Old 21st May 2011, 19:10   #271
mercedised's Avatar
Thanked: 177 Times
Default re: Tata Safari TCIC 2,30,000+ km review!
Originally Posted by sumannandy View Post
I find it better with IOC .
I used Mobil Delvac MX in the last fill. the vehicle is super smooth, and I feel that the it is easier to reach higher speed or climb steep inclines with full load. And definitely the engine is silent enough, but that may be due to the pump head change as well.
I am open for suggestions as it is time for another oil change now. This time the vehicle is running smooth even after close to 6.75k kms.
Shell Helix HX6 one of the best oil I have used till now in my Safari and Indica. Smoothness is super noticable immediately after the oil change. Cost is also only 200-210 Rs per liter.
A question, Do you also use 2T oil in Diesel?? Looks like only my car is running with out 2T Will have to try this now.
Old 21st May 2011, 19:36   #272
HIGHNOON's Avatar
Thanked: 56 Times
Hi Suman,
I have in the past few years tried various engine oils for my diesel motors.
I found the LUBES from our PSUs very good. There is no advertisements for these oils but there is always a better chance of these oils actually conforming to specifications certified, rather than making some tall claims and misleading information on packaging.
I feel IOC Servo Pride TC is an excellent oil. Retails at about 13xx/ 7.5 lit. Meets CF4 and is graded 15w-40. I have used more expensive stuff but have found this one to be as good oils worth 1.5 times .
And IOC Futura D is excellent at a higher range- Meets CI - 15W-40 and formulated for use in vehicles fitted with catcon and egr. Only catch is the packing 4lit. AND 1 LIT. I had bought the 4lT. cans for 825/- Now may have shot up.
But i still thinks it is the best value ci rated oil available.
HIGHNOON is offline   Reply With Quote
Old 21st May 2011, 19:43   #273
mercedised's Avatar
Thanked: 177 Times
API-CH4 is the recommended oil for Tata Safari TCIC. So, anything lower might not be good for the health of engine. There are better options such as Shell, Mobil, Valvoline available.
Old 21st May 2011, 20:01   #274
HIGHNOON's Avatar
Thanked: 56 Times
Sure there are better oils having sludge busters, friction busters, sustained released molecules, with synthetic technology, magnetic molecules and what not.
I feel it is a ( safari TCIC , mine is 2004 ) atleast a decade old engine with tolerances designed for older oils.
The oils recomended for particular emission standard and particular fuel specification so .
So i feel CF4 rated oil may be as good for the engine life.
Infact i wouldnt be too surprised if this oil is actually better in a situation where we are getting euro-IV diesel.
Anyway no harm in sticking with what manufacturer specified oil. They ought to know better ,no ?
HIGHNOON is offline   (1) Thanks Reply With Quote
Old 22nd May 2011, 16:21   #275
sumannandy's Avatar
Thanked: 219 Times
I do not use 2T.
Recently I had to change the fuel pump head and in the process i had some interaction with Bosch. Before that, I used to use premium diesel always. They advised me to use plain diesel and System D every 5000 kms for best performance.
I am willing to try Shell or IOC. Problem with IOC Futura D is it is not commonly available in all pumps.
sumannandy is offline   (1) Thanks Reply With Quote
Old 22nd May 2011, 18:50   #276
HIGHNOON's Avatar
Thanked: 56 Times
Today only i bought 1 can of 4lit.@ 880/- mrp and 1 lit can @ 226/ MRP.
It seems to be available at big bunks only. And the SM rated 10w-30 Futura -P does not seem to be available anywhere.
Now i have supply for 2 oil changes for Safari. With oil rates going up , thought shall have stock for a yr. ( 2 changes @ 5000km each )
Old 22nd May 2011, 22:20   #277
mercedised's Avatar
Thanked: 177 Times
Our cars require 20w40 not 10w30 be very careful in selecting the grade of oil. You might have to bear with another wore engine in quick time. TCIC has already a revv'in engine, so if you put additional stress on it by using wrong grade of oil, you might have to pay hefty for that. Use only 20w40 or above.
Old 23rd May 2011, 02:00   #278
c10
c10's Avatar
Nice photos, the car looks neat but is it repainted? How much did that woofer cost to you?
She's not repainted.. Bought her from the used car consultancy guys, they always do the rubbing polish to get that extra gloss.. Mech also said touch up work only, but not full body repainted..
Cheers!!
c10 is offline   (1) Thanks Reply With Quote
Old 23rd May 2011, 06:47   #279
sumannandy's Avatar
Thanked: 219 Times
I think TCIC requires 15W40. There is a sticker on my dashboard and it says 15W40 oil to be changed at every 8000 kms.
Old 23rd May 2011, 07:38   #280
mercedised's Avatar
Thanked: 177 Times
Yes, that's the minimum required specs. One can use any Xw40 oil or Xw50 oil. For me using a 20w50 oil is better in this hot Sun of summer. Currently am using Castrol GTX Diesel 15w40 as used by TASC. No problems, but still the car rests in garage for a long long time.
Old 24th May 2011, 19:23   #281
HIGHNOON's Avatar
Thanked: 56 Times
The 10w-30 SM futura P is for my gasoline logan I was only referring the availability at IOC bunks.
The 15w-40 CI rated fUTURA D is for my TCIC safari.
And i feel a 15w-40 is the right grade of oil for the turbo of safari. 20w-40 is still a bit thick.I would stick to 15w-40 for a turbo diesel like SAFARI TCIC and a 20w-40 for a Naturally aspirated 483 dl of earlier sumo.
Actually 15w-50 would be the right grade for a hot country like ours with the high ambient temperature. But unfortunately its not available in India.
Old 24th May 2011, 19:43   #282
condor's Avatar
Thanked: 4,908 Times
Recommended oil for Safari is 15w40 .. why would you want to try 20W40 ?
condor is online now   (1) Thanks Reply With Quote
Old 24th May 2011, 19:51   #283
HIGHNOON's Avatar
Thanked: 56 Times
Ditto my take.
20w-40 may simply ruin the turbo in colder times and cold starts.
20w-40 is ok for the NA diesels not for the turbo diesels.
Old 26th May 2011, 16:42   #284
ACM
ACM's Avatar
Thanked: 2,892 Times
20W40 is for the Sumo, though a lot of the smaller oil retailers try to push it for the safari saying the engine is the same. It is a bit different.
15W40 is for the Safari TCIC
Castrol Superplus 15W40 (a bit hard to get) - but is what I used the most.
Mobile Delvac 15W40
Are the two that I stuck with for 175,000 kms all through.
You can go to 5/10W40/50 but not higher that 15 or lower than 40 in 15W40
ACM is offline   (1) Thanks Reply With Quote
Old 27th May 2011, 07:34   #285
sumannandy's Avatar
Thanked: 219 Times
Castrol GTX Diesel is a good oil. Last time I used Mobil Delvac MX. Initially the engine was smooth but again I had to change oil at 6.75k kms. With Castrol also I get the oil changed at 6k-6.5k kms. With the fact that it is hard to get Mobil Delvac or IOC, and that there is a risk of parts changed outside, I might stick to OEM oil change for a while.
sumannandy is offline   Reply With Quote
Reclaiming life - My Tata Safari TCIC. 13 years, 1,23,000 kms and counting sumannandy Long-Term Ownership Reviews 163 19th April 2015 07:54
Tata Safari 2004 TCIC EX 4x4 125,000 KM Ownership Review AVR Long-Term Ownership Reviews 118 2nd January 2014 12:43
TATA Safari TCIC Maintenance Cost ibm_jennifer Long-Term Ownership Reviews 90 16th October 2011 14:10
TATA safari TCIC or the DICOR maheepgupta SUVs, MUVs & 4x4s 24 12th September 2007 11:29
Safari TCIC LX or Safari DICOR LX arindam SUVs, MUVs & 4x4s 19 10th January 2007 17:42
