Old 23rd June 2015, 11:23   #256
Thanked: 127 Times
Default re: Toyota Corolla Altis 1.8 GL - 60,000 kms and close to 7 years later
Altis parts are not cheap bro. It's after all a D1 segment sedan.
The thing is parts don't fail as much so ownership costs are lower but when they do fail or wear out it costs a pretty penny.
The actual cost is not 14K.
1. Brake pads - 9900 + tax
2. Caliper Kit - 1800 + tax
3. Labour charges
Total comes to 14K including labour.
+1 to that. I have Corolla H4 at 13 and Etios 2012 at 7.5. Etios bumper is at 2.3 and Corolla at 12K. Similar for other parts. My faux brown cladding on Corolla stereo has given way in some areas and it costs Rs. 13000. Keyless entry with remote another 13-14K. Have not bothered to get both replaced.
What you get in both cars (incl. Etios) is the certainty that there would be no mechanical failures on the road and total trouble free experience.
vasudeva is offline   Reply With Quote
Old 8th April 2016, 15:29   #257
Vid6639's Avatar
Thanked: 17,192 Times
Default Re: Toyota Corolla Altis 1.8 GL - 60,000 kms and close to 7 years later
62,000 Kms update
Running has reduced drastically. The last service was done at 55K kms in 2014! That means in 15 months I had done barely 7,000kms. Thanks to not having a driver and the ease of Uber, the Altis is being used as a spare or standby car.
I wasn't too happy with the service done at Nandi last time around and wanted to go back to Ravindu. Thanks to a kind BHPian who knew the Ravindu guys, I got a call from Mr. Manjunath, the GM of service at Ravindu. He offered to come home, check the car and take it to the workshop for servicing.
Complaints:
1. Clutch shuddering on cold start.
2. Front suspension noise.
3. Sound from the rear brakes.
Most of the complaints were same as last time which meant they came back shortly after the service at Nandi.
I got the car back after 2 days, with all the problems resolved. Manjunath is a proper technical guy who kept me up to date on all the issues and what he did to fix them.
Final bill came to 9K which was not bad. However I was told the clutch would eventually need to be changed by the next service at 70K kms. The front struts were ok but might need to be replaced next service as well.
The car came back totally transformed. Pickup has improved thanks to the clutch setting and throttle body cleaning. The front sound has disappeared completely. Only small negative was the rear brakes have a spring sound which can be heard from outside. This is something new after the rear discs were skimmed on a lathe.
Service bill:
Toyota Corolla Altis 1.8 GL - 60,000 kms and close to 7 years later-img20160323wa0084.jpg
Toyota Corolla Altis 1.8 GL - 60,000 kms and close to 7 years later-img20160323wa0083.jpg
I also finally decided to get the car detailed to give it a refresh since it was nearing 7 years. Called up Nirmal from Keystone and he came home in his mobile detailing van. Thanks to the hard water spots, getting the car cleaned and prepped for detailing took an entire day. The second day was the actual detailing. 2 whole days of detailing for one car. The end result was worth the effort:
Lo and behold:
Toyota Corolla Altis 1.8 GL - 60,000 kms and close to 7 years later-img20160401wa0054.jpg
Toyota Corolla Altis 1.8 GL - 60,000 kms and close to 7 years later-img20160401wa0055.jpg
Toyota Corolla Altis 1.8 GL - 60,000 kms and close to 7 years later-img20160401wa0056.jpg
Toyota Corolla Altis 1.8 GL - 60,000 kms and close to 7 years later-img20160401wa0058.jpg
Toyota Corolla Altis 1.8 GL - 60,000 kms and close to 7 years later-img20160401wa0057.jpg
Toyota Corolla Altis 1.8 GL - 60,000 kms and close to 7 years later-img20160401wa0059.jpg
Toyota Corolla Altis 1.8 GL - 60,000 kms and close to 7 years later-img20160401wa0060.jpg
Toyota Corolla Altis 1.8 GL - 60,000 kms and close to 7 years later-img20160401wa0061.jpg
Toyota Corolla Altis 1.8 GL - 60,000 kms and close to 7 years later-img20160401wa0062.jpg
Toyota Corolla Altis 1.8 GL - 60,000 kms and close to 7 years later-img20160401wa0063.jpg
Toyota Corolla Altis 1.8 GL - 60,000 kms and close to 7 years later-img20160401wa0099.jpg
Toyota Corolla Altis 1.8 GL - 60,000 kms and close to 7 years later-img20160401wa0077.jpg
Vid6639 is offline   (14) Thanks Reply With Quote
Old 12th April 2016, 12:20   #258
gpa
gpa's Avatar
Thanked: 204 Times
I also finally decided to get the car detailed to give it a refresh since it was nearing 7 years. Called up Nirmal from Keystone.
The detailing looks brilliant, Vid. Could you please share the contact details of Nirmal. I'd like to talk to him about some work on my cars. Thank you.
Old 12th April 2016, 13:31   #259
Thanked: 194 Times
Smile Re: Toyota Corolla Altis 1.8 GL - 60,000 kms and close to 7 years later
Hey GPA,
Check the thread for Keystone Enterprises (Bangalore) on teambhp directiory @ http://www.team-bhp.com/forum/bangal...bangalore.html (Exterior & Interior Detailing : Keystone Enterprises (Bangalore))
You should have all the required details there!
Vid,
Your car looks awesome after the detailing. Can't believe it is 7 years old! Kudos.
naut is offline   (1) Thanks Reply With Quote
Old 26th August 2016, 00:23   #260
Hi Folks,
I am planning to consider buying a 7 year old Altis run 60,000km for the price of 3.5L. It has been converted to CNG recently and has 70%tyres left. The price looks very good for the car, wanted to with veterans and owners any apparent problem that might come up in an aged Altis?
While I know Toyota brand means reliability, still just confirming from your experience. I'm ready to buy and drive this car for the next 5 years if it gives annual maintenance around 10K. Thanks and keep suggestions coming.
62,000 Kms update
Last edited by Vid6639 : 26th August 2016 at 00:52. Reason: reducing long quoted post
niteshsharmab is offline   Reply With Quote
Old 29th August 2016, 10:06   #261
KK_HakunaMatata's Avatar
Thanked: 194 Times
Originally Posted by niteshsharmab View Post
Hi Folks,
I guess this is a very good price for Altis of 7 years with this mileage. You will not get the same in Bangalore for such price.
I bought a 9 year old Corolla (not Altis) last year and I don't think there is any apparent problems to be specifically looked into. But you should generally get it checked by any FNG for its condition and expected expenditure in the future course.
I am not aware of the likely problems on CNG part, let any owner comment on it.
KK_HakunaMatata is offline   Reply With Quote
Old 29th August 2016, 10:12   #262
drmohitg's Avatar
Thanked: 2,983 Times
Isn't 3.5 L a bit too sweet a deal? I would have expected a similar specced Altis to go for something around 5L at least. The older corollas are still holding on their resale values in the used car market. You can possibly get it evaluated at Toyota after sales and also have a detailed look at the service history.
There is no other problem per se with the car as such.
drmohitg is offline   Reply With Quote
Old 30th August 2016, 20:21   #263
Thanks a ton folks. In Mumbai 7 to 8 year old corolla altis is fetching ~4Lacs. That's pretty compelling, looking at Innovas running cost I believe it will be similar for Corolla as well.
Can someone suggest if buying a CNG used vehicle is fine or I should scout for petrol and fix cng aftermarket. Thanks a ton.
niteshsharmab is offline   (1) Thanks Reply With Quote
Old 4th September 2016, 20:40   #264
Thanked: 18 Times
Hello,
I would strongly advice to buy a only petrol driven vehicle and then go in for CNG conversion. You can never be sure on a CNG fitted vehicle about the quality of fitting, care taken while driving on the alternate fuel and such things.
I recently bought a 2010 Altis petrol and then fitted the CNG. The car performs as desired.
Gran_Tourer is offline   Reply With Quote
Old 4th September 2016, 21:51   #265
Thanks a ton brother. Can you pls tell how much did u get ur altis for and it's how much run. Even I'm planning seemingly good deals on this car, given its Toyota maintaining it will be low too for next 4 5 yra.
Originally Posted by Gran_Tourer View Post
Hello,
Mod Note : Slang and SMS Language are STRICTLY prohibited on Team-BHP. Please type in full and proper English for the benefit of other community members.
We advise you to read the Forum Rules before proceeding any further.
Old 11th September 2016, 21:33   #266
Thanked: 18 Times
Hey,
Mine is a 2010 GL model which was at 28k when I bought it on 09.06.2016. The vehicle was kept amazingly well by the first owner and was run on petrol completely.
The final price was 5.9L +3k (changed the key to the flip one) + 25k(Insurance) + 18k(RTO Charges)
I converted it to CNG for roughly 37k. The odo stands at 31.5k and there are no issues as such post conversion to CNG. I got it serviced at 31k and the bill was 6k at the authorized center.
However, there has been one issue faced which might be related to the fuel pump. The car refuses to start intermittently. I have to get it diagnosed and find the source of the same soon!
Old 7th November 2016, 20:10   #267
Thanked: 24 Times
Hello Vid.
I am presently driving a Tata Safari Dicor and looking to change to a Sedan. I came across a mint condition 2010 Toyota Corolla Altos 1.8 G petrol which has done just 12000km. Spoke to the owner personally and seems to be a genuine person. Planning to have a look at the service history, an extensive check by the mechanics and a couple of drives. I have few questions.
1. What are the differences in features between a 1.8 G and a 1.8 GL?
2. How much do you think I can shell out for this car if it turns out to be completely genuine?
3. I am actually looking for a Honda civic or a Chevy Cruze LTZ but came across this car. Never had a ride in a corolla before.
All I know is Toyota is known for its reliability and peace of mind ownership experience.
4. Okay lastly I want to ask you if I need to keep any points in mind to check particularly with the car.?
Thank you.
Ani0404 is offline   Reply With Quote
Old 20th January 2017, 11:29   #268
Thanked: 12 Times
Not sure if this is still relevant, none-the-less:
  1. Differences between G and GL: I own a G and IIRC GL had leather seats, xennon head-lamps and few other minor accessories.
  2. You can check the used car prices in your region by doing a quick Google search.
  3. You have to own a Toyota to feel the peace of mind. Corolla is a very good car which tends to spoil you.
    1. My car is over 6.5 years old, makes a yearly visit to the service center and other than that just runs. Use the pick-n-drop service, so, have not been to the service center in a long-time (other than battery change).
    2. The Corolla suspension is awesome. Now-a-days, I don't even slow down too much over rough roads.
    3. No rattles.
    4. Changed tyres six months back.
    5. Tyre pressure, I used to check bi-weekly in the first year of ownership, after that gave up as it stayed stable and now do that only if the tyre appears visibly deflated or before a road-trip (twice a year).
    6. Changed battery an year back. Toyota folks still tested the battery to ensure that it needs replacement. I was telling them to just go ahead and change.
    7. I wanted to change the car, however, test-drove the new Fortuner and didn't like the suspension. Liked the Camry, which is lovely, but, doesn't feel like an upgrade. Don't want to buy the Germans as they still have niggles.
    8. You will get bored with the car, but, it will still run well.
    9. You may miss some zing which the other two cars have, however, if reliability, comfort etc. are your main criteria, then those two do not even come close to a Corolla.
    10. Many more. Was talking to a senior Toyota person few years back, and he accepted that their Corolla customers are the most satisfied of the lot.
  4. You will be able to find a used-card checklist on TBHP forums, please use that.
Happy motoring!
anupgangwar is offline   Reply With Quote
Toyota Corolla Altis 1.8 AT - 4.5 years, 51000 kms. Running well...very well! geronimo Long-Term Ownership Reviews 36 16th January 2017 10:59
Toyota Corolla Altis AT *UPDATE: 67000 KM, 8 years- now on CNG!* mrkanitkar Long-Term Ownership Reviews 47 5th January 2017 12:54
Toyota Corolla H4 Automatic EDIT: Now at 8+ years/78,000 kms vasudeva Long-Term Ownership Reviews 203 21st June 2015 12:12
Toyota Innova: 11000 kms, 2 months and 3 services later balan Long-Term Ownership Reviews 18 20th May 2014 17:14
All new Corolla coming soon EDIT: Corolla Altis now Launched extreme_torque The Indian Car Scene 295 19th September 2008 23:48
