Old 24th September 2010, 18:18   #256
SS-Traveller's Avatar
Thanked: 10,778 Times
Anyway, repairs done, and here are the before-and-after pics. The Hawk-on-Fours (Ho4s) earned its studs today! I rather like them.
Old 24th September 2010, 18:29   #257
Originally Posted by Zappo View Post
Aha! Now this sounds like a juicy, masala story. Bring it on.
By the way, I did not get this tell-tail. I mean, from that pic I felt it is a small knobby kind of thingy peeping out from the bottom of the rear bumper but not entirely sure. Could you please elaborate what this exactly is in terms of functionality?
It is to tow other vehicles with! This attachment also allows you to attach a trailer to the SUV and drive off for a long weekend.
himanshusmart is offline   Reply With Quote
Old 24th September 2010, 20:33   #258
SPIKE ARRESTOR's Avatar
Thanked: 742 Times
@SS remove the truss head screw, I believe it is M6x1.0 size, if not then drill a hole and pass a bolt with washer through this, that would not look odd.
Spike
SPIKE ARRESTOR is offline   Reply With Quote
Old 24th September 2010, 21:39   #259
Sounds like a good idea. Might just put in 2 more bolts on the right side corner too, to lend symmetry. Then it'll be the bolt-studded Ho4s!
Old 20th October 2010, 19:06   #260
Hawk-On-Fours® (H-4®) (the official name!) got a pair of brighter eyes yesterday - Philips Xtreme Power 80%+ 60/55W bulbs. 1100 INR for the pair. The lights were decent enough as such, and the original bulbs were also Philips (Made in Germany). There's @ 25-30% improvement in light intensity and reach.
The original bulbs went into the Swift, replacing it's Halonix, and what an instant improvement there!
Edit: 15 October was H-4®'s first birthday, with 26k km on the clock. The bulbs were a birthday gift of sorts!
Old 14th January 2011, 22:17   #261
Default 32,850 km update
H-4® had its 30k km service done in the middle of December 2010, with the oil in both diffs changed, and a general checkup. The front damper units were found to be leaking but not completely gone, but since 4WD front dampers were not in stock, the change was deferred.
Took in H-4® for the damper change today @32,850km, along with attention to a noise issue when driving in 4WD mode.
Hawk-0n-Fours® started emitting a high-pitched low-intensity whine from both the front hubs when driving in 4WD (both high or low ratio). Hubs lock and unlock okay. No noise when in 2WD with hubs unlocked, but noise persists even in 2WD when hubs remain locked.
Also wanted to change the engine oil since it's been almost 9k km since the last change (I know, the recommended change is at 15k km, but I still prefer an early change, @ <10k km). However, what came as a shock was the labour charges asked for...
The labour charge for only changing the engine oil & oil filter is a whopping Rs.550 + taxes.
It is a different matter that I got a substantial discount.
The noise issue was surprisingly simple, and nothing to do with hubs and differentials. The front prop shaft was being scraped by an extra-long bolt on a silencer clamp, and that was all there was to it! Take a look...
Bolt turned around and fully tightened to take care of the slight silencer leak. Both front dampers changed. No more noise. H-4® is back to running smooth and stable.
Old 14th January 2011, 23:58   #262
trumpcard's Avatar
Thanked: 11 Times
Default Re: Hawk-On-Fours® (H-4®) with a tail - Scorpio mHawk 4WD
Thats the rear tow hook if i am not wrong
trumpcard is offline   Reply With Quote
Old 18th February 2011, 11:44   #263
A quick update: 35k km completed on 14 February, exactly 16 months after the car came to me. One pic of the meter reading - on 27 January 2011.
The automatic cruise control has stopped working since yesterday. One ASC trip due - have a free car wash coupon to utilise, and this cruise control issue to sort out. Spike, what usually goes wrong for CC to stop working?
Old 18th February 2011, 12:29   #264
Thanked: 742 Times
@SS Da, is the vehicle speed being displayed correctly in the Instrument cluster? Most probably it must be loose / faulty switches, connectors in the steering wheel area. The simplest thing which can go wrong are the Clutch / Brake switches, check them too!
Spike
PS- These electronic gizmos are beyond me
Old 18th February 2011, 15:15   #265
MileCruncher's Avatar
Thanked: 356 Times
@Doc: Shouldn't the temp guage be slightly lower than the mid way mark. All Scorp's as well as my Storm also its below half always. Please get your coolant or may be the whole circuit checked
MileCruncher is offline   Reply With Quote
Old 18th February 2011, 15:43   #266
Spike
Yes, speed display is fine. I agree, it must be one of the sensors/switches that went on holiday. No worries, what's the warranty for?
Oh, how I also long for a car without electronics - including ECUs and EFi and loads of such headaches!
No, this was where it was right from the beginning. These bargraphs are awful - in fact, the fuel gauge shows 3 bars of the 8, when there's still 35 litres in the tank! And "Your Scorpio is running on reserve fuel" starts jabbering when I've still got 22 litres.
Old 18th February 2011, 15:57   #267
n.devdath's Avatar
Thanked: 1,712 Times
I m surprised the electronics act crazy so soon. Looks like quality @ M&M too has begun to take a hit.
Old 18th February 2011, 16:08   #268
I've had an issue with the MicroHybrid system early on during my ownership, and a switch which sensed the clutch pedal position was changed. A ten-minute job, which the ASC said was related to some bad vendor supplies in the earlier vehicles. Only saving grace is, these minor failures don't lead to a breakdown on the road, and can at best be described as minor irritants.
Old 18th February 2011, 22:44   #269
...some bad vendor supplies...
Bad vendor-supplied component rears its head again. Diagnosis of cruise control failure done - the brake light switch is permanently on. Needs replacement. CC works fine when switch is disconnected.
Mercifully, the brake light on the Scorpio is not direct wired to work with the ignition off, as in Marutis, but turns off after a delay timer relay trips, a few seconds after removing the ignition key. So I don't drain out the battery through constantly glowing brake lights when the car is parked.
Old 18th February 2011, 22:48   #270
Thanked: 742 Times
Dada, could you tell in detail what was done to correct this? I really wanna know.
Spike
The Hawk has Landed 2.2 mHawk 4WD .. vraghuz Test-Drives & Initial Ownership Reports 145 12th August 2014 18:37
Hawk-On-Fours® (H-4®) Roadtrip - LUCKNOW SS-Traveller Travelogues 18 26th November 2010 00:00
Hawk-On-Fours® (H-4®) Roadtrip - Amritsar & Pathankot SS-Traveller Travelogues 48 4th November 2010 14:01
Hawk-on-fours on a pan-India tour: Delhi-Mumbai-Goa-Manipal-Coorg-Kolkata-Delhi SS-Traveller Travelogues 187 16th July 2010 11:16
Old Scorpio Mhawk>>> New Scorpio Mhawk rishin.kalra SUVs, MUVs & 4x4s 9 21st July 2009 15:51
