Old 7th March 2011, 09:46   #61
SS-Traveller's Avatar
Thanked: 11,630 Times
Default Re: Urgent: Engine heating issue(?)
Originally Posted by sumannandy View Post
I have no idea about the thermostatic valve. In my car the temperature used to always be at 1/2 mark. During a radiator change (Nov 2009), TASS installed new model radiator circuit with new model radiator. Since then, the temperature has always been close to zero with AC at 2.
Is it harmful in any way...?
So the low mileage could also be because of the thermostat? Could you please explain...
Low mileage could indeed be because of a missing thermostatic valve or a faulty one which is stuck in the open position - this prevents the engine from achieving optimum running temp. It isn't really harmful to engine life if you go on a long drive, nor is anything going to break down, but since attending to the valve is not time-consuming work and would probably improve your FE, why don't you get it done before going?
Old 7th March 2011, 11:14   #62
sumannandy's Avatar
Thanked: 219 Times
Sure sir, point taken. The car is with TASS now. Will update this thread after I get it back hopefully by today.
sumannandy is offline   Reply With Quote
Old 7th March 2011, 11:19   #63
mercedised's Avatar
Thanked: 177 Times
@sumannandy:
There is absolutely no problem with the car. Why did you went to TASS. Even in my car the temperature needle never comes above "C" and on AC it is between 1/2 and 'C'.
P.S: And this is indeed a good sign of a healthy engine.
Old 7th March 2011, 11:53   #64
mmxylorider's Avatar
Thanked: 185 Times
Could it be a problem with the temp gauge? If the thermostat is faulty, would the fan be 'on' all the time?
as mentioned earlier in this thread, driving with this behavior is not a problem. I had a similar issue with my Indica. The temp gauge was just always halfway between 0 and mid mark - Continued like this for about 3-4K.
mmxylorider is offline   Reply With Quote
Old 7th March 2011, 12:21   #65
sumannandy's Avatar
Thanked: 219 Times
Originally Posted by mercedised View Post
@sumannandy:
Thanks for the information. TASS checked the car and did not find anything wrong at all. By the way, if I may ask, let me know how much mileage you are getting in city and if you always drive with 100% AC without switching off engine at traffic.
Everything is fine. TASS checked the car and did not find any problems.
Old 7th March 2011, 12:33   #66
mercedised's Avatar
Thanked: 177 Times
Mileage in city is 9-10kmpl not more than that without AC and without switching off the car anywhere before the destination. With AC I think it would be 8-9kmpl.
Old 7th March 2011, 13:17   #67
Did they physically check for the thermostatic valve, whether it is stuck in the open position or that it exists at all? Also could you give an idea of how long the car takes to reach optimum running temp after a cold start on a winter morning?
Old 7th March 2011, 14:35   #68
sumannandy's Avatar
Thanked: 219 Times
The temperature needle in the car never reaches the half mark, no matter what you do. May be spirited uphill driving will do, but I never checked for that.
You noted a very good point. According to TASS, they checked everything physically, and they are also taking a "long trial". But it is hard to believe them, and it does not harm to double check anyway.
I will be going to the TASS now to check everything.
Old 7th March 2011, 19:42   #69
sumannandy's Avatar
Thanked: 219 Times
Default re: Reclaiming life - My Tata Safari TCIC. 13 years, 1,23,000 kms and counting
There was a problem with the car. The coolant temperature sensor was not working.
According to TASS, this did not result in any other problems as only the gauge was not displaying the correct value.
After they replaced the sensor/switch, the needle is between 45% and 30% with AC at bumper to bumper traffic.
And the engine gets warmed up within a couple of minutes (probably it used to earlier as well, just that the display was not updated).
Also, the AC efficiency has increased 5-6 times after the replacement of the sensor/switch. Earlier the AC used to get cut-off pretty soon, resulting in ineffective cooling, Now the cooling is really effective even when the outside temperature is high. Looks like the AC sensor gets data from the coolant sensor.
Thank you all for your valuable input. I would not have known that there was a problem . It is anyway always better to get the correct temperature displayed, specially when I am going to do lot of uphill driving. Also, really happy that the AC is working great.
Old 7th March 2011, 21:16   #70
mercedised's Avatar
Thanked: 177 Times
@sumannandy:
It is nice to know that TASC recognized and diagonised the actual cause. But, I must tell you that my car meter also never pops up untill I switch on the AC and with AC it is between 'C' and 1\2 mark. And this has been the characteristics of car since day 1. I don't know if there is any fault in my car too, but there are no signs of any BAD.
Old 7th March 2011, 22:43   #71
sumannandy's Avatar
Thanked: 219 Times
In my car the temperature gauge used to be almost at C even with ac at 2.
The ac is more effective after the replacement
Old 9th March 2011, 15:41   #72
sumannandy's Avatar
Thanked: 219 Times
Stranded. Waiting for the help for last 2 hours or so. There os some metallic sound.
Old 9th March 2011, 16:38   #73
Cryptic post... could you please elaborate on what left you stranded, and where?
Old 9th March 2011, 21:39   #74
sumannandy's Avatar
Thanked: 219 Times
So a metallic sound was coming from behind the engine whenever the engine was on.
We could not figure out what it was. So stopped the car and called the helpline.
The helpline guys finally found a loose gearbox guard which came out. I am assuming it was not fitted properly during one of the repair works in the recent past.
After loosing 3 hours I am on my way. Don't understand why can't the service center guys pay attention to details.
Old 9th March 2011, 23:24   #75
mercedised's Avatar
Thanked: 177 Times
@sumannandy:
Is that engine guard same as the gearbox guard that runs down the chassis in the front? And what would have happened if you had driven the vehicle with broken gear guard?
Tata Safari GX 4x4 Mineral Red - 70,000 kms and counting HappyWheels Long-Term Ownership Reviews 486 29th August 2016 17:44
Tata Safari 3.0 Dicor: Burnt, Recovered and Reclaiming @ 1,62,000 Kms EDIT : Now SOLD! mercedised Long-Term Ownership Reviews 34 19th February 2015 06:46
Tata Safari 2.2 EX 4WD - 100,000 kms and counting jaysmokesleaves Long-Term Ownership Reviews 25 13th January 2014 10:11
Life of Tata Safari TCIC engine Hemanth Technical Stuff 48 16th March 2010 04:57
My Bull - TATA SAFARI Dicor 2.2 VTT Lx - Booked, Bought and Now Reclaiming my life! bglsrini Test-Drives & Initial Ownership Reports 324 27th November 2009 16:27
