Old 7th February 2011, 09:11   #76
v&v
v&v's Avatar
Thanked: 1,099 Times
Default re: Skoda Octavia vRS - 12/2004 - Diamond Grey - Update @ 46500 kms
Today morning again EPC light came ON, vehicle is running normally. Switch off and ON , EPC goes off. It has not come on again.
Observation : Last petrol filling was not from the usual pump. Could it be due to it ? There is no performance deterioration. Still monitoring.
v&v is offline   Reply With Quote
Old 7th February 2011, 15:20   #77
Thanked: 11,072 Times
Try cleaning the MAF sensor
Old 7th February 2011, 18:11   #78
v&v
v&v's Avatar
Thanks ajmat, but the error code generated was
Code P0221 - Throttle/Pedal Position Sensor/Switch "B" Circuit Range/Performance
The pointers is towards either the pedal position sensor issue or the throttle position sensor on the manifold.
Will do a scan again and post the results.
Old 24th February 2011, 06:15   #79
v&v
v&v's Avatar
Current update, Since the pointer was towards throttle body, i used system G.
Have driven around 500 kms. Every thing is back to normal.
Old 1st March 2011, 07:16   #80
v&v
v&v's Avatar
Update at 39k kms.
Changed the rear brake pads at FNG.
Costed @ Rs 750/- + 150 labor.
Also replaced the A/c filter or Pollen filter @ Rs 500/-.
The guys had a tough time pushing back the caliper piston. It almost took 40 min for each wheel.
Old 1st March 2011, 09:13   #81
SS-Traveller's Avatar
Thanked: 11,630 Times
Didn't he loosen the bleed nipple?
Old 1st March 2011, 12:42   #82
You need a special tool to rotate the piston back. It can be done using a thin nose plier
Old 1st March 2011, 15:24   #83
v&v
v&v's Avatar
SOP is as ajmat refered, one has to rotate it to push back. it very tight. Even after loosening the bleed nipple , it took a good 15 min to push it back.
These guys used nose plier to do it. it make it difficult due to the awkward location too.
Old 31st March 2011, 21:16   #84
v&v
v&v's Avatar
Update at 40k kms.
Got the engine oil & filter changes at Wheel Force, Rajouri Garden.
Cost : 5L of Mobil 1 @ 850/- + tax per lit
Oil Filter - Rs 350/- (Raj nath motors, mahipal pur, new delhi)
Labor - 300/-
Changed the oil (only 7k kms ) because when i bought the car, i presume the oil was not changes for more than a year and half. it was black. Instead of a flush, a early change of oil was opted.
Old 1st July 2011, 15:35   #85
Thanked: 94 Times
@v&v:Have you gotten your timing belt kit changed?If not, that should be your first priority now since the car is already 6.5 years old.Timing belt snapping means serious damage to a non-interference engine.
The same would set you back by approx. 30k INR for the Labour + entire kit (which includes belts, bearings, pulleys, bolts, tensioners).I am guessing the quotes of 10-11k INR found here on the forum for the same are the quotes only for the belt and the tensioners.Apparently, replacing the entire kit on an old car is better than replacing only the belt and tensioners and mixing up old parts with new.That's what I found online at Briskoda.While at it, get the water pump changed too as advised on team-bhp.
octane1002 is offline   Reply With Quote
Old 1st July 2011, 15:47   #86
You mean an interference-type engine, don't you?
Old 1st July 2011, 15:48   #87
Thanked: 94 Times
Oops, thank you for correcting.
Old 1st July 2011, 16:20   #88
v&v
v&v's Avatar
Thanks octane1002 for the reminder/advice. this was the first thing i got checked. As per the service advisor need to consider around 50k only. Age is not a major factor for TB. I am keeping a close watch of it. Will be changing it soon.
Now as for the cost, the entire new kit is available at rajnath motors for just 9.5 k only.
Old 1st July 2011, 16:44   #89
Thanked: 94 Times
@v&v:Are you sure age isnt a factor for considering the timing belt change?In that case are there any particular signs to gauge that the car is due for a timing belt change?
Also on the price of the entire kit are sure it includes the pulleys/bolts/bearings?I was under the impression that only the ribbed belt along with the tensioner cost around 7.5k and all the allied parts such as tensioners/idler bolts etc sets us back by around 23-24k.And since its a precision job its always better to get it done at Skoda(who again might be reluctant to accept parts from outside).
Old 1st July 2011, 17:06   #90
v&v
v&v's Avatar
@octane, how can you be sure that the Skoda guys will do a precision work, when you hear so much -ve about their work in the forum itself. IMO a good FNG (Delhi has lot of them) can do it easily.
About the price , yes i have confirmed from the owner of the importer. its readily available with him. I was planning to do it when i bought the car, but my FNG told no need change it immediately.
As for the belt inspection, you can open the top cover the check the condition of belt. Visual inspection can help a lot, like dust or peal off etc.
Dream Come True. The Skoda Octavia vRS!! Update: 59,712 kms HAFI Test-Drives & Initial Ownership Reports 76 13th September 2014 23:07
Mahindra Xylo - 54000 Kms - Engine Issues!!! cinnypt Technical Stuff 71 9th July 2013 18:47
Throttle body change @ 54000 kms namit Technical Stuff 16 25th February 2013 18:20
Advice required - Skoda Octavia RS 1.8 Turbo - Bought - Diamond Grey/2004 v&v Sedans 22 19th August 2010 09:15
Skoda Octavia vRs - Laal Pari - 10000km update abhinav.gupta88 Long-Term Ownership Reviews 14 4th May 2009 17:26
