Low fuel warning came on just when I was about to enter the station!) in bumper to bumper traffic. I too got the usual low noise, feels smooth, responsive feeling, but I do not know yet if its placebo or not until I drive it like it deserves to be - on the highway. The clutch feels better though, but the 3rd gear @2k RPM is still 50 KMPH.
There were no charges for the brake / clutch fluid, and bleeding was said to be covered in the PMS - not sure what was done and what was not. I had disconnected the fresh-air / recirculation cable, setting it permanently in recirculation - this was connected back.
One other thing - the mileage has steadily dropped, and has come to 12.9 KMPL for the last tank-up . Took the car to the garage, promptly disconnected the fresh air / recirculation cable behind the glove box, and tied the control lever in closed position. Have disconnected the battery terminals - will leave them disconnected overnight. Will clean my K&N and let it soak in tonight before taking the car out.
Let me drive around for a few 100 KMS before I comment on the new tires, and the new oil. Also, the mystery of 90 @ 2000 RPM in 5th vs. 100 @ 2000 RPM in 5th remains.
Mileage:
The car has consumed 727.50 Liters of Diesel for the last 9900 KM, at an average of 13.61 KMPL. Cost per KM works to 3.02 bucks.
ph03n!x is offline
Old 23rd April 2011, 23:53   #454
Thanked: 41 Times
As of two just over 40K about 10K after remap.
my car will complete 2 yrs somewhere in july, so incase it is premature turbo failure i want to get it check before the warranty lapses, according to kiirus the remap is undetectable by the scanners
Old 24th April 2011, 12:18   #455
kpzen's Avatar
Originally Posted by ph03n!x View Post
What else?
The cost break-up:
Phoenix.
Thats an interesting oil changes you have done.
Engine Oil - Mineral -> Synthetic
Gear Oil - Synthetic -> Mineral
I think you are the 1st one among the Getz Crdi owners to use synthetic grade. Will wait for your detailed review on that.
Also, waiting for your views on C drives.
I'm only 10k kms away from my second tire change.
BTW, this car can only take 2L of gear oil.
Even the manual says 2L. In my car it started spilling at around 1.9 L.
Haven't heard of any turbo failures in Verna around 40k mark.. It has a very robust turbo.
Have you seen any drop in oil level ?
kpzen is offline
Old 24th April 2011, 15:29   #456
ph03n!x's Avatar
Thanked: 120 Times
Phoenix.
That was something I didn't ask them to :( Will switch back to Synth for gear oil by 60k / 70k. The gear feels a bit notchy when coming back to second and first while the car is in motion. I am looking for Synthetic gear oil from outside, my A.S.S says they have never had the synth gear oil from Hyundai in the past 5 years!
The car does seem responsive, and sounds smoother at idle - but I am still,l reserving the verdict - let me do a 1000 KM, and then I will know for sure - especially awaiting a highway run in a couple of weeks.
Here is a quick review, with the C.Drives now being 625 KM old on the car. Comfort is definitely much, much better considering I moved down from S.Drives on 15" to this. Major difference is that I drive faster than before over uneven roads, when I had to slow down with the S.Drives - hope this does not amount to abusing the C.Drives and get me their infamous bulges!!
For city speeds as well as for speeds up to 100, the C.Drives are pretty grippy for braking - no wheel locks in spite of me being a late braker. I will reserve my verdict on the highway handling and high speed braking in a couple of week's time.
Wet grip is amazing - definitely better than the S.Drives. It rained her for the last couple of days, and the roads were wet, slippery and water logged. Whenever I hit a patch of water, I was expecting the tires to aquaplane like the S.Drives did, but nope - goes smoothly over water patches so much that I am confident enough to cross water patches without slowing down like I would with the S.Drives. Wet braking is good too, though I never got into a "situation".
Interesting. The quantity says 2.5, not sure if it is liter or something else. But whatever it is, 2.5 seems suspicious. This might be my last service as an A.S.S, what with my warranty expiring in in June mid.
ph03n!x is offline
Old 25th April 2011, 10:30   #457
pras.oct25's Avatar
Thanked: 7 Times
Jayanth what was the reason given for steering squeak and brake screech?
3900 bucks for 5 litres is pretty cheap isnt it? I thought it generally works out to 1k per litre.
pras.oct25 is offline
Old 25th April 2011, 11:54   #458
headers's Avatar
Thanked: 464 Times
Lubrication or the lack of it!!
OT?
@Pras.Oct: Can you please get me Shell Rimula xxx 1 barrel as a gift? My Birthday is around the corner and I AM your friend!!
headers is offline
Old 25th April 2011, 12:16   #459
pras.oct25's Avatar
Thanked: 7 Times
Originally Posted by headers View Post
OT?
So you need just the barrel or the contents too?
pras.oct25 is offline   (1) Thanks
Old 25th April 2011, 18:12   #460
ph03n!x's Avatar
Thanked: 120 Times
I didn't ask about the squeaks, and thanks for reminding - will have to check if they are still there! yup, the oil is priced pretty nominally - only thing is that is not available in Chennai yet.
OT?
Mr. Thalai's, so WTPT for your B'day eh?!!
ph03n!x is offline
Old 25th April 2011, 18:36   #461
headers's Avatar
Thanked: 464 Times
I didn't ask about the squeaks, and thanks for reminding - will have to check if they are still there! ...
Jayanth: So are you gifting me 1 Barrel Shell "Rimula whatever"..My 540 is making too much of a racket and i need the best oil to shut it up!!
@Pras.Oct.25: You can gift me whatever you feel like. But just ensure I get money to settle your dues!!
headers is offline
Old 25th April 2011, 19:09   #462
ph03n!x's Avatar
Thanked: 120 Times
I have a better idea than that - Switch it off and give me the key! I will enjoy the music whenever..!
ph03n!x is offline
Old 25th April 2011, 19:55   #463
headers's Avatar
Thanked: 464 Times
Anytime..I'll PM you my bank details
headers is offline
Old 29th April 2011, 12:28   #464
ph03n!x's Avatar
Thanked: 120 Times
Here is an update on the 5th gear / 2000 RPM - 90 KMPH or 100 KMPH issue.
After vdrive, kpzen and I exchanged this, I had a few sleepless nights thinking my clutch is slipping - more so because the car was driven by a few ladies whom I know drive right out of driving schools and ride the clutch (yes, all of them!) in the family, and it was 3000+ KM when I got back after my Philippines assignment. But that was when the car was ~15k KM old, still I was wondering if that would have an effect. I was more or less sure it can't be my driving coz I hardly use the clutch except for gear changes.
I collated the 2000 RPM data for a bunch of Getz CRDi on the forum (as well as Prasanna's Verna CRDi) to see how it looks - I was initially wondering if the later Getz / Verna CRDi had shorter gear ratios, but does not seem so. Here is is what I have:
Letz Getz Started (Hyundai Getz CRDi)- UPDATE: 40000, new alloys, tires!!! (page 30)-timings.jpg
Looks like Prajesh (kpzen) is the only Getz CRDi with the different timing, and vdrive seems to have had a similar timings earlier, but now has fallen back to majority. In fact I have posted in June 2009 (Letz Getz Started (Hyundai Getz CRDi)- UPDATE: 40000, new alloys, tires!!! (page 30)) that 100 KMPH comes in about 2200 RPM, and 120 KMPH comes up in 2500 RPM - the car was brand new, with less than 300 KM on the clock then.
Prajesh, what mod did you do?? Open up now, you owe me for all the sleepless nights!!!
Shouldn't I be giving you my bank details to offload you of your off-road burden??!
ph03n!x is offline   (1) Thanks
Old 29th April 2011, 13:04   #465
headers's Avatar
Thanked: 464 Times
Simple, His tyre OD must me higher than yours, else it is not possible!!
headers is offline
Closed Thread
40000 km = 80000 km. 2007 Verna CRDi. Got cheated, Now sold. sarthakgupta Long-Term Ownership Reviews 39 5th November 2014 17:21
My Red Pimento - Maruti Swift Vdi Euro IV review - 40000 Kms update ontheroad Test-Drives & Initial Ownership Reports 19 9th June 2013 20:01
The future of Hyundai Getz? EDIT : Bye Bye Getz (page 2) sathya_j2084 The Indian Car Scene 32 25th June 2010 10:19
Query : Tubeless tires / Normal Tires nicejits Tyre & Alloy wheel Section 12 10th June 2009 09:59
Verna Crdi Vs GetZ Crdi. EDIT : Finalising on Getz! aks_karthik Hatchbacks 74 17th May 2009 10:22
