Old 17th June 2010, 09:43   #31
Thanked: 7 Times
Originally Posted by rajeshvin View Post
Mine is september end 2009 fiesta, remote key is not programmed to open the driver side door only, I really miss the auto lock feature, I'll ask Service Manager if there is any way to activate this feature in my fiesta as already yourself and sanjayc got this feature.
Thanks,
Rajesh, by default the remote is programmed to open all doors. It can be reprogrammed to open driver side door only. This is toggle-feature. Don't remember the correct steps, but it is described in the user manual. IIRC, this is described by Nairji in the "All Fiesta Owners" thread as well.
sanjayc is offline   Reply With Quote
Old 17th June 2010, 09:58   #32
ghodlur's Avatar
Thanked: 2,435 Times
Smile
Its quite simple. Just keep the lock & unlock buttons on the remote both pressed for more than 4 secs and the feature is activated, to disable it repeat the same step.
I used to do it twice a week first during the weekdays when I used to drive alone to office and once during weekends when family drives along with me. But now I have stuck to keeping the option of opening all doors.
ghodlur is online now   Reply With Quote
Old 17th June 2010, 10:16   #33
nairrk's Avatar
Thanked: 37 Times
Infractions: 0/1 (5)
Yes ghodlur is correct, but this function can be activated only when the ignition is switched off.
nairrk is online now   Reply With Quote
Old 17th June 2010, 12:04   #34
rajeshvin's Avatar
Sanjay thanks, I was asking about how to activate auto door lock feature without using remote key after switching off the car, my fiesta don't have this feature of auto door lock which is present in your and Gilead's fiesta, any suggestions from your side.
rajeshvin is offline   Reply With Quote
Old 17th June 2010, 12:11   #35
Thanked: 7 Times
Not sure if I understood this, but the auto door lock feature is like this:
If you suppose use the remote unlock button, the lights will flash once. Now, in case you do not open the doors or boot for the next 30 secs or so, central locking system will be engaged and doors will be locked. So, basically this is a feature, where after disengaging the central locking, if for some reason you do not proceed to use the car from inside, the central locking system will re-engage.
I don't remember mentioning anywhere that if you switch off the ignition, and come out of the car, doors will automatically lock after some time. Is this avlbl in Gilead's Fiesta S..I doubt.
Old 17th June 2010, 12:30   #36
rajeshvin's Avatar
Sanjay, sorry for confusing query, basically Gilead in his earlier post (same thread) mentioned his (also yours) fiesta gets auto lock after switching off the car and if doors are properly closed.
Anyway thanks for your inputs, I am happy with present system (though not satisfied), and I do take care to lock the car with remote key.
Old 17th June 2010, 12:47   #37
Thanked: 7 Times
I re-checked Gilead's post...have never noticed such a feature. Let me check on mine and reconfirm.
Old 17th June 2010, 14:22   #38
Gilead's Avatar
Thanked: 21 Times
sanjay, maybe you forgot you made this post a few months ago.
Auto-locking works in mine - after switching off the ignition, if you come out of the car, and all doors/boot are already closed, even if you do not press the lock button on the remote, central locking gets activated automatically after about a minute or so. And, yes, this auto-lock happens without the blinking of lights as Gilead mentioned.
Gilead is offline   Reply With Quote
Old 17th June 2010, 14:23   #39
nairrk's Avatar
Thanked: 37 Times
Yes, I also read in the past as some one did claim that their car has the facility of autolock i.e after you reach your destination, switch off the ignition, come out and close the door - in a shortwhile the doors get locked automatically?
I tried in my car (and even checked with my dealer guys but they are not aware such facility is there in fiesta) but nothing that kind works. May be Ford technicians will be able to explain if this autolocking can be activated in Fiesta's!
Old 17th June 2010, 15:01   #40
Thanked: 7 Times
OOPS! Seems this feature is non-repeatable experiment!
Just went out and checked again. Here is what I did:
1. Unlocked using remote
2. Started the ingnition
3. Locked using the push door handle
4. Drove the car back and forward for some metres
5. Switched off the ignition and took out the remote key
6. Unlocked the doors by pulling the door handle
7. Came out, & just slammed the door close (did not use the remote lock button)
8. Walked off, had a fag, came back after five minutes
9. The door could be opened simply.
Which means, the auto-lock was not activated.
Now, let me do some other permutation/combination and see how I arrived at the auto-lock conclusion. Meanwhile, Nura@ also had confirmed it works in his car. Seems something is going on here.
http://www.kairaliford.com/fiesta.htm - this site which has now become kind of ready-reckoner for me, mentions keyless entry & auto-relocking feature present in ZXI/SXI.
Old 18th June 2010, 08:47   #41
Thanked: 7 Times
Till now, no luck. Tried various combinations, but auto-lock is not working.
What works is if the unlock button is pressed from outside, but for next few secs if no doors/boot are opened, the locking is activated again automatically.
Maybe Nura@ can cross-check his observations as well and confirm.
Originally Posted by nura View Post
Auto lock working in my Fiesta too. Haven't checked what happens if there is a person left inside.
I don't think the car can "sense" that there is someone in the car. More likely the car's body controller relies on signals sent by the opening & closing of individual doors. Just my hunch. Which could be totally wrong.
Old 18th June 2010, 09:00   #42
ghodlur's Avatar
Red face
Sorry for shooting off my mouth too fast without verfying the facts. The auto locking facility is not working in my Fiesta. I tried on a couple of occasions in a similar way which sanjay had tried but no luck. The auto locking does not happen. I guess its not been programmed, will talk to dealer and verify.
Old 18th June 2010, 09:54   #43
krish3's Avatar
Thanked: 21 Times
So it seems that the feature is available and has to be activated, which seems the case for @Gilead.
Let me go and check the manual once more and see if this feature can be activated. If so, its a nice feature to have.
krish3 is offline   Reply With Quote
Old 18th June 2010, 10:28   #44
ghodlur's Avatar
Smile
I contacted the Ford Dealer for the ongoing Auto lock feature issue. They have confirmed that the presently there is no auto lock facility available in Fiesta (any variant). Which means that if you close the doors after you get out of the vehicle the doors dont auto lock after a few min. This was confirmed by two Ford Dealers (Wasan & Shreeji).
This facility is normally available for vehicle having no engine mobilizer but Autocop security systems(not Ford's). Will be writing to Ford customer care for further clarification. Till then I guess I will have to use the remote key for locking the doors.
Old 18th June 2010, 13:24   #45
Gilead's Avatar
Thanked: 21 Times
Guys, I checked again this morning and it does auto lock after I get out of the car hahaha. Happens in about 30 seconds to 1 minute. Didn't time it. Looks like I got something that isn't working on any other Fiesta at the moment.
ghodlur: Auto Lock is explicitly mentioned on the Fiesta website. But it's probably referring to the to the auto lock that happens if you don't open the doors. Let us know what customer care tells you. I am pretty sure it's a programmable feature since it's working in mine, but probably even Ford is not aware of it. Only the OEM vendor will know for sure.
Please help me decide: Fiesta S or Fiesta ZXi? EDIT: Booked Fiesta S! Pics on pg5. frankmehta Sedans 108 18th August 2009 13:43
Hyundai to hike prices (2%) 1000-18000 from 1st week of June SumitBahl The Indian Car Scene 19 22nd May 2008 12:48
Getz 1.3L 18000 kms ownership report nishantgandhi Long-Term Ownership Reviews 20 11th February 2008 13:52
Fiat Adventure 1.6 Sport 18000 Kms sriku23 Long-Term Ownership Reviews 53 25th July 2007 22:39
16 yrs old kid Turbo_charged Introduce yourself 43 3rd August 2005 02:08
