Old 16th March 2014, 23:13   #226
Default Re: Toyota Altis 1.8 GL - 47,000kms *update* New Yokohama tyres finally
Yeah this car is definitely perfect for BLR roads!
60k kms and all I do is change break pads.. touch wood! Service costs are 3k to 4k and the paint job is quite fantastic in my opinion. Vid u have got a diff front,have u?
Btw , thanks to GTO for sending across the stickers
Toyota Corolla Altis 1.8 GL - 60,000 kms and close to 7 years later-20140313_2314581.jpg
vivekrvcse is offline   (1) Thanks Reply With Quote
Old 16th March 2014, 23:43   #227
Vid6639's Avatar
Thanked: 17,201 Times
I've just changed the front grill from the 2 chrome one to black honeycomb found in the diesel variants. Gives it a less smily look.
Vid6639 is offline   (1) Thanks Reply With Quote
Old 17th March 2014, 08:31   #228
Obviously I would love to know where you got it from (and how much)
vivekrvcse is offline   Reply With Quote
Old 17th March 2014, 09:22   #229
Vid6639's Avatar
I got it from the dealer but it's insanely expensive. 6 grand for just the grill.
I'm sure you can get this cheaper from Thailand or Malaysia.
Old 29th July 2014, 14:14   #230
Thanked: 21 Times
My Altis is due for 3rd free service. Toyota service advisor says that AC vent clean up @ Rd 1500/- is part of the schedule. Is it true or just a cross sell attempt to fleece me?
anujatwork is offline   Reply With Quote
Old 22nd October 2014, 11:23   #231
freakmuzik's Avatar
Thanked: 264 Times
Great thread! Good to see the car is serving you well! And after reading more and more threads of a Toyota Vehicle, the reliability can literally be seen! And I'm shocked to see your service costs of 4k to 5k! Heck, even my wagon-r 30k and 40 k services costed me 5.3k each! Great. So while buying a next car, toyota will be high in the list as i've experienced how a not-so-good after sale affects you! Have many more happy miles Vid!
Cheers!
freakmuzik is offline   Reply With Quote
Old 14th December 2014, 11:17   #232
Vid6639's Avatar
Finally from a crazy hectic schedule I got time to drop the car for 50K kms service. The odo reads 54,900kms, well overdue!
The car has been going to Ravindu Toyota Avalhalli branch which is 20kms away. With the current workload, it was very difficult to get time and drop the car off that far away.
Had a chat with Jaggu and Khan and both of them suggested I try Nandi Toyota on Hosur road, Bomanahalli branch. Khan used to get his Prado serviced there. Jaggu accompanied me to the place as well.
Car was dropped off yesterday afternoon with following issues reported:
1. Clutch had become heavy and would shudder on cold start in morning.
2. Steering rack would rattle over bad roads
3. idling rpm would sometime get stuck at 2000rpm even when warm
4. rear brake pads to be checked to ensure the uneven wear issue from last year has really been fixed.
5. suspension check cause Madhus has mentioned some issue with camber when I changed the tyres in March.
Will get the car back tomorrow and estimate given Rs.4K + taxes.
Old 15th December 2014, 16:23   #233
Vid6639's Avatar
Things don't look all that rosy today. Got a call from Nandi regarding the complaints. They recommend the following:
1. Front brake pads are down to 3mm. Need to be changed. (Approx 10K)
2. Front caliper kit is getting stuck. Needs to be changed. (Approx 2K)
3. Throttle body will need to be removed and cleaned
4. Rear brakes are down to 7mm from 11mm new. Wear is even. Nothing needed.
5. steering damper to be chnaged.
6. Clutch bleeding done but clutch is towards the end of it's life. Recommended to change but ok for 5K kms. 17K for new clutch + new gear shift bushes.
7. brake rotors need to be skimmed.
Apart from the last item on the list, have told them to go ahead with the other changes. Bill has shot up from 4K to 21K largely due to the new front pads and calipers that are almost 14K.
Old 15th December 2014, 19:46   #234
Eddy's Avatar
Thanked: 3,777 Times
Default re: Toyota Corolla Altis 1.8 GL - 60,000 kms and close to 7 years later
Hmmm, are you now looking for a replacement ?
Eddy is online now   Reply With Quote
Old 15th December 2014, 20:09   #235
vinod_namakkal's Avatar
So you had spent Rs. 2.85 per Km apart from your regular service.
vinod_namakkal is offline   Reply With Quote
Old 15th December 2014, 20:13   #236
Vid6639's Avatar
How did you get that number? By adding all the bills in this thread??
Old 15th December 2014, 20:39   #237
Sorry a small miscalculation. Your odo reads 54,900 and your service cost is Rs. 21000
54900/21000 = Rs. 2.61 / km
Old 15th December 2014, 20:47   #238
subbarp's Avatar
Thanked: 80 Times
Even if you want to calculate it this way, it should be the other way around.
Rs. 21000/ 54900 km = Rs 0.38/ km.
subbarp is offline   Reply With Quote
Old 15th December 2014, 21:05   #239
That's true . I always do this mistake. Am weak in mathematics. My highest score in mathematics was 35/100
Old 15th December 2014, 21:09   #240
Vid6639's Avatar
Actually you have to add up all service bills from page 1 and then divide by kms. That will give you the actual running cost. As far as I know the total for all services done till now including the current one will not be more than 50K for 55,000kms. Will see based on final bill tomorrow.
Toyota Corolla Altis 1.8 AT - 4.5 years, 51000 kms. Running well...very well! geronimo Long-Term Ownership Reviews 36 16th January 2017 10:59
Toyota Corolla Altis AT *UPDATE: 67000 KM, 8 years- now on CNG!* mrkanitkar Long-Term Ownership Reviews 47 5th January 2017 12:54
Toyota Corolla H4 Automatic EDIT: Now at 8+ years/78,000 kms vasudeva Long-Term Ownership Reviews 203 21st June 2015 12:12
Toyota Innova: 11000 kms, 2 months and 3 services later balan Long-Term Ownership Reviews 18 20th May 2014 17:14
All new Corolla coming soon EDIT: Corolla Altis now Launched extreme_torque The Indian Car Scene 295 19th September 2008 23:48
