Old 24th October 2013, 17:02   #46
Default Re: Vel's Indigo Manza Aura+ QJET
Guys,
I own the first batch of Tata Manza QJet (Dec 2009) and have faced many issues since I got hold of it. But the main problem that I face is the hard clutch which gives me knee pain in city traffic and the body roll due to soft suspension.
Do any of you face similar problems?? Any idea how much it would cost to get a new clutch installed??
Also, the authorised Tata service is so expensive.. just doesn't justify for a diesel car.
Brian Ammanna is offline   Reply With Quote
Old 24th October 2013, 19:03   #47
Thanked: 57 Times
Well Brian, you are not alone. There are many with the same issues. I too own one 2010 (may) model QJD and if I drive it for more than 15 minutes in stop-go city traffic, my left knee will pain for that entire day. Only option you have is to bleed the clutch. Regarding maintenance cost, it easily comes to more than 18K per year with 10k KM covering in 9 to 10 months. In TASS part cost and labor cost are more or less same !!
sreerknair is offline   Reply With Quote
Old 24th October 2013, 19:05   #48
Samar117's Avatar
Thanked: 496 Times
Originally Posted by Brian Ammanna View Post
Guys,
I own a petrol Manza(2009). From my experience, the clutch is super soft. And I haven't replaced the clutch, still stock.
As far as the body roll is concerned, well mine behaves like a boat because of the super soft suspension. Although absorbs the bumps very well while going in a straight line. But push it into a corner, and it starts rolling like a boat.
Samar117 is offline   (1) Thanks Reply With Quote
Old 5th November 2013, 17:49   #49
Have tried bleeding the clutch but hasn't helped much. I have driven newer cars esp petrol and they have a very soft clutch.. dunno if it's just with diesel models. Will take a chance and get the clutch changed and hope for the best.
Brian Ammanna is offline   (1) Thanks Reply With Quote
Old 8th November 2013, 12:38   #50
motomaverick's Avatar
Thanked: 868 Times
Has the clutch master cylinder been changed at any point in time? If not then get it done as I had the same problem with my 2011 car and they replaced it after which it's been fine. If it has been changed then it might be an inherent problem with 2009-2010 models.
For knee problems drink less coffee and exercise
Old 22nd March 2015, 17:59   #51
Thanked: 16 Times
Vehicle has done 31850km. For the first time, my car has done 10,000km in less than six month period and got the oil change in the recent mega Service Campaign.
Got my Brake Disc(Rotor) Machined and refitted. Still Running on original brake pads.
Very Recently I have replaced my Ordinary Rims with Alloy Wheel (R15). Its OEM Alloy wheels from TATA that is used for ZEST. It fits well and I like the.
Rs5500/per wheel from TATA Authorised Dealer in Coimbatore.
Pl. see the pictures.
Velmurugan is offline   (1) Thanks Reply With Quote
Old 26th March 2015, 20:18   #52
Thanked: 16 Times
Also drained about 300ml of engine oild and topped up with 300ml "Bardahl engine oil additive"(Rs.500/-). Approved by TATA.
A small kit was displayed for demonstration.
Velmurugan is offline   Reply With Quote
Old 20th September 2015, 21:12   #53
Thanked: 16 Times
Completed 50,000km and Oil Service Done.
Got my Fog Light bulbs replaced(fused).
Bonnet rubber bushes...
That's its. Car is going fine.
The AC problem is also solved. Nothing was done. I guess some Ice formation which got rectified I believe.
Old 2nd May 2016, 22:40   #54
Thanked: 16 Times
60,000km on the Clock, almost 6 years.
60K service done, including Timing Chain replacement.
Old 30th January 2017, 19:41   #55
Thanked: 16 Times
Had severe vibration at high speeds. Upon checkup following were carried out.
Replaced the following:
1. 4 x Tyres Apollo
2. Suspension Bush Kit
3. Splash guard below front bumper
4. Inner Ball Joint
5. Assembly Strut top mount
6. Set of wiper blade, tube, nozzle assembly
7. Brake pads
8. Brake Disc machining
65,000km
Now the ride is smooth.
Old 23rd October 2017, 19:52   #56
Thanked: 16 Times
72,500km clocked. Last Oil Change was done in Feb-2017 at 67500km at SRT TATA Motors Coimbatore
Replaced Engine oil & Oil Filter.
USED CASTROL MAGNATEC 5W-30 (Semi Synthetic).
Car is doing fine.
Free Issued the oil from Authorized Genuine Dealer in Chennai & got the work done by local mechanic.
Happy with CASTROL 5W-30 which is better than 5W30 of PETRONAS used by SRT TATA dealer in Coimbatore.
Indica Vista Qjet Aura- 10000 Km report rkg Long-Term Ownership Reviews 44 19th October 2011 14:11
The Prince - Tata Indigo Manza QJD Aura ABS gowda79 Test-Drives & Initial Ownership Reports 39 24th November 2010 14:09
Its time for the big show-Yes I got my Manza Qjet Aura + rki2007 Test-Drives & Initial Ownership Reports 8 23rd September 2010 00:20
Got my Silver QJet Aura nipun dhingra Test-Drives & Initial Ownership Reports 46 16th October 2008 18:55
