Go Back   Team-BHP > Indian Cars > Team-BHP Reviews > Long-Term Ownership Reviews
Long-Term Ownership Reviews Ownership reports, of Indian cars, spanning over several years and thousands of kms
Thread Tools
Old 23rd June 2009, 22:12   #1 (permalink)
Nan
Default Hyundai i10 catches fire during ignition!
Here is a strange incident that happened to my friend. When he turned on the ignition of his 10 month old i10 to start the engine, a strange sound was heard from under the hood and the car caught fire immediately. He managed to get out of the car and put out the flames just in time. The intensity of the fire was such that the whole engine compartment has been burnt out and the boot lid has warped due to heat! The car was under warranty and was taken to Trident Hyundai service station to ascertain the cause for the problem. This matter was reported to HMIL and they sent a representative from the company to inspect the car. After inspection it was told that a 'rat bite' on the fuel pipe had caused the fuel pipe to leak leading to a fire! The whole engine compartment has been burnt and all the hoses are damaged and the claim by the company that a rat might have bitten the fuel pipe is inconclusive. Since this is not covered under warranty, my friend has been told by the company to claim insurance for the repairs. Estimate for the repairs is approx 1.15 lakhs! Since most of the parts damaged are plastic and rubber, insurance company will pay only 50% of the amount!
The question here is whether the argument by the company that the fuel leak was caused by a rat bite valid? or was it due to a manufacturing defect? Since the car is under warranty, should he contemplate legal action?
Nan is offline   Reply With Quote
Old 24th June 2009, 04:16   #2 (permalink)
satyamenon's Avatar
Unless HMIL can prove it was a rat bite, I doubt they can pass it off as such.
__________________
Horn not working ! Watch for finger !
satyamenon is offline   Reply With Quote
Old 24th June 2009, 05:55   #3 (permalink)
Nan,
This is an unfortunare incident. How can the engine room catch fire if there was fuel leak because of a fuel leak ,that too by a rat bite on the fuel pipe? Your friend should have smelled the leaking before starting if at all it was that big a leak. There should have been enough fuel that leaked into the starter or plugs so that the electric spark could ignite it. How did the hyundai engineer prove that it was because of rat bite? was there any solid evidence?
Can you describe what all your fiend did after he saw the fire, maybe we can investigate the reason from what he saw and did.
Anyways how can a full engine room go into flames just after the start, it can be a problem with fuel injection system.
decode is offline   Reply With Quote
Old 24th June 2009, 10:04   #4 (permalink)
Ramsagar's Avatar
This is big disadvantage of Hyundai vehicles.
many of the parts,Front member,even the radiator is also made of fiber,hence the insurance claim would not fetch much.
Guess he need to shell out app. 50k to bring out the vehicle.
__________________
CAUTION!!!All the nuts in my car are tight,except the one driving it...Obsessed with CARS since 1981.
Ramsagar is offline   Reply With Quote
Old 24th June 2009, 10:43   #5 (permalink)
NetfreakBombay's Avatar
I think fuel lines are not made of plastic / fiber. Then how could Rat chew them in the first place?
Old 24th June 2009, 10:59   #6 (permalink)
Even if they are made of Plastic/Fibre or Rubber, they should be hard enough to sustain an impact on accident so that fuel cannot spill much to cause fire.
I cannot digest that a 1/2 inch thick rubber pipe can be damaged by rat. If its true than HMIL should be questioned for supplying such a low quality fuel pipe.
__________________
Shabbir
Honda Aviator March 2009
WagonR Nov 2007
Dad's Bajaj Super 1996-2004
shabahmad is offline   Reply With Quote
Old 24th June 2009, 12:59   #7 (permalink)
Rat Bite !
I find this very difficult to digest. Do investigate if they (HMIL) have any such history of incidence in past .. or it is just their standard answer to get away with warranty.
idea1979 is offline   Reply With Quote
Old 24th June 2009, 13:09   #8 (permalink)
I think i know the reason for this. During the last free service of mi i10 auto, the service centre added a fuel line cover/guard free of cost. On enquiry they said it has been installed on all i10 kappa on instructions from the company.
I think we know the reason of the fire now.
sharad_agl is offline   Reply With Quote
Old 24th June 2009, 21:02   #9 (permalink)
Nan
Originally Posted by decode View Post
Nan,
He said that once he started to crank the engine, the was a noise from under the hood and the fire started immediately. He got out and tried to open the hood but could not do so due to the heat. Then after pouring buckets of water, the fire came down and he opened the hood to find everything burnt. I will post some pictures. Maybe that will give you an idea of the extent of damage.
Even i think that this reason given by HMIL is too far fetched to believe. There must have been some trigger for the leaked fuel to catch fire. Also, the fuel pipe is a steel braided rubber hose made to withstand high pressure and cannot be bitten by a rat easily.
I think there was some issue with the fuel line which the company realized later and took the necessary steps to correct it. This might be a good point to question.
Also when my friend was in the service station, an other i10 was also present with the same problem, but in that case there was only a fuel leak, not a fire! They were trying to pass this off also as a 'rat bite' issue!
Old 25th June 2009, 00:34   #10 (permalink)
f1fan's Avatar
Rat biting a fuel pipe which leads to a fire? I dont believe it. As we all know Manufacturers and Insurance folks try to pass the buck across.
f1fan is offline   Reply With Quote
Old 25th June 2009, 01:25   #11 (permalink)
Parm's Avatar
I smell a Rat in Hyundai's assesment of the cause of the fire!
__________________
Go with the Flow.....Free Flow!
Parm is offline   Reply With Quote
Old 25th June 2009, 01:29   #12 (permalink)
AbhiJ's Avatar
IMO your friend should turn the tables on Hyundai
He should get in writing from them their statement about reason of fire and then threaten to go public about this inherent safety flaw in the i10, which is potentially life threatening to all occupants. If he creates enough noise, Hyundai is bound to change their stand, since they cannot afford "badnami" in today's competitive hatch market.
AbhiJ is offline   Reply With Quote
Old 25th June 2009, 02:37   #13 (permalink)
I am with you Abhij.
You are right. This is crap. Question them. We should not be buying such nonsense (so called) investigation and that too from the Hyundai engineer. Are these people educated on the technical aspects of the car to are they trained how to fool customers with stupid answers and make them accept whatever they say.
Nan,
Take pictures from all angles and post it in on this site. Ask your friend to contact Hyundai customer care through phone and mail. Keep a record of all communications ..in and out.
I am sure that it is sure smelling a rat in this incident. By the way, has your friend fitted any extra electrical accessories or a gas kit ? Where there any modifications done? If at all they were fitted un-proffesionaly,we should not be blaming Hyundai.
Old 25th June 2009, 02:37   #14 (permalink)
devarshi84's Avatar
Check it there are fuel marks where he parked the car. If the fuel leaked, the ground should smell of fuel even after the fire.
Also your friend should charge hyundai for providing such low grade stuff. Ask them to prove it was due to rat bite.
2 points deducted from hyundai's kitty on my list of trusted brands.
__________________
-The Boyracer
2000 Suzuki WagonR VX
2003 Mitsubishi Lancer SFXi (soundstream ICE)
2008 Suzuki Access 125
devarshi84 is offline   Reply With Quote
Old 25th June 2009, 02:39   #15 (permalink)
Ravveendrra's Avatar
Default Oh rats!
A rat bit through a pipe and the car spilled enough fuel to burn the whole engine bay?
Sounds unlikely. A rat bite might let fuel drip and the drops will evaporate. It looks like a pipe burst or the fuel in some part or pipe exploded.
If the rat bite theory is true, Hyundai needs to re-look at their designs and stop putting such fire hazards on our roads.
If the car was cold, I wonder how the spilled fuel caught fire.
In any event, ask Hyundai for proof or a statement in writing.
Cheers,
__________________
Live to drive!
(For commuting - take a bus)
Ravveendrra is offline   Reply With Quote
Thread Tools
Swift Catches Fire joethomasv Street Experiences 30 18th November 2008 13:11
Bullet tanker crashes, catches fire with IMAGES nbr Street Experiences 21 23rd August 2008 13:29
Another accident on DND, car catches fire tsk1979 Street Experiences 10 18th December 2006 23:01
all fired up!!! OMNI catches fire!! flipsyde Street Experiences 3 13th December 2006 10:38
Palio catches fire after collision with truck, 3 dead tsk1979 The Indian Car Scene 41 15th February 2006 20:00
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599
