Old 12th December 2009, 21:30   #31
jkdas's Avatar
Thanked: 1,436 Times
Fuel filter change is 15k or was? Did this change for newer ones?
And labour is supposed to be free right?
Old 13th December 2009, 14:04   #32
v&v
v&v's Avatar
Thanked: 1,099 Times
Originally Posted by dadu View Post
You can again raise a complaint for the same, if they didnt get/ read the circular its their problem. Have a look at the post below.
If Fuel filter has the Part no : 253409110117, it should be changed only after 30k run.
http://www.team-bhp.com/forum/1003485-post208.html
Thanks dadu.
I am already in talk with Mr Grovar/Ankur regarding my charges issue at zonal office gurgaon. Let me see the outcome of it. I have asked them to proved a free check of my vehicle at any other service center than autolink.
As for above said info. How do i now verify that my old filter was of this serial No. or not. They have already changed it ?
vinod
v&v is offline   Reply With Quote
Old 13th December 2009, 14:08   #33
v&v
v&v's Avatar
JK,
My service book states clearly of change of Fuel Filter at every 15000 km service. Which means every 15k km, you are bound to have a minimum bill of 5k.
They have introduced a new service called STDCHK (Lubrication) which they claim to lubricate all electrical parts. They have charged Rs 325 for it. I have raised a complaint regarding the same. I am yet to receive the clarification from the service center side.
vinod
Old 13th December 2009, 19:09   #34
Thanked: 245 Times
Originally Posted by v&v View Post
Thanks dadu.
vinod
They should've returned the replaced part as it was paid for. But since yours is a 2009 model, you would have had the newer Fuel filter by default, the circular came in second half of 2008.
Old 16th December 2009, 09:17   #35
v&v
v&v's Avatar
Thanks Dudu.
(I am getting the refund for fuel filter change @ 15k km.)
I followed the same with Zonal office as why my filter was changed at 15k km service, they check my record and told me to raise a complaint with the Service center regarding the same. I did, after a couple of followup, i got a call the GM of that service center that they will REFUND the cost of filter.
Also regarding unsatisfactory service - Washing and Vacuuming, I am getting a complimentary wash with choice of my service center.
Hence i feel, I case of the service not upto the mark my MD,TASS or TASC if you really go after them and show your displeasure, you will get result. All you need to be persistent with Zonal office and the service center.
Again thanks dadu for the Fuel filter advice.
vinod
Old 17th December 2009, 15:36   #36
Thanked: 50 Times
Good that your issues were resolved amicably finally.
LongDrive lover is offline   Reply With Quote
Old 17th December 2009, 15:59   #37
v&v
v&v's Avatar
Originally Posted by LongDrive lover View Post
Thank lalit. I after a lot of call and followup's my issues were resolved by them.
vinod
Old 27th December 2009, 20:15   #38
v&v
v&v's Avatar
After the theft of my spare wheel cover, finally i upgraded to alloy.
Earlier
Tata Safari 2.2 VTT - Black Beast - 8.5 years and 100,000 kms up!-slr-042.jpg
Now
Tata Safari 2.2 VTT - Black Beast - 8.5 years and 100,000 kms up!-dc27n9-135.jpg
Old 27th December 2009, 21:26   #39
Thanked: 245 Times
Now
Definitely looks better, Just a word of caution, the lock is resting on the alloy hub and will eat away the chrome over time as it will rock to the vibrations. Use a double sided tape and stick one side of it on the hub along the free movement of the lock above.
dadu is offline   (1) Thanks Reply With Quote
Old 28th December 2009, 08:19   #40
v&v
v&v's Avatar
Thanks dadu.
i too was planning do this. As of now as cello tape working.
Also was hunting for alternative locking solution too.
vinod
Old 28th December 2009, 13:50   #41
Thanked: 245 Times
Thanks dadu.
vinod
Buy a cycle cable lock with PVC tube and cross it over through the alloy and the holding frame on the door.
Old 23rd March 2010, 14:16   #42
v&v
v&v's Avatar
Default Update at 21000 kms
After my second service at 15k kms,
No major problems faced.
We did two trips
1. Delhi - Amritsar - Dharamshala - Mcleod ganj - Billing - Delhi - 1600 kms - 7 Days
2. Delhi - Mumbai - Mount Abu - Delhi - 3100 kms - 6 days.
getting a consistant average around 12 kms.
100% satisfied with the performance of my bull.
cheers
v&v
Old 25th March 2010, 18:00   #43
Thanked: 19 Times
Hi Vinod,
Nice ownership experience with Safari and glad to see that you are enjoying your bull to the maximum.
I did see that you have clocked a good distance in the odo; what did you do to suppress the dashboard / door/ window glass vibrations that usually comed up after long drives? Or are you one of the lucky ones who do not have any 'in-cabin vibrations noise'?
Just curious and want to get rid of these in my Safari as well. They don'y bother me much; but was thinking if it can be better..
Cheers..
sunil_k_u is offline   Reply With Quote
Old 26th March 2010, 11:11   #44
v&v
v&v's Avatar
Originally Posted by sunil_k_u View Post
Hi Vinod,
Cheers..
Thanks sunil,
firstly i dont have much of the problem of in-cabin noise. I do had the rattle issue with driver seat and passenger window. Driver seat noise was correct during my first service and the passenger window rattle got corrected during the retro.
Rest all is fine with my beast. .
v&v
Old 3rd April 2010, 11:34   #45
v&v
v&v's Avatar
Default Type Rotation, Alignment, balancing done at 21k kms.
Needed to find a good wheel alignment guy , with some call to my circle came to know there is a good guy named (Sanjay) at Raj nagar IOC petrol pump who does wheel alignment and also a specialist in adjusting/increasing the turning radius. (Also a specialist for imported car too)
Me and ITmylife took our safaris. Huge rush , we had to wait around 1 hour before our turn came.
Got adjusted the turning radius,Tyre Rotation,Alignment,balancing, now its fantastic, U turn is a breeze. Earlier it used to be a pain, i had to do a U turn from middle lane , now i can do it easily from the right lane.
v&v
100,000 km of comfort - My Tata Safari DiCOR 2.2 VTT - Now Sold PrasannaDhana Long-Term Ownership Reviews 45 11th March 2018 13:47
A new beginning - Tata Safari 2.2 VTT DICOR EX QUARTZ BLACK verditer Test-Drives & Initial Ownership Reports 175 28th June 2016 23:05
Tata Safari 2.2 EX 4WD - 100,000 kms and counting jaysmokesleaves Long-Term Ownership Reviews 25 13th January 2014 10:11
2010 Tata Safari 2.2 VTT LX Black - 24000 KM Update shantanumishra Test-Drives & Initial Ownership Reports 48 25th October 2012 10:05
Palio GTX - Red beast comes home! EDIT: update @100,000 kms JVH Long-Term Ownership Reviews 327 7th August 2012 15:26
