Old 1st November 2010, 20:36   #106
rahultomahawk's Avatar
Thanked: 45 Times
Hi Harjeev,
Rs. 40,000 to Rs. 50,000 is quite cheap . I paid 1,50,000 as tax not counting the extra 20,000 to the agent according to the books the tax was coming close to 2.5 lakhs. Transfering from one state to another is a costly affair.
rahultomahawk is offline   Reply With Quote
Old 2nd November 2010, 10:50   #107
tsk1979's Avatar
Thanked: 15,683 Times
Rahul, tax in punjab is only 2% so there is no need of any hanky panky.
Getting a new reg in pb should cost around 30-35K. I suspect the agent is trying to make quite a bit of moolah.
Old 2nd November 2010, 18:47   #108
Thanked: 45 Times
Hi Tanveer,
In Maharashtra Tax is 16% on imported cars .They charge it on the original invoice value. Its very cheap in Punjab lucky Harjeev.
Old 2nd February 2011, 23:10   #109
harjeev's Avatar
Thanked: 256 Times
Default Long Due Maintenance Update Part I
Hey Guys
Extremely sorry for the long pause with the update. Last maintenance update was on 15th October 2010.
The ODO has now (as of today) crossed 111k kms and now reads approx 111030 kms .
In the past couple of months I took the vehicle to the workshop thrice to sort out some small and big issues that are natural to crop up with the ownership of the vehicle especially when one buys a second hand or in my case a 3rd hand vehicle. Please do not misunderstand me as I am not cribbing or complaining, I am rather happy that these issues are cropping up as, as and when I am resolving these issues my vehicle is getting close to near perfection, atleast mechanically.
ISSUES
As I hadnít got a chance to check whether the 4x4 was working or not, I was not really comfortable about the 4x4 capability of my vehicle. Please bear in mind that I never had or have any doubt over the 4x4 ability and/ or capability of the mighty 80 series, I only wanted to check whether it was in proper working condition or not. The reason for my doubts was that my brother had taken the vehicle for two outstation trips and both the times heíd got stuck in sand and that too in the simplest of the places. Over the phone I guided him to lock the front hubs and press the H4 button on the centre console but he had to be pulled out both these times. So this was problem number one.
The second issue, though much smaller was the front power windows ceased to function along with horn.
SOLUTION
All this time I wanted to get the 4x4 issue resolved but I didnít get a chance to even check what the problem was. I didnít know whether there was a problem in the front differential or the transfer case or the 4x4 switch or any other issue that I wasnít thinking about or didnít know of it. So one fine day (9th of November 2010) I took the vehicle to the workshop and told guy to raise the vehicle on jacks and mount the triangle shaped mounts which all workshops and tyre shops use. They can be seen in the following pictures
Toyota Landcruiser - 80 Series HDJ80 - Owned for 82,000 kms and counting-101-raised-jacks-.jpg
What effectively I thought that weíd do is that raise the vehicle on all 4ís and then try engaging and disengaging the 4x4. This would tell us whether the 4x4mechanism was working or not.
After the above exercise was done we discovered that upon engaging the 4x4 the front shaft was rotating but without the force or the rotation being transferred onto the front two wheels. This gave me a sigh of relief that atleast the transfer case and the 4x4 mechanism was working and this was my main worry. Now I thought that the fault would either lie in the front axles or the Free Wheeling Hubs. So naturally we started opening up the front disc assembly along with the front hubs and all.
Toyota Landcruiser - 80 Series HDJ80 - Owned for 82,000 kms and counting-201-front-hub-being-opened-.jpg
Toyota Landcruiser - 80 Series HDJ80 - Owned for 82,000 kms and counting-202-front-hub-being-cleaned.jpg
Toyota Landcruiser - 80 Series HDJ80 - Owned for 82,000 kms and counting-203-front-hub-being-cleaned.jpg
In this process it was discovered that the front left Free Wheeling Hub FWH had developed an issue. There was this small circular plate which when the FWH is rotated to the LOCK position, pushes and locks the axle in place. This ring or plate was badly bent and mangled and was was preventing the front left wheel from being locked in place.
Toyota Landcruiser - 80 Series HDJ80 - Owned for 82,000 kms and counting-301-circular-ring-being-repaired.jpg
Also it was decided that when we have already opened the front assembly we do a complete service of the front discs (i.e. cleaning, greasing, washing, checking the bearings, etc)
Toyota Landcruiser - 80 Series HDJ80 - Owned for 82,000 kms and counting-401-front-discs-being-cleaned.jpg
A picture of the faulty part after being repaired
Toyota Landcruiser - 80 Series HDJ80 - Owned for 82,000 kms and counting-501-faulty-part.jpg
Some pictures of the final assembly in progress
Toyota Landcruiser - 80 Series HDJ80 - Owned for 82,000 kms and counting-601-greasing-final-assembly-progress.jpg
Toyota Landcruiser - 80 Series HDJ80 - Owned for 82,000 kms and counting-602-greasing-final-assembly-progress.jpg
Toyota Landcruiser - 80 Series HDJ80 - Owned for 82,000 kms and counting-603-greasing-final-assembly-progress.jpg
The air filter was also given a customary cleaning or the air filter element
Toyota Landcruiser - 80 Series HDJ80 - Owned for 82,000 kms and counting-701-air-filter.jpg
So after everything was done the vehicle was again checked and this time the front wheels were engaging like a charm. Also earlier I had to use a pair pliers to lock and unlock the front FWHís but post this exercise I was able to lock and unlock them with my hand.
When one has to spend an entire day at the workshop you have to keep yourself busy. Well, I took some pictures of vehicles standing at the workshop.
Toyota Landcruiser - 80 Series HDJ80 - Owned for 82,000 kms and counting-801-vehicles-lined-up-workshop.jpg
Toyota Landcruiser - 80 Series HDJ80 - Owned for 82,000 kms and counting-802-sunset-vasant-kunj-img_4658-psed.jpg
As it had become quite late in the evening and me too was quite tired, I decided to attend to the power windows the next day. Next evening I took the vehicle to Palika Bhawan and discovered that the power window motor had gone for a toss. The mechanic overthere told me that I can install Hyundaiís (whether accent or Sonataís I am not sure) power window motor and that it works flawlessly. Spoke to Bobbie and he too agreed that I can safely get them installed. These were eventually changed along with the complete window rubber beading.
Toyota Landcruiser - 80 Series HDJ80 - Owned for 82,000 kms and counting-901-power-windows-being-replaced.jpg
Toyota Landcruiser - 80 Series HDJ80 - Owned for 82,000 kms and counting-902-rubber-beading.jpg
Toyota Landcruiser - 80 Series HDJ80 - Owned for 82,000 kms and counting-903-final-installation.jpg
Again time has to be passed so I tried taking some long exposure, just experimentation
Toyota Landcruiser - 80 Series HDJ80 - Owned for 82,000 kms and counting-904-time-pass.jpg
Toyota Landcruiser - 80 Series HDJ80 - Owned for 82,000 kms and counting-905-time-pass.jpg
Toyota Landcruiser - 80 Series HDJ80 - Owned for 82,000 kms and counting-906-time-pass.jpg
All pictures are from a P&S camera.
harjeev is offline   Reply With Quote
Old 2nd February 2011, 23:24   #110
svsantosh's Avatar
Thanked: 1,392 Times
Default re: Toyota Landcruiser - 80 Series HDJ80 - Owned for 82,000 kms and counting
Did you try some soft roading yet? Will be fun in this vehicle I suppose.
svsantosh is offline   Reply With Quote
Old 3rd February 2011, 04:51   #111
there are ghosts in the last picture!!!
saintsinner is offline   Reply With Quote
Old 3rd February 2011, 12:30   #112
rhandle's Avatar
Thanked: 107 Times
I guess we have done some good off-roading in this, from climbing up dunes, rock, to getting stuck in lake.
The beast is powerful and gets out from every where by it self but when it got stuck then two Pajero had to be used to take it out.
rhandle is offline   Reply With Quote
Old 3rd February 2011, 21:12   #113
VCheng's Avatar
Thanked: 245 Times
Great DIY on the front hubs! A question: How was the preload adjusted on the front hub bearings to the specified torque?
VCheng is offline   Reply With Quote
Old 5th February 2011, 07:43   #114
harjeev's Avatar
Thanked: 256 Times
Hi Santosh, As rahul said, yes I did a little bit of off-roading, not hard core but we had good fun with this beast. One thing that this vehicle has is immense amounts of power at the disposal of the driver and once you have it in the right powerband, she's has that go anywhere, do anything attitude. Initially I'll get just the hang of it for the 1st couple of years, and later on now with Ironman liftkits and suspension mods available in India, who know what I'd be doing with this vehicle in the years to come.
Hahaha. Really looks like it na. Its actually a long exposure that I was trying in the evening while getting the power window issue sorted out.
Thanks mate and no idea how the hub bearing was adjusted. Though the workshop has a torgue wrench, but I didn't see them use it.
Old 5th February 2011, 08:00   #115
VCheng's Avatar
Thanked: 245 Times
Adjusting the front hub bearings is critical for a long service life and accurate tracking at highway speeds.
I have a Series 100, so the procedure might be different for the 80, but the bearing is first torqued quite high to seat properly, and then loosened, so that the force needed to rotate the hub is only 6 lbs or thereabouts, measured at a stud. This needs a load guage in addtion to a torque wrench.
From your description, your workshop may have just "winged" it. That might work if the mechanic has good experience, but given that "feel" is no substitute for proper specifications, overheating might occur if it is too tight, or highway tracking might be off if too loose. Both conditions are not good.
Old 12th March 2011, 23:54   #116
harjeev's Avatar
Thanked: 256 Times
Sorry for the long post.
Post the previous service interval, I had taken the vehicle for an outstation trip to Tordi, Rajasthan for some dune bashing and off-road fun. This was a three day trip and the TLC performed remarkably well during the entire trip both on and off-road.
However there were some parts that conked off during/ after the trip and I had to replace them after I came back to Delhi. The following was the job done
110295 kms on November 22, 2010
Power Steering Pump replaced
Brake Master Cylinder replaced
Rear Differential Seal Replaced
Oil Pressure Switch (This was not working since the day I bought the vehicle)
Radiator Cap
Differential Oil
Power Steering Oil
Brake Oil
Grease
Washing
Labor Charge
Power Steering Change
Brake Master Cylinder Change
Differential Seal
Front Guard Setting
Washing
Toyota Landcruiser - 80 Series HDJ80 - Owned for 82,000 kms and counting-110295-kms-7591.jpg
Later on I drove the vehicle for about 2 month and the radiator started leaking. Got it again checked up and discovered that the top tank of the radiator was leaking. Therefore I got that changed too, As luck would have it there was an old radiator at the workshop of a Toyota 4Runner that that almost the same dimensions. Thererfore I got the part from that radiator mounted on my radiator. Further the vehicle had run for 5400 kms since the last full service, I decided to get a full service done in the meantime the vehicle was at the workshop getting the radiator work done
110930 Kms on January 19, 2011
Engine Oil
Oil Filter
Coolant
Air Filter
Radiator Repair
Labor Charge
Toyota Landcruiser - 80 Series HDJ80 - Owned for 82,000 kms and counting-110930-kms-7591.jpg
Tyre Changed
111122 Kms on January 21, 2011
I got the tyres replaced too. Decided to go in for Yokohama Geolanders AT-S 275/70/R16. Infact I got a really good deal too. A friend was selling his slightly used set of 5 tyres, 2009 manufactured and I decided to go in for them. As the size that he was selling was an exact match to the OEM tyre spec I picked them up replaced the old tyres.
I have to mention that the ride quality has phenomenally improved since the day I got the tyres replaced. The vehicle has become so smooth over the potholes and uneven surfaces on the road like riding a well cushioned sedan. The road grip and road noise has also improved for the better. All in all I am really happy with the change. I was initially a little apprehensive with going in for old tyres, but it all worked out for the best.
Also I got the new set of tyres balanced, got the alignment done . This is where I discovered that the steering shock absorber was leaking and had lived its life.
Toyota Landcruiser - 80 Series HDJ80 - Owned for 82,000 kms and counting-111122-kms-tyre-change-7591.jpg
111360 Kms on February 2, 2011
On this day I decided to replaced the steering shock absorber and as I had saved some cash on the tyre replacement I decided to change the headlamps too.
This was carried out on this day.
Toyota Landcruiser - 80 Series HDJ80 - Owned for 82,000 kms and counting-111360-kms-head-lights-windshield-7591.jpg
There are some updates left that I would do so in a couple of days. Post these updates, this thread would be up to date.
harjeev is offline   (2) Thanks Reply With Quote
Old 13th March 2011, 11:42   #117
Thanked: 131 Times
way to go buddy. you are really into this I see. And you are giving it a good run as well. before you know it you will be past the 150k mark
53BHP is offline   Reply With Quote
Old 14th March 2011, 21:43   #118
harjeev's Avatar
Thanked: 256 Times
Thanks a lot Rohit
Glad to see that atleast someone is following the thread.
Yes I sure am trying to put it through its paces, on a recent count I've driven the vehicle for 14+K kms till date and am all set to embark on another 3000 kms round trip to Udaipur, Gir & Diu.
Found a very good workshop Lakozy Toyota and have given it for some repairs, well if anyone follows me on FB then they already know. Should get it back tomorrow and will update soon
Old 14th March 2011, 22:49   #119
svsantosh's Avatar
Paaji - we all follow your thread, what to do, your FB and blogs are a few days ahead, so dont reply much here
Old 14th March 2011, 23:12   #120
Thanked: 46 Times
Originally Posted by harjeev View Post
Thanks a lot Rohit
You are not getting it back tomm as the putty was still not dry by this evening and they will need all day tomm to paint it. The job seemed decent but could not feel the smoothness of the repairs as the putty was still wet and not sanded.
The chap said he will need all day tomm. No word on other items you wanted fixed as I was there only a few minutes. Let me know if you are coming tomm. cheers
zipperone is offline   Reply With Quote
A thin line between genius and insanity - Fiat Grande Punto 90HP - 1,50,000 km up! CrAzY dRiVeR Long-Term Ownership Reviews 670 2nd January 2018 14:57
Tata Safari GX 4x4 Mineral Red - 70,000 kms and counting HappyWheels Long-Term Ownership Reviews 486 29th August 2016 17:44
A Star AT: 26,000 kms in 15 months and counting... sumannandy Test-Drives & Initial Ownership Reports 97 9th June 2015 17:00
Pre-owned: Nissan Pathfinder, Toyota RAV4 or Landcruiser? tsk1979 4x4 Vehicles 12 28th July 2014 17:35
Ownership Report - My new Scorpio VLX mHawk - 25,000 kms and counting raj_5004 Long-Term Ownership Reviews 319 25th May 2011 13:59
