Old 30th January 2012, 20:51   #106
srinath1965's Avatar
Thanked: 11 Times
Originally Posted by v&v View Post
1.6 L , what all were the damages ? After a rebuild why 4 kmpl ? Where did you get it repaired ?
Got it done at the Hyd dealership where my car has been going since 2007 when bought. God knows why the mileage - noticed it yesterday i.e 2 days after the car came back home.
Originally Posted by ashish22 View Post
@Srinath They might not have set the tappets rightly or is there one? Also let the engine bed in properly as it might produce heat due to new metal friction. Have you experienced any loss of pickup?? Also i would suggest the oil change in next 1000-1500 kms.
Thanks Ashish, will do. She is one lovely car and we have travelled 98000KM togeather since 2007 Aug. No loss of pick up but the engine sounds softer. Will do the Oil Change as advised. Sri
Originally Posted by rxpaul View Post
Oops....so how much (km) had your RS done when the belt blew ?
98000 kms - Roughly 35% on highway travel. Of this 15K on bad roads.
Note from the Team-BHP Support Team: Please use the "edit" button if posting within 30 minutes of the first post, instead of creating another back-to-back post.
Also use "Multi Quote" option for quoting Multiple posts.
srinath1965 is offline   Reply With Quote
Old 31st January 2012, 06:36   #107
v&v
v&v's Avatar
Thanked: 1,099 Times
98K and A.S.S never adviced for a TB change?
IMO max 60K after which one should change TB.
v&v is offline   Reply With Quote
Old 31st January 2012, 08:10   #108
Ardy's Avatar
Thanked: 86 Times
Default re: Skoda Octavia vRS - 12/2004 - Diamond Grey - Update @ 46500 kms
Originally Posted by srinath1965 View Post
Wow Ardy,
I blwe my Timing Belt. Car just came back with a bill of INR 1,60 lacs includes a new battery as the car was in garage for 60 days (No spares in India) and mileage has dropped to 4KMPL.
Srinath
Goodness gracious. That's a huge bill. Can you share the list of parts that were replaced?
In my post, I was talking about the TB of my Octavia. My RS is just about 41K done and its due for its servicing soon. Since its been close to 5 years since I bought it, I would be getting the TB changed in the next servicing.
Cheers,
Ardy
Ardy is offline   Reply With Quote
Old 31st January 2012, 09:03   #109
v&v
v&v's Avatar
Cheers,
Ardy
Don't you think 41k is too early for a TB change. When i was discussing the same at Bosch SS, He was in opinion that heat is a major killer for RS. if it is not used for daily commute then age is not a big factor can safely extended till 60k with regular inspection while at service.
Old 31st January 2012, 12:30   #110
ashish22's Avatar
Thanked: 49 Times
I would still advice Ardy to go ahead and change the TB in his next service. Better safe then sorry :-) By the way my timing belt got snapped at 48K so its not a big issue and was set back by 78K bill. Also get the fuel pump inspected if its possible.
@Sri... You should sue skoda for not advising you to change the TB at 60K service. Still continuing with the old TB at 98K was suicidal and you paid for it.
ashish22 is offline   Reply With Quote
Old 31st January 2012, 12:41   #111
Thanked: 11,047 Times
My personal recommendation is to change it at 40k
Old 31st January 2012, 13:28   #112
Ardy's Avatar
Thanked: 86 Times
Yeah, 41K would be early. I drive about 500-600 KMs a month in the RS. I am planning to do it only because of the heated conditions of Hyderabad which is dry heat in summer and age of the vehicle i.e. 5 years. I would assume, the dry heat over a period of time would make rubber and plastic parts brittle and could lead to snapping / breaking. Hence the thought process of getting it replaced during the next service, which may be scheduled for March-April time frame.
Cheers,
Old 31st January 2012, 14:02   #113
rxpaul's Avatar
Thanked: 103 Times
Is it possible to physically inspect the belt ? I mean is it visible when you open the engine bay.
rxpaul is offline   Reply With Quote
Old 16th April 2012, 14:54   #114
v&v
v&v's Avatar
Yes , its possible. There is a black cover on the left side, which can be opened to check the belt condition. its easy, i do it once a month.
Another update - Regarding Sunroof
Today i faced a typical problem : The sunroof was opened in tilt mode. While closing it did close, just reset to open position. A little googling got information that pinch protection was the reason for this problem.
Resolution : To override pinch protection push the rotary switch at home/close position till the Sunroof closes completely.
Also there is an option to close manually in case the Sunroof motor fails :
The cover near the rotary switch can be pulled down , there is a manual crank to close it.
v&v is offline   (1) Thanks Reply With Quote
Old 2nd May 2012, 11:44   #115
Thanked: 11 Times
Wink re: Skoda Octavia vRS - 12/2004 - Diamond Grey - Update @ 46500 kms
@V&V So you went to Nitanshu's work shop to get the brake pads job done! He has amazing knowledge of Skoda cars and the RS in particular.
Dear Ashish,
Apologies for the delay in reply as I was busy with some new projects. Have finally dumped my lovely vRS. She was a great companion with a lovely reg number 555. Drove her all over with extensive long distance specially on the lovely AP highways.
She is currently under wraps at the automotive showroom our company owns (We are also the dealers for JLR - InLine4 Motors in Hyderabad) and I have shifted to a Tata Safari GX and Tata Marina. Maybe will try out the new Laura RS if possible sometime.
Old 2nd May 2012, 19:16   #116
Motoringlover's Avatar
Thanked: 179 Times
Hi Vinod -
I never shared the picture of my RS with you, mate thanks a ton for your help with it, I havent driven her in a while, but have plans to send her to get the blessings of saint pete.
Hope you like them.
Best - Motoringlover - Deepak
Motoringlover is offline   Reply With Quote
Old 3rd May 2012, 09:50   #117
v&v
v&v's Avatar
Originally Posted by Motoringlover View Post
Hi Vinod -
Hope you like them.
Thats some beautiful shots Deepak. As for Mods, IMO keep it stock unless you have specific plans , RS it too good and fast in stock version itself. I never felt it short of power ever !
By the by i am in double mind whether to keep my RS for another year or start hunting for another car like 3.6 V6 Superb or V6 Accord or C200 cgi even 320 D !
Suggestion please !
Old 3rd May 2012, 09:55   #118
Thanked: 179 Times
Suggestion please !
Mate - I have been away from this car for a while and i can tell you, its strong enough to keep you away from concentration. But having said that - I think i am now a convert of Euro build quality. Try the TSI.
That's what I am thinking - I might make this a project car and think of another daily driver. These cars are addictive.
Best - Motoringlover.
Old 7th May 2012, 17:23   #119
Thanked: 179 Times
Got my Elm327 obd cable. Installed ScanMaster-ELM. Standard driver was available in CD but it also require virtual com port driver (VCP). Downloaded from website. Tested with skoda and worked with out a glitch.
Mate - Could you please share - How to procure the diagnostic tool - I contemplating investing in it - What do you recommend ?
Also how did you procure the Ignition Coil - Did you buy directly from a Skoda Garage or use the import route. I don't have an issue with it, but want to have it with me. My engine code is AUM.
Old 10th May 2012, 09:58   #120
v&v
v&v's Avatar
Most of the parts are still available here with ease. Sources you can try are
1. Rajnath automobile - Vasant Kunj , near cng pump , c block. - 26781153
2. Metro Spares - Savitri Nagar, Malviya Nagar - 26017686
3. Lastly Skoda A.S.S
I think coil pack is available for 2.4 k per pcs. Part no to check is
06B 905 115M or 115D or ever 115J
As of OBD scanner , i bought it from dealextreme.com, software i am using scanmaster elm. this is more that sufficient for basic diagnostic.
Dream Come True. The Skoda Octavia vRS!! Update: 59,712 kms HAFI Test-Drives & Initial Ownership Reports 76 13th September 2014 23:07
Mahindra Xylo - 54000 Kms - Engine Issues!!! cinnypt Technical Stuff 71 9th July 2013 18:47
Throttle body change @ 54000 kms namit Technical Stuff 16 25th February 2013 18:20
Advice required - Skoda Octavia RS 1.8 Turbo - Bought - Diamond Grey/2004 v&v Sedans 22 19th August 2010 09:15
Skoda Octavia vRs - Laal Pari - 10000km update abhinav.gupta88 Long-Term Ownership Reviews 14 4th May 2009 17:26
