Old 17th December 2010, 03:11   #16
vigsom's Avatar
Thanked: 515 Times
Default re: Old is Gold - Tale of Two Toyota Corollas - AT and MT
Thank you , guys, for the good wishes.
I have done a fair amount of homework before going ahead and hope I am right.
Got the starter serviced as a preventive;two carbon brushes changed and the bendix was serviced-everything else in the DENSO starter was perfect.
Old 25th December 2010, 15:01   #17
vigsom's Avatar
Thanked: 515 Times
Update 68400km - approx 600km covered
Fuel Efficiency recorded after three fills is 10.5-11kmpl,all in city traffic.
Judge traffic well and this automatic can be driven really really well.
The moment I have to stop at a signal,I put the car in N and pull the hand brake.
Driving now seems a breeze,especially in tight traffic.
Got the alignment done after replacing the left steering boot;400 bucks.
I fail to understand why they charge more for alignment in this car when the job is the same as in say.a Wagon-R viz. toe adjustment.
Premium gaadi=premium alignment fee maybe????
Guys,any idea how much it costs to get a duplicate key made?
Old 28th January 2011, 20:57   #18
vigsom's Avatar
Thanked: 515 Times
Had a minor issue with the ac about 45 days back which seems to have been sorted.
By putting the ac on AUTO with the temp setting even at coldest,the cabin wasn't cooling enough.I suspected that refrigerant must have leaked out,so got the pressure checked.
Suction was 20psi and compressor discharge was 120psi or so ;the suction pressure of 20 gave me some relief as that meant there was no major problem.
Got approx 200g of refrigerant topped up to take the suc pressure to approx 35 and discharge pressure to 130psi levels.
Water needed to be poured on the condenser after the refrigerant top up to get the actual pressure readings.
So far so good - the ac is working very well at a temperature set point of 24.5 degreesC
Old 15th February 2011, 22:08   #19
vigsom's Avatar
Thanked: 515 Times
Originally Posted by Hatari View Post
Congratulations! Love the old Corolla.
Was planning to paint my Disc brake calipers Yellow/Red.
But apprehensive as a bright colour behind the alloy will become dirty quickly and would be diffcult to clean daily.
Do let me know your experiences on this
would strongly recommend painting the calipers silver/bright metal and nothing else-the yellow gathers brake dust and gets dirty real quick.
Here's a pic of what it looks like when clean
Old 16th February 2011, 00:28   #20
camchennai's Avatar
Thanked: 7 Times
What happened to Toyota emblem in the alloys??
How is the suspension now?? Is it stiff??
camchennai is offline   Reply With Quote
Old 16th February 2011, 08:44   #21
vigsom's Avatar
Thanked: 515 Times
Only one emblem was available - and its lugs were all cracked.I have seen scores of Corollas roaming on aftermarket emblems which have worn out.Where do I get a genuine set?and how much?
I can't say much about the suspension as I was hitherto driving a car with one of the worst suspension set ups - the Versa.
But, I'd still say the ride is good probably because of the tyres.
Old 16th February 2011, 09:49   #22
wmanu's Avatar
Congratulations Mate, I would love to see the interiors as well, once the cleaning is complete.
wmanu is offline   Reply With Quote
Old 16th February 2011, 10:58   #23
Spinnerr's Avatar
Thanked: 113 Times
Quick question about the alloys, were they restored? From the pics I can see a factory like finish, like the ones where they have a clear coat or some thin plastic coat. For that nice matt finish.
If yes, how costly is it? and what is the process like? Old alloys, are they just repainted or are they baked as well? Any details that you can share is appreciated.
Spinnerr is online now   Reply With Quote
Old 16th February 2011, 12:57   #24
vigsom's Avatar
Thanked: 515 Times
the process involves just repainting - but it costs a lot - approx 1500 per wheel since it is laborious - my bodyshop friend told me it takes almost as much effort to restore one wheel as it does to get one body panel back in shape.
Here you are - some interior shots -with a 2MP camera.
Old 17th February 2011, 01:25   #25
camchennai's Avatar
Thanked: 7 Times
You can source one from Toyota A.S.S., I am not sure how much it costs though I can check and update you.
I see from the interior pics that you have changes the OE system, bad you haven't updated that. I also see tweeters in dash, why did you place them in the place of stock tweeters? Please tell us about audio upgrade
Old 17th February 2011, 11:31   #26
S_U_N's Avatar
Thanked: 374 Times
@vigsom: Congratulations! The old Corolla is one car that has always fascinated me.
I have a budget of 4.5 lacs (all inclusive). What would be the recommendation for a used Corolla in this price range?
My requirements are:
1. Trouble free ownership - car should not breakdown in the middle of nowhere, and should not require frequent service center trips
2. Should give a mileage of atleast 12 in city with a light foot
3. Should have Airbags and ABS
Sorry if this is appears off-topic.
S_U_N is offline   Reply With Quote
Old 17th February 2011, 11:46   #27
AWD
Thanked: 217 Times
Congrats Vigsom.
Which Double Din ICE system have you installed & is it well/flush fitting?
Also how much did it cost?
AWD is offline   Reply With Quote
Old 18th February 2011, 20:45   #28
vigsom's Avatar
Thanked: 515 Times
I'd strongly recommend a 2006 H2/H5 manual Corolla(the tell-tales of a facelifted Corolla are the multispoke alloys) but that would mean a budget of around 5.5lacs.
For 4.5 you can get a 2005 H1 which would have ABS and airbags but this would have a manual AC and also the wood finish would be missing.
If you're going to restrict driving to the City,then don't bother about ABS - even a 2004 or 2005 would suffice(no ABS) - and that would save you some bucks as well
AWD:The audio is a JVC KW-XC404 which I transplanted from my earlier car -I had to get a fill panel for Rs.1500 to fit it inOld is Gold - Tale of Two Toyota Corollas - AT and MT-imag0340.jpg
and used the fitting brackets from the stock HU - perfect fit.
The pics I posted are bad - will post quality pics when I get my camera back
Old 18th February 2011, 20:57   #29
AWD
Thanked: 217 Times
Thanks. Is the part pictured above fabricated/aftermarket?
If yes, 15oo/- is ok.
Old 18th February 2011, 21:28   #30
vigsom's Avatar
Thanked: 515 Times
I transplanted the equipment from my earlier Versa into the Corolla plus added a new set of components.
This is what it finally is:
  1. Boston Play Smart Sxi606 6.5" components in front - NEW Crossovers neatly tucked away above the kick panels
  2. HU-JVC KW-XC404 Double Din with a D/in fill panel
  3. Kenwood 8401 amp under the co-driver seat -Ch A driving compos and Ch B driving sub
  4. Monster 100 series RCA interconnects
  5. stock Corolla rear speakers off the HU amp
  6. 10" sub in sealed MDF enclosure in the boot
Used a 40A fuse on the main supply wire and OFC for all audio.
Installation was supervised by me and done by my Electrician - total time was 5 hrs
The set up sounds great ; amp gains needed to be adjusted a bit to suit this car.
I set the switch on the crossover to 0dB since the tweeters sounded bright.
I did not install the new tweeters in the stock position as I wasn't interested in disturbing the stock tweeters and wiring (they are still there but are disconnected).
The stock Head Unit and front speakers are cooling their heels at home.
Investing in Gold ETF or physical Gold - Which is better amitk26 Shifting gears 38 19th May 2017 11:48
Toyota Corollas manufactured in 2007-08 recalled S2!!! The Indian Car Scene 12 1st June 2016 13:13
Toyota to recall Corollas produced between January - June 2003 Redline6800 The Indian Car Scene 7 17th August 2013 17:34
Tale of Two City’s ( NHC and ANHC ) and a DDiS (Swift Vdi) Mevtec Test-Drives & Initial Ownership Reports 80 15th October 2010 00:38
