Old 17th September 2012, 12:04   #241
headers's Avatar
Thanked: 464 Times
Default re: Long Term Review - Fiat Punto EP 1.3 - EDIT: 165,000 kms up
Originally Posted by kiren View Post
I have got the GC kit installed in my Punto and happy with the change in GC. What are these rear sway bars? I donot think these are replaced. The five items get replaced are the 4 shocks and one stabilizer bar in front.
Kiran
Apparently the later cars somewhere in mid 2010 onwards do NOT have the rear sway bars. If your car did not come with it, then they dont remove it, else I was told that they remove the sway bar. I am not too certain about the information though!
headers is offline   (1) Thanks Reply With Quote
Old 17th September 2012, 13:36   #242
epicenter.rulez's Avatar
Thanked: 168 Times
hi headers & kiren,
i myself wouldve gone for the increased ground clearance kit, but then the body roll would be that much more prominent and i dont like that.
the 165 mm of ground clearance on the older puntoes is also not that bad when the cars are running relatively less, but at 1.3k, the suspension does show signs of softening up.
so the best option for me was to upsize the tires again, and since they were already due for replacement, i bit the bullet. the 6 mm height over the stock size was gained from there.
now come the cushion tech pads, cushion tech being the name of the company that makes them. they are made from nylon 6, the reason of using this material and the properties being high tensile strength, elasticity and luster as well as their tendency to be wrinkle free.
these come in various sizes (heights and circumferences) and some cars use a combination of one or more size for best results. the photos show, how they are installed. its a 10 minute job
what they do is that once they are fitted, they maintain the heights of the springs and prevent the car suspension from bottoming out. As they are acting as spacers between the springs, they basically modify the spring ratings and make them stiffer, in turn making it difficult for the suspension to act mushy.
not only that, since the setup becomes stiffer, they also prevent the unnecessary body roll of the car at high speeds and during cornering. this also helps in slightly better braking efficiency as the car stops nosediving and the duration of maximum contact of the tire to the road surface is more (atleast this is what they say).
since the car doesnt squat on its haunches like earlier due to these, the ground clearance issue is sorted out.
hope this helps.
drive safe, always wear a seatbelt.
epicenter.rulez is offline   (5) Thanks Reply With Quote
Old 17th September 2012, 17:22   #243
headers's Avatar
Thanked: 464 Times
Originally Posted by epicenter.rulez View Post
hi headers & kiren,
hope this helps.
Thanks so much Mandeep - Now where do I get this cushion tec - I need 2 sets asap.
Old 17th September 2012, 17:29   #244
Thanked: 168 Times
Hi headers,
Just pmed u the details.
epicenter.rulez is offline   (1) Thanks Reply With Quote
Old 17th September 2012, 18:21   #245
headers's Avatar
Thanked: 464 Times
Hi headers,
Done,Spoke to Vishal and got some good info - Thanks again
Old 31st October 2012, 20:37   #246
sdp1975's Avatar
Thanked: 972 Times
Mandeep, hows your car doing ? Did you get the timing chain replaced ?
sdp1975 is offline   Reply With Quote
Old 2nd November 2012, 14:41   #247
Thanked: 168 Times
Nope. Its still pending. Not getting the time out to give in the car for repairs. Rescheduled the service thrice. The car is crying out loud for one. Maybe sometime next week. Odo reads 1.45 k kilometers.
epicenter.rulez is offline   Reply With Quote
Old 13th November 2012, 19:29   #248
Thanked: 168 Times
hi gaaij
first of all a very happy diwali to all of you.
secondly, finally managed to give the punto for its service and man it made a difference after the timing chain change.
too busy enjoying the car after a very long time and bursting crackers.
will put a full update once i am back from a long drive.
watch this space for more to come.
Odo reads 1.46k kilometers.
Drive safe, always wear a seatbelt!
Old 3rd December 2012, 17:34   #249
devansn's Avatar
Thanked: 113 Times
Any updates, epicenter?
devansn is offline   (1) Thanks Reply With Quote
Old 17th December 2012, 22:44   #250
Thanked: 168 Times
Hi gaaij
Proud to get to this!
Having a bit of an overboost situation.
Will try to sort it out this weekend.
Till then, drive safe, always wear a seatbelt!
epicenter.rulez is offline   (2) Thanks Reply With Quote
Old 17th December 2012, 22:46   #251
Thanked: 168 Times
Request the moderators to change odo reading to 150000 please.
I hope it isnt asking for too much!
Old 24th December 2012, 12:14   #252
Thanked: 168 Times
gaaij,
finally managed to solve the overboosting problem without the help of the authorised service center guys.
Details coming up in the next post. Still trying to get over the elation that i could do it myself.
The car crosses the 150 kph mark again.
Watch this space for more.
Odo reads a shakun ka 151000.
Old 1st January 2013, 00:30   #253
Thanked: 53 Times
Hi headers,
Hi epicenter,
That's an awesome discovery. I have a year old polo, and the front suspension is rubbish on bad roads. A heavy diesel engine up front makes matters worse.
Where can I get these cushion tec pads? Also, is the installation DIY?
Ph03nix is offline   Reply With Quote
Old 2nd January 2013, 11:58   #254
Thanked: 168 Times
Originally Posted by Ph03nix View Post
Hi epicenter,
hi pho3nix,
just pmed you the details. yes the installation is DIY and once the car is up on a hydraulic/pneumatic ramp with the suspension unloaded, its a 20 min job.
Old 2nd February 2013, 16:10   #255
Thanked: 168 Times
hi gaaij,
the punto turned 3 today.
At 157000 kilometers, it still looks fit to tackle the roads for a similar amount of kilometers more.
a lot of updates pedning from my side, but this was a reason to celebrate.
Long Term Review - Kinetic Honda - 53,000 KMS in 14 Years! ph03n!x Motorbikes 118 30th November 2017 17:33
White Knight: Toyota Etios VD 1.4L Diesel. Long Term Review @ 33,000 kms AshBabu Test-Drives & Initial Ownership Reports 6 8th December 2014 21:33
Skoda Laura - Long-term (14,000 Kms) ownership Review! anandbhat Long-Term Ownership Reviews 20 1st March 2013 09:39
GM - Spark PS - 22 months - 25,000 Kms - Long Term Ownership Review Chethan B G Long-Term Ownership Reviews 14 7th April 2011 18:21
Short Term vs Long Term Ownership, New Car vs Used Car Ownership architect The Indian Car Scene 10 9th May 2008 11:39
