Old 18th February 2011, 23:13   #271
SS-Traveller's Avatar
Thanked: 11,627 Times
Default Re: Hawk-On-Fours® (H-4®) with a tail - Scorpio mHawk 4WD
Originally Posted by SPIKE ARRESTOR View Post
...tell in detail what was done to correct this?
Nothing yet, Spike. Realised the brake lights were glowing constantly when I took the car out this evening. Taking a trip to CCU tomorrow for a week, will come back and have the switch replaced.
Old 19th February 2011, 09:47   #272
n.devdath's Avatar
Thanked: 2,150 Times
I've had an issue with the MicroHybrid system early on during my ownership, and a switch which sensed the clutch pedal position was changed. A ten-minute job, which the ASC said was related to some bad vendor supplies in the earlier vehicles. Only saving grace is, these minor failures don't lead to a breakdown on the road, and can at best be described as minor irritants.
Which is why the T Fort sells in spite of being overpriced by at least 30% than its worth. I wonder why it is so tough to get simple things right with our desi manufacturers.
@Spike: Can you throw some light on the/if there are conscious attempts made by M&M to stop these niggles please?
Old 19th February 2011, 10:01   #273
suman's Avatar
Thanked: 257 Times
Not a healthy situation for a long journey - try & get it changed at Kol. It can be very distracting for cars behind you. Apart from that, if the guy behind you realizes that your Brake lights are malfunctioning, there is a danger of being rear-ended when you actually brake........
Old 19th February 2011, 11:09   #274
Can't afford the Fortuner. Not yet, anyway. By the time M&M sort out the niggles on the Scorpio, I hope to have graduated to a T-Fort... Till then, I'll either terrorize the ASC to do my job (while under warranty), or get my hands dirty with D-I-Y.
Originally Posted by suman View Post
...try & get it changed at Kol.
Oops, no, I didn't bring H-4® to CCU - I took the bus. The Airbus A320...
Old 19th February 2011, 13:33   #275
suman's Avatar
Thanked: 257 Times
I'm relieved......do get it fixed as soon as you are back
Old 1st March 2011, 23:23   #276
Minor issue with the brakes that took exactly 5 minutes to fix. A little rubber piece that deactivates the brake light switch had worn out (it's supposed to be a common problem), and a new one was put into its place. Costs Rs.7, I got it gratis, thanks to the floor supervisor at Koncept Automobiles.
Here's what that little thing (the old one) looks like.
Old 11th May 2011, 22:12   #277
It's been a while since the last update on H-4®, and the odometer crossed 39,000 km today. All well with the machine as it bides time for the next month, to head for the terrain it was built (and bought) for.
One small bother with the vehicle since the beginning, was a rather pronounced under-thigh support on the driver's seat. This meant that depressing the clutch pedal caused pressure under the left thigh, and driving in heavy traffic meant either needing to pull the seat forward (making the position of the right foot on the accelerator uncomfortable), or suffering cramps in the thigh muscles after a while.
Since I plan to drive for prolonged periods in the mountains next month, I wanted the seat to be adjusted just so. The solution was a visit to this place in Moti Nagar with the suggestion and help of BHPian maglev.
The seat was removed and disassembled, and a pocket of the rather high density foam was removed from below the left thigh area.
The pocket was then filled with layers of low-density foam...
...and the seat cover finally assembled. The shape of the seat is not deformed in any way, but the firmness of the support under the thigh has reduced substantially, and the car is much easier to drive in heavy traffic, with the seat pushed back to my overall-most-comfortable position. No more cramps in the thigh muscles.
Cost of work: 800 INR.
Verdict: Good work for a somewhat steep bill. Worth it, especially since the seat appearance is not changed (no creases on the cover - which I was told, by others as well as Autocraft, would happen if I did what I did).
Old 11th May 2011, 22:19   #278
sudev's Avatar
Thanked: 2,646 Times
Nice input. I think this is perfect solution to driver seats in many cars that lack thigh support in driving position.
sudev is online now   Reply With Quote
Old 11th May 2011, 22:48   #279
I guess so. Packing in higher density foam, or even Polyfil (available from sofa makers) tightly into such a pocket should make the thigh support firmer without deforming the seat.
Old 28th May 2011, 20:40   #280
40,000 km service completed yesterday at 39,830 on the odo. Engine oil & filter, air filter, coolant, brake and clutch fluids and diesel filter replaced. All nuts and bolts tightened. Brake pads checked, good to go for another 10k km. Feels good to drive.
Old 2nd June 2011, 12:49   #281
One more landmark on the odo on 31 May 2011 after 1 year, 7.5 months of ownership.
Urgent work done yesterday:
The clutch pedal had become a little stiffer than it felt when new. With the upcoming trip to the mountains and a scare of clutch slave cylinder (CSC) failure in vehicles of H-4®'s period of manufacture, I thought it prudent to have the clutch attended to.
Koncept Auto Okhla were very kind to accommodate me in the middle of the afternoon, at 3 PM, on an emergency basis.
Gearbox down
The old slave cylinder - no leaks there.
The pressure plate and CSC were replaced under warranty, while the friction plate appeared to have substantial material left (not more than 20-30% wear) and did not require replacement.
Job completed by 7:30 PM, billed amount Rs.70 for hydraulic fluid top-up. Thank you, Koncept Auto!
Old 31st July 2011, 13:16   #282
H-4® went for the 45k km service on 29 July 2011 (Friday) with 45485 km on the odo. Apart from the usual wash and check, nearly a dozen little bits and pieces of work had to be attended to.
  1. MicroHybrid and cruise control not working. The clutch pedal sensor switch was faulty. Replaced under warranty, now working fine.
  2. Gear lock plate loose. Discovered the security bolt had gone loose, and 2 other bolts not fitted originally . Attended to.
  3. Footstep light (FL) not working. Wire cut when footstep hit during previous trip. Wire runs over footstep support, so was pinched and cut. Wire re-routed, joined & taped.
  4. All chassis-body-suspension-mounting nuts & bolts tightened.
  5. Left rear damper unit leaking, replaced under warranty.
  6. Rear door light switch not working. Fixed.
  7. Front hubs showed traces of oil during extended operation in Ladakh. No issues detected, hubs operating normally. To be greased at 50k km service.
  8. ECU scanned because check light came on for short periods in Ladakh. Only error found related to clutch pedal sensor, which has been replaced.
  9. Cigarette lighter fuse blown. Replaced.
  10. 2 wheel nuts damaged during tyre removal earlier. Replaced.
Total bill Rs.1923. Time taken: 6.5 hours from entry to exit.
Old 31st July 2011, 20:03   #283
Guderian's Avatar
Thanked: 1,410 Times
Hi SS-T,
Did they check the brake pads ?
Diff/gear/clutch oil/air/fuel filter change at 40 K ?
At 40 K, as per the manual, I thought even the engine coolant needs a change.
All these points culled from my maintenance sheet of the Scorp CRDe circa Sept 2005.
Guderian is offline   Reply With Quote
Old 31st July 2011, 21:27   #284
Originally Posted by Guderian View Post
Hi SS-T,
Yes, both this time and at the previous service - mountain driving takes a lot of brake pad material away, but I've got enough to last at least another 5k km.
Yes - all at 40k, also diesel filter - check my post dated 28th May 2011 after the 40k km service
That too, as well as brake and clutch oils.
My engine/gear/diff etc. oils and all filter change schedules do not conform to M&M's recommendations, and are changed much earlier - for example, engine oil and oil filter are replaced anytime between 8-10k km. I need to keep track of this, that's all, and since the work is done at ASC, there is no issue with warranty either.
Old 31st July 2011, 22:06   #285
Guderian's Avatar
Hi SS-T,
Nice to hear that.
Any particular reason as to why you change the oils at a higher frequency ? Esp engine oil ?
Reason being my experience - earlsier on my old Zen I used to change eng oil at 5K KMs though the manual mentioned something like 10/15 K KMs IIRC.
On the Scorp the EO change was to be at 15K KMs as per the manual. I used to change it initially at 10 K. But on talking to an senior M&M service chappie realised that the oils are rated for higher usage though they mentioned 15K KMs - meaning it is rated for usage upto 20K KMs or beyond - but to prevent abuse the manufacturers, as a safety measure, peg the change at 15K KMs. So shifted to 15K interval.
The last when I went to M&M ASC and changed oil (Jan 2011) - it was some 'Supreme' or something which had on the 'dabba' instructions to change at 20K though the ASC was still sticking to 15K.
All other oils were being changed at their recommended frequencies.
Are you generally using your H-on-4s in extremely trying conditions ?
The Hawk has Landed 2.2 mHawk 4WD .. vraghuz Test-Drives & Initial Ownership Reports 145 12th August 2014 18:37
Hawk-On-Fours® (H-4®) Roadtrip - LUCKNOW SS-Traveller Travelogues 18 26th November 2010 00:00
Hawk-On-Fours® (H-4®) Roadtrip - Amritsar & Pathankot SS-Traveller Travelogues 48 4th November 2010 14:01
Hawk-on-fours on a pan-India tour: Delhi-Mumbai-Goa-Manipal-Coorg-Kolkata-Delhi SS-Traveller Travelogues 187 16th July 2010 11:16
Old Scorpio Mhawk>>> New Scorpio Mhawk rishin.kalra SUVs, MUVs & 4x4s 9 21st July 2009 15:51
