Old 28th February 2012, 16:48   #841
traveloholic's Avatar
Thanked: 228 Times
Default Re: Chevrolet Cruze:The “White Annihilator” has arrived!!!! EDIT : 20,000kms Complete
Originally Posted by Fordmanchau View Post
Wow!! 25K kms, in how much time Pandeyji ? 1.5 or 2 years?
I just finished 25K on my car in 3 years
1.5 years Pal!!!
You need to spend more time driving Manish, Seriously
I clocked 20K in my Santro today, that too exactly in 15 Months and that too with City Driving.
traveloholic is offline   Reply With Quote
Old 28th February 2012, 23:54   #842
spadix's Avatar
Thanked: 186 Times
Originally Posted by mobike008
I am happy to report the brakes still perform amazingly well and there is not even a single symptom of the brake bads being on its last legs.
I remember you saying that you felt a loss of bite from the brakes (this was just before I moved out of Hyd, when we were checking out the CR70 on BQ). Did you get that looked into back then?
When I depress the clutch and engage the gear and leave the clutch, there is slight "kat" sound. This sound emanates each time I dis-engage the clutch.
Nothing to worry. Just a little loss of lubrication. There's no need of any special liquid. Any old lubricating oil will do. By the way, leaving the clutch pedal amounts to *engaging* the clutch.
LOL!! No way!! I am fine with the pace I am going on.
For a PETROL car I am doing good.
My BQ (a Civic) and WA are pretty much in lock-step. WA is 2-3 days older. So that's 25k kms in 1 yr 7 months for a petrol here, although I feel I have under-used my car to the extent of 7k kms as-on-date. The odo should ideally have been reading closer to 32k kms.
spadix
spadix is offline   Reply With Quote
Old 29th February 2012, 10:54   #843
n.devdath's Avatar
Thanked: 2,152 Times
we will spray a special liquid for this purpose which will eradicate that noise.
That "Special Liquid" in all likelyhood is WD-40 or its derivative. Keep a can handy at home, it is mightly useful in eliminating small squeaks everywhere.
n.devdath is offline   (1) Thanks Reply With Quote
Old 29th February 2012, 11:09   #844
Fordmanchau's Avatar
Thanked: 302 Times
last on mobike's thread.
Lol!! you guys are making me bad about the average 8k km annually on my car.
Nikhil, your car runs on ORR. The FE and driving fun, plus the longer distance you commute adds upto your Odo , I feel.
My daily average run is around 24kms, that too only from November last year. Before that it was hardly 14kms. Last year was dull in terms of long trip, but still managed 8k kms. The year before I did 12k kms .
Looks like I need some support here, Venu Sir(vnabhi) where art thou?
Fordmanchau is offline   Reply With Quote
Old 29th February 2012, 14:57   #845
vnabhi's Avatar
Thanked: 1,317 Times
@Fordmanchou--your usage is abysmally low. You gotta use the car more, like I do ---31 K already on the odo. Don't ask in how many years
vnabhi is online now   Reply With Quote
Old 2nd March 2012, 23:43   #846
Cruzerman's Avatar
Thanked: 34 Times
Update ( Pre-25,000kms Service) :-
Have just returned from a 1600kms trip to goa couple of days back and my current odometer reading is 25,000kms.
Hey, congrats on reaching 25k kms . With Cruze you tend to crunch more miles anyways. My Cruze's odometer has just touched 14k kms in 13 months.
My Cruze has an issue with the right hand side (front) brake caliper. The caliper sends out a "clang" noise whenever the car is driven on roads with small undulations. Not sure whether any other Cruze owners have come across such an issue. The right side caliper is a bit shaky compared to the left side one. This issue cropped up during a trip of 2100kms a couple of months ago. This has in no way affected the braking capabilities of the car and I believe it is one of the best in C+ segment cars. I took the car to the service centre to check it and the service guys fixed it saying it was just a loose caliper. After a week or so, the noise came back. I'm not sure whether it is a safety issue to drive the car with a shaky caliper. Do you guys think I should insist the service guys to replace the caliper or should I allow them to repair it again? Do you think this issue has anything to do with the tyre air pressure? I usually fill up Nitrogen to 34psi though the company recommends 32psi.
Cruzerman is offline   Reply With Quote
Old 3rd March 2012, 13:19   #847
mobike008's Avatar
Thanked: 8,319 Times
I just got the wheel alignment and balance done from Mohan Chandra and the brakes felt as good as day 1
Originally Posted by ashish22 View Post
Where have you fitted the tweeters on the B-pillar? Could you please post the pic of the same
As requested, picture posted below!
So where else do you think this liquid can be used for squeaking noise? I think only for metal related components
I have some other problem which was diagnosed during a casual conversation. Details below!
Please stick to 32PSI maximum. This is the maximum I set on my Cruze till date and even 32PSI makes the ride a bit harsher
Service Update DONE on Feb 29, 2012 (25,000kms) : Total Cost : Rs. 3525
1. Brake Pads : Top priority asked them to check the brake pads and replace if required. To my utter surprise the SM called me in afternoon and said they are absolutely fine and you can easily run for another 5000kms if not more. He mentioned they plan to only clean the pads and put it back. Cost was some Rs. 300++
2. Decarbonisation : They asked me to get this done and should be done each 25000kms it seems. This process will remove excess carbon from fuel system, pistions, valves etc. Rs. 1500 was the cost
3. Clutch spring noise taken care of.
Other cost included pollution check done and bought a bottle of System D
After 25,000kms. My Cruze maintenance cost stands at 0.58/Km (Including the wheel alignment and balance cost which is yet to be done)
ATTENTION CRUZE OWNERS (March 3rd, 2012)
Today morning, I dropped into service center to get a free nitrogen top up done which they forgot to do last time around. And, while talking to my service manager ( Sampath Reddy) who is a brilliant person, I mentioned there is a light wheezing noise ( can be heard if you hear very carefully) while car moves back in reverse gear to which he immediately told me good you highlighted this problem
According to him, GM has asked all dealers to immediately replace the brake caliper dampners for rear brakes for both wheels if any customer complains of same for FREE OF COST
Now wait to hear the cost
Each brake caliper damper set costs a whopping Rs.27,000 on each wheel
He immediately ordered for my free replacement set and asked me to drop in next wednesday for this replacement.
I cant stop loving KUN Dealership for their out of this world service and personal attention !!!!
mobike008 is offline   (1) Thanks Reply With Quote
Old 3rd March 2012, 13:23   #848
anb
anb's Avatar
Thanked: 157 Times
Infractions: 0/1 (5)
This is a common problem with old cruze. Ask the service centre to replace the caliper assembly for free. New Cruze comes with modified Brake caliper and pin. There was a mismatch between the brake caliper pins outer diameter and the inner diameter of the brake caliper hole.
anb is offline   (1) Thanks Reply With Quote
Old 3rd March 2012, 18:58   #849
ghostrider's Avatar
Thanked: 307 Times
Good to know
I mentioned there is a light wheezing noise ( can be heard if you hear very carefully) while car moves back in reverse gear.
According to him, GM has asked all dealers to immediately replace the brake caliper dampners for rear brakes for both wheels if any customer complains of same for FREE OF COST.
Each brake caliper damper set costs a whopping Rs.27,000 on each wheel.
Do you know till what manufacturing dates cars were afflicted with this problem? Ie...when did they rectify it?
ghostrider is offline   Reply With Quote
Old 3rd March 2012, 22:38   #850
Cruzerman's Avatar
Thanked: 34 Times
Thank you, mobike. I will stick to 32psi.
Thanks for the info, mate. My Cruze is 2010 Dec make. So, I guess it falls in the older batch. I will ask the service centre to replace the caliper. Hopefully it will solve the issue.
How accurate are the fuel efficiency info on Cruze's MID? I got a surprising figure of 18.6 kmpl a couple of weeks ago while on a 200km drive (the previous best was 17.5 kmpl a few months ago). This time I was driving with 50% a/c off and stayed on 4th and 5th gears mostly and never crossed 80 kmph. Will this increase the fuel efficiency to such an extent? In bumper to bumper traffic, I get around 10-11 kmpl though.
Old 3rd March 2012, 23:08   #851
anb
anb's Avatar
Thanked: 157 Times
18.6 Kmpl. Were you driving downhill? I tried the same kind of on a level load last time. Got 15.1 Kmpl. I think the actual FE is FE in MID minus 0.5 - 1 Kmpl.
anb is offline   Reply With Quote
Old 4th March 2012, 00:16   #852
spadix's Avatar
Thanked: 186 Times
Makes sense.
May be metal components, mostly, with a few other applications here and there. I remember reading a story (here on TBHP, if I'm not mistaken) of a Fiesta whose driver's side power window developed an issue. F.A.S.S. said the entire power window assembly must be replaced and it would cost a few thousands. The owner went to the friendly neighbourhood mechanic who opened up the door panel, sprayed some WD40 and the mechanism was back to being as good as new.
A decarb every 25k kms! Maybe because it's diesel. But at 1500 it hardly moves the needle. I remember back in the days of 2-stroke two-wheelers decarbs were a major maintenance activity every ~60k kms and used to cost a fair bit too.
Is this a formal recall or an activity to be performed only on those vehicles whose owners complain about the noise? Also, does this affect only Indian Cruzes? I'm sure you may have seen this news on the other Cruze forums by now if that isn't the case.
Seriously, hats off to GM and Kun!
Sometimes H.A.S.S. makes me wonder if I made the right choice with Honda. I'm sick and tired of their nonchalance, carelessness, and absolute ineptitude when it comes to addressing complaints with an effort to eliminate them. There have been two or three minor complaints which I have been experiencing every day over the last 14 months, but they can't reproduce it, and can't fix it when I reproduce it for them. They just can't handle anything more than the extremely routine stuff, and don't even make an attempt to get better. This is the case when volumes at their service centres are still low. I wonder what will happen when the Jazzes and Brios start coming in in numbers. I hope they learn something from GM before they slide even further.
spadix
Old 4th March 2012, 00:28   #853
SS-Traveller's Avatar
Thanked: 11,630 Times
...clean the pads and put it back. Cost was some Rs. 300++
What's the cost of new pads?
2
How frequently do you change engine oil? What did they do for the decarb - was it the use of an engine flush?
Old 4th March 2012, 11:15   #854
Cruzerman's Avatar
Thanked: 34 Times
No, I was not driving downhill. I was surprised too. I guess with a light foot and high gears, it's possible.
Old 4th March 2012, 11:46   #855
anb
anb's Avatar
Thanked: 157 Times
Front Brake pads Rs. 6431/- Rear ones Rs.7882/-
frankmehta® acquires a Locomotive: Chevrolet Cruze LTZ Automatic. EDIT: Now sold frankmehta Test-Drives & Initial Ownership Reports 59 13th June 2015 23:54
Choosing to Cruze - Chevrolet Cruze LTZ AT. (First 500 kms) a.sundaram Test-Drives & Initial Ownership Reports 47 22nd April 2014 16:46
My new Chevrolet Cruze in White! EDIT : PICS on Page 2 SubuS Test-Drives & Initial Ownership Reports 124 23rd May 2012 15:17
My White Boomerang has Arrived - The Maruti Ritz Pumpy_Raj Test-Drives & Initial Ownership Reports 13 24th February 2012 15:51
Little Spark of Happiness has arrived - Chevrolet Spark LT JRD Test-Drives & Initial Ownership Reports 27 15th November 2008 13:44
