Old 26th November 2011, 14:21   #316
Thanked: 37 Times
Originally Posted by .anshuman
I was thinking, the 110hp MT version or the even smaller 1.6TDI Vento/Rapid would do even better in same conditions.
Hi Anshuman,
Have you test driven the MT of Laura and vento/rapid? Can you Say how do you compare the the MT with Vento/rapid as both Laura MT and the vento have almost similar power outputs I.e. 110 bhp bs 105 bhp and 250NM is the same. However the engine size is different but so is the weight.
Can anyone having driven both the engines put a comparison?
Sid
kumarsiddhi is offline   Reply With Quote
Old 26th November 2011, 16:56   #317
.anshuman's Avatar
Thanked: 9,159 Times
Default re: Skoda Laura DSG CR 140 - Ownership Experience.
Originally Posted by kumarsiddhi View Post
Hi Anshuman,
Sid
Yup, I have driven both these cars. My FE comment was based on the European FE figures mentioned at the back of the owner's manual, where the 1.6 and 2.0 110 engines mentioned as slightly more efficient than 140hp.
In Europe the 105hp 1.6 TDI(same as Vento/Rapid) is the starting range Diesel for Octavia(our Laura), it is the most efficient engine in the line up. Even Superb greenline comes with this same engine.
I cannot really tell you the exact comparison of both these engines because here i have driven these engines in different cars which have different size, weight and gearing. The 2.0 Engine definitely is more refined and with more linear power delivery compared to the 1.6. Both engines have similar 250nm torque output which stays for most part of the revv band, both are driveability champions from their segments here, credit to sensible gearing and flat torque curve.
I really cannot make sense out of why the 110hp 2.0 TDI is sold in Laura MT, if they want to go for economy get the 1.6TDI, and if they are keen on offering a 2 litre engine then why not 140hp version(like Jetta), which too has brilliant FE.
Old 28th November 2011, 11:07   #318
Swanand Inamdar's Avatar
Thanked: 573 Times
Very true. In fact my 1.9TDi 110bhp MT Laura does manage to return some great FE even in city traffic condtions. Today morning, on the way to work, I did happen to see the FE returned. It showed 5.5l/100kms. Thats in Hinjewadi traffic (slow as ever and chaos at its best).
Highway FE, the last time I checked was 22 kpl. That was with some spirited driving at its best.
Swanand Inamdar is offline   Reply With Quote
Old 16th January 2012, 18:26   #319
vinj14's Avatar
Thanked: 259 Times
Hello anshuman,
After completing 6 months my laura dsg i've noticed the odd rattle from the boot and the vibration entering the cabin on bad roads. My pedantic nature is just not letting this small issue go ! My friend suggested dynamat for the wheel wells and the trunk floor to solve this issue ( he also suggested this for the doors but im dead against dismantling the door panels). I would like your opinion and suggestion on this as i have zero knowledge on noise dampening!
vinj14 is offline   Reply With Quote
Old 16th January 2012, 20:39   #320
.anshuman's Avatar
Originally Posted by vinj14 View Post
Hello anshuman,
The rattle from boot in my car has self healed Actually when i vacuum cleaned the carpet and interiors last month i took out everything from the boot including stepney and rearranged it back, i did not check it the same day but some days later when i noticed the rattle was gone. I drove on a really bad stretch of road today, the AC and Audio were off and i don't remember any rattle.
Instead of going for dynamat, find the actual source of rattle. Maybe like someone else driving and you in the boot with a stethoscope Or may be rearranging everything again ensuring every thing held tightly like the emergency reflector and spare bulbs box etc.
My favorite Polaroid sunglasses do not like Laura's sunglasses holder, they start rattling. My other sunglasses including the metal frame Ray Ban Aviators fit fine and do not make any noises.
.anshuman is offline   (1) Thanks Reply With Quote
Old 23rd January 2012, 01:32   #321
adi_petrolhead's Avatar
Thanked: 1,069 Times
@ Anshuman:
Since you own the Laura for a longer period than I have, i wanna ask you about a small issue which is bothering me with my Laura DSG. I have noticed that the RPMs often increase at idle, close to a 1000 on the dial. car usually shifts in to 5th, the moment i touch 50 kph on the speedo, but when the idle rpm is high, it shifts to 5th only after 60 kph. at the same time, if i turn off the ignition after such an event, the engine fan stays on even after locking the car. I then restart the car and then the RPM reaches normal 800-850 and fan turns off. have you faced this problem in your laura? this has happened only 4-5 times in the 7 months i have had the Laura till now.
adi_petrolhead is offline   Reply With Quote
Old 23rd January 2012, 09:25   #322
Behemoth's Avatar
Thanked: 1,691 Times
Originally Posted by adi_petrolhead View Post
@ Anshuman:
Hi Adi_Petrolhead,
Don't worry this is quite normal and is on account of something known as DPF (Diesel Particulate filter) regeneration. What happens is that over a period of time, soot and carbon particles collect in the DPF (which is part of the exhaust system). If you are doing frequent short drives the buildup rate of the carbon particles is higher. To burn off the deposited soot in the DPF, the engine automatically goes thru cycles of DPF regeneration. In these cycles, what will happen is that the engine will idle higher than usual (950-1000) like what you have noticed and for periods as long as 15-20 minutes and you may also notice a funny smell from the exhaust fumes. During this time, what the engine is trying to do is to raise the exhaust gases temperature to a higher level so that the soot will burn out completely from the DPF.
This regeneration cycle is vital for the health of the engine, and I would recommend not worrying about it. In fact, what you should do (at least once a week) is to drive the engine spiritedly at higher rpms (3500-4000) after appropriate warmup, to burn off the soot deposited in the DPF.
You can also find some good info in the owner's manual.
Behemoth
Behemoth is online now   (6) Thanks Reply With Quote
Old 23rd January 2012, 09:53   #323
Originally Posted by Behemoth
Hi Adi_Petrolhead,
Behemoth
Thank you very much @behemoth for the valuable post and such detailed explanation. Its sure helpful for other Laura owners too. But I now remember, same thing used to happen in my verna too. Higher idle rpm. If I am not wrong, it's common to all modern day diesels?
Old 23rd January 2012, 10:21   #324
Thanked: 1,172 Times
Hi Adi_Petrolhead,
Is the Indian Laura equipped with DPF?
When I causally asked the service guys they said no, DPF is only used in "F-O-R-E-N" .
Of course, they are Skoda service guys so thay can say anything...he he he.
Incidentally, in my petrol Laura (TSi), the idle RPM fluctuates between 800 and 1100 upon cold start for a few seconds and I always assumed it to be an ECU bug...
Not sure, my 2005 Tucson does not do it, but then I think it does not have DPF.
anandpadhye is offline   Reply With Quote
Old 23rd January 2012, 10:34   #325
I'll have to refer the manual to know exactly whether Indian Lauras have DPF or not. If @Behemoth is so sure abt the problem he must be right. Any how, definitely, u can't take a word from Skoda Seriously. They are only and only worsening their image with small issues all the time. Diverting from the current topic, just another bad experience from Skoda After sales, They destroyed my newly installed windtone horns in the front o the engine bay, while te car was there for cleaning. When I asked them to replace it under warranty, they said 'ok sir, you can pick up your car tomorrow!' I was like heh??!! Yea it was a very stupid thing, first they made me wait for 3 hours at the workshop just so someone could attend the problem! Den they said u cn very well leave the car here till tomorrow evening! For unscrewing two horns and fitting them back?! On asking they say it was a warranty policy! Ridiculous...
Old 23rd January 2012, 10:42   #326
Behemoth's Avatar
You are welcome! The DPFs were introduced in India with the implementation of the BS4 norms (in 13 major cities which happened in April 2010). All diesel cars which satisfy BS4 should have a DPF, though some high capacity diesels can still manage without a DPF due to lower fuel/ air ratio (specifically the Toyota Fortuner/ Innova 3L Diesels are an example. Smaller 2L diesel engines from VW/ Skoda / Audi / etc) all have DPFs now and same should be with Hyundai. All these engines equipped with DPFs will go through regular DPF regeneration cycles, but subject to individual driving styles, the frequency of the cycles will vary.
Don't believe the Skoda guys ! Even though they are supposed to be "experts" this community actually knows a lot more than them!
In case of Petrol Skodas, there is no DPF , it is just a catalytic converter or CATCON, which is there is almost all petrol cars , since BS3 norms.
Idle RPM fluctuation in case of petrols also happens due to Idle rpm stabilization process which takes around 2-3 minutes will the engine warms up. For example on a startup in cold conditions, the rpm will be raised to a higher rpm to allow for quick heating of the engine and also to prevent stalling. Also, often the loads fluctuate (switching on / off of fan / AC / lights) which the engine automatically compensates for.
The 2005 Tucson would not have the DPF and also would not meet the BS4 norms, which is why it is also very difficult, if not impossible, to get it re-registered in any of the BS4 compliant cities if you are bringing it from another city.
Behemoth
Behemoth is online now   (2) Thanks Reply With Quote
Old 20th March 2012, 14:31   #327
.anshuman's Avatar
My car has done close to 26,000kms now. Nothing much to report *YAWN*, no issues, same FE, everything working like it should. Expect a proper report when the car goes for 30k service in next month.
I got a few PMs requesting me to update the thread. This thread is not abandoned, it's just there is not much to update.
.anshuman is offline   (2) Thanks Reply With Quote
Old 9th May 2012, 16:34   #328
Default Re: Laura gets Curtains.
Hi Anshuman, can you please share details of the dealer where from you got your cutrains. because i am also getting quots of 4500 from everywhere.
Thanks.
I always liked the OE curtains some luxury cars like Mercs etc...
...how easy i am on the acc. pedal. The DSG continues to bring a smile to my face every KM.
Note From team-BHP Support-Team: Please avoid quoting large/entire posts as it may inconvenience small-screen/mobile users. Thanks.
RockyP is offline   Reply With Quote
Old 9th May 2012, 17:16   #329
n.devdath's Avatar
Thanked: 2,150 Times
Has the 30K service not happened yet? How is the car doing?
Old 9th May 2012, 19:50   #330
.anshuman's Avatar
Around 1100kms away from service. Car is doing great, no issues.
My 2013 Skoda Laura CR 140 DSG Ambition vignesh.cv Test-Drives & Initial Ownership Reports 73 8th July 2018 18:59
DSG packs up on Skoda Laura CR140 - NOW: DSG fails 3RD time manson Long-Term Ownership Reviews 117 27th February 2018 19:34
Skoda Laura, Ambiente 2.0 TDI DSG : Ownership Experience luky_13 Test-Drives & Initial Ownership Reports 82 26th February 2015 16:08
