Old 29th April 2013, 12:02   #31
ankur_gupta10's Avatar
Thanked: 50 Times
Default Re: Safari LX 2.2 VTT 75 K Report
1. Got camber fixed.
2. Got the front bearings changed again.
3. Got the ball joints replaced.
4. Flushed radiator coolant and refilled.
Turbocharger pipe shows a little leakage, but no running problems. So continuing till there is an issue.
ankur_gupta10 is offline   Reply With Quote
Old 29th April 2013, 12:24   #32
tsk1979's Avatar
Thanked: 16,421 Times
Whoa!
Change it. If foreign particles get into the turbo, it will lead to shorter life, and eventually a 45000+ expense for turbo replacement. Never skimp on hose or rubber belt changes. A stitch in time saves Nine
Old 6th May 2013, 12:27   #33
ACM
ACM's Avatar
Thanked: 2,892 Times
Also besides what TSK mentioned. If the pipe leakage becomes big during an outstation drive the loss of power will be so significant that you will not be able to climb flyovers or get across Ghat section without a very significant strain on the turbo, engine, gearbox and clutch. It is relatively a small expense, get it done with.
ACM is offline   Reply With Quote
Old 6th May 2013, 12:44   #34
Thanked: 50 Times
You and TSK are correct, its the fat pipe in the right side of the engine. I showed it to a local mechanic and TASS, but both said that it gets black, and there is generally a little leak, and its OK. My local spare parts dealer wanted the fat pipe opened up and given to him, so that he can get it from his dealer, typically 1 day exercise. Does anybody know the part no?
Old 6th May 2013, 12:52   #35
ACM
ACM's Avatar
If he is talking about a small bit of leakage at the joint due to how the clamp is fixed then the clamp has to be fixed better else there should be zero Leakage. Just buy the pipe over the counter from the TATA Dealership. Also All TATA outside dealers too would know which pipe you are referring to if you mention the model year. Getting this from ASS is a better idea, the cost should not be more than 15% higher for the original pipe.
ACM is offline   (1) Thanks Reply With Quote
Tata Safari 2.2 VTT - Black Beast - 8.5 years and 100,000 kms up! v&v Long-Term Ownership Reviews 111 24th May 2018 16:29
Tata Safari 2.2 VTT : 125000 kms Long Term Report rrsteer Long-Term Ownership Reviews 87 14th July 2012 20:02
Need Advice: New Safari 2.2 LX VTT or Safari 2008 3.0 Top Model? alexnazim SUVs, MUVs & 4x4s 150 1st December 2009 11:20
New Tata Safari 2.2 VTT EX 4X2 EDIT 25000kms service done harjeev Test-Drives & Initial Ownership Reports 324 27th November 2009 09:18
Tata Safari 2.2 VTT RIPPED (Read post #94 before adding a TD report) .anshuman Test-Drives & Initial Ownership Reports 213 11th October 2007 23:45
