Old 30th November 2006, 12:04   #31 (permalink)
Shan2nu's Avatar
We use IOC 91 in all our cars and it's done a pretty good job so far.
Shan2nu
__________________
VTEC flyby - youtube.com/watch?v=1AhWJlVRPqE
Old 2nd December 2006, 19:48   #32 (permalink)
ravibhat's Avatar
ok Thank you for the reply,
I had contacted Shell people for their Petrol and octane value. this is what they replied.
[FONT=Arial][SIZE=2][/SIZE][/FONT]
[FONT=Arial][SIZE=2]Dear Sir,[/SIZE][/FONT]
[FONT=Arial][SIZE=2]Shell Super and Shell regular petrol contain shell proprietry additives that enhance engine performance and keep it clean. Both the grades of petrol are 91 Octane. For most of the Indian cars and 2 wheelers except very few high end imported fuel, 91 Octane is appropriate.[/SIZE][/FONT]
[FONT=Arial][SIZE=2]To get the best results, I recommend thar you consistently use Shell Super petrol.[/SIZE][/FONT]
[FONT=Arial][SIZE=2]Regards,[/SIZE][/FONT]
So its good that even Shell normal Petrol comes with Octane 91. Since my Innova's first owner used normal Petrol from good Petrol Bunks always I will continue to use normal Shell Petrol which is 91 octane. Toyota recomands normal Petrol. If its 91 octane they said it is even better. So shell is the petrol for Innova.
Ravi.
ravibhat is offline   Reply With Quote
Old 6th December 2006, 20:09   #33 (permalink)
ravibhat's Avatar
Fuel Economy about my Innova, In Bangalore congested traffic with 50% AC on, my Innova returned around 7.5kmpl, Next week I am travelling in highway I will come back with Fuel Economy on highway.
Ravi.
Old 29th December 2006, 15:21   #34 (permalink)
ravibhat's Avatar
I am back from trip, average it gave me 10.5kmpl as FE on highway. Its great drive/travel in Innova for sure, very comfortable and practical car in India is Innova.
One more point I would like to mention is vehicle used to produce vistle type sound, I thought something not right with steering or something else.. I carefully studied all situation and came to know within 3 hrs. vistle sound starts when outside Air Circlulation is on while travelling and when we speed up or slow down or take slight turns and when car is above 80+ in ODO. However I am double checking with service centre about this.
This reminded me case of Suhas's Fiesta and Metro Ford. He mentioned when he heard noice from steering on highway he asked Metro Ford to check his car and they met with accident as per what I read in this website. Hopefully what (it makes vistle type noice when air circulation is on) I found with my Innova is not the same situation of actual problem of Suhas's Fiesta.
Another funny thing -> my driver didn't cross 110kmph speed even on golden quadrilateral between Haveri and Bangalore in my petrol Innova. He used to touch 125kmph as top speed in my Swift. May be he needs more driving in Innova to touch 150kmph.
Hey Shan, Can you tell me whats the top speed you could achieve with your Petrol Innova ?
Ravi.
Old 3rd January 2007, 15:24   #35 (permalink)
superavi's Avatar
"points to remember about Petrol Innova is
1. We need to make sure Fuel Bunk guys fill petrol not diesel."
This point by Ravi was hilarious!!
superavi is offline   Reply With Quote
Old 3rd January 2007, 15:35   #36 (permalink)
akshay1234's Avatar
Ravi.
do you by any chane have a baggage carrier on your roof? that causes it sometimes.
akshay1234 is offline   Reply With Quote
Old 3rd January 2007, 15:46   #37 (permalink)
msdivy's Avatar
I know of a case where the new driver filled petrol in a diesel Ikon .
My friend owns a petrol Indica. He is extremely cautious while visiting a bunk to ensure the attendent their fills petrol instead of diesel.
msdivy is offline   Reply With Quote
Old 3rd January 2007, 17:30   #38 (permalink)
Hatari's Avatar
just bought a 25000km old innova.. fully loaded
and took it for to my family farmhouse in jharkhand.. about 250 kms away
the road after kharagpur is the worst i'v ever seen..
the drive in the innova was very comfortable.. amazing ride quality
11 kmpl, top speed of 150kmph (diesel )
but the problem was that the car had 7 ppl.. with luggage
that made the car even lower than it is... and the under carriage hit bumps a few times
is there any way to increase the ride height ?
and are any other innoca owners facing this problem ?
Hatari is offline   Reply With Quote
Old 3rd January 2007, 20:43   #39 (permalink)
ravibhat's Avatar
Hi Hatari,
One important point (you may already know) when there is full load Toyota suggests make sure your tyre pressure measured accurately. Front tyres 33psi, rear tyres 34psi, this is measurement when you check cold tyre pressure thats when you have not travelled 10km still, best time is morning. I suggest you can maintain 34psi for all tyres as cold tyre pressure.
I never noticed Innova hitting bumps or any rocks even while travelling very very bad roads. Already I travelled in my Innova very bad mud roads in hilly areas. Swift used to touch ground sometimes but this Innova (although as per tech. spec swift's ground clearence 170mm and Innova's 176mm as I read in mannual..) never touched because of its highly stable suspension make Innova ride solid without hitting any obstacles like road hump, rocks etc..
Since Innova is heavy car I feel it all depends on tyre pressure and since it has 176mm ground clearence one can't drive fast in bad roads because
it will hit rocks in sush cases, IF road is very bad drive slowly things should be alright Please check for any loose parts under engine or front/rear suspension unit. Toyota can help you thats one best solution. Please get in touch with them, I always reecived good answers from them so far.
Ravi.
Old 4th January 2007, 00:32   #40 (permalink)
Hatari's Avatar
hey ravi..
i actually made it a point to fill 33psi & 35 psi ( front & rear ) first thing in the morning.. having hardly travelled 2 kms
will talk to the service centre to figure out why its so low at next service
Old 22nd March 2008, 14:46   #41 (permalink)
Default turbocharged?
hey guys just wanted to know if the innova diesel has a turbocharged engine or not, im planning on buying one pretty soon but jus wanted to know about this part
__________________
misfiring fate?!
rikin_sampat is offline   Reply With Quote
Old 22nd March 2008, 15:42   #42 (permalink)
akshay1234's Avatar
yes it does. all modern diesel engines are turboed.
Old 23rd March 2008, 21:08   #43 (permalink)
ravibhat's Avatar
Hi Shan, Akshay,
My AUG. 2005 manufactured Innova's stock Exide battery gave up a day back, I exchanged it for TATA Green battery with 15 months warranty for 3000/-
Whats your latest and overall feedback about Innova's Battery?
Ravi.
Thread Tools
Toyota Innova Diesel 30,000 Kms Report + Pete's box review akshay1234 Long-Term Ownership Reviews 150 19th June 2008 17:11
Maruti Swift -Vxi (ABS) 1000km ownership report raghutk Long-Term Ownership Reviews 0 27th August 2007 14:23
2006 Baleno VXi - 1000km report updated @13000kms shuvc Long-Term Ownership Reviews 96 28th June 2007 09:57
Toyota Innova cheatingdeath The Indian Car Scene!! 15 18th May 2007 23:00
Powered by vBulletin
Copyright ©2000 - 2008, Team-BHP.comAd Management by RedTyger
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430
