Old 2nd July 2013, 12:06   #961
bluevolt's Avatar
Thanked: 2,246 Times
Default Re: It's Me and My Honda City i-VTEC - It's Us Against the World!
Originally Posted by pyrodrive View Post
What is your average in city traffic these days?
In day to day city traffic, City gives anywhere between 12-14 KMPL.
Originally Posted by Rock 'n' rollz View Post
Planning to upgrade to 195/60-R15 Primacy LCs soon.
Would appreciate your thoughts on this esp warranty issues, if any.
Up sizing tyres will not void your car's warranty AFAIK. You may go ahead with the upgrade.
bluevolt is offline   (1) Thanks Reply With Quote
Old 27th July 2013, 22:04   #962
bluevolt's Avatar
After a drive in heavy rain this afternoon, my dad forgot to turn off the parking lights and I noticed that now only i.e. the lights were on for over 6 hours. I tried starting the car but it is refusing to start and starter is hardly engaging. So that means battery got completely discharged.
What should I do now? Call Honda Road Side Assistance in the morning or any local battery guy to jump start the car?
My car is just over two years old and I hope Honda Road Side Assistance will not charge me for this job as my car is at home only.
Should I make another attempt to start the Venus tomorrow morning before calling RSA? I hope that will not damage the starter?
bluevolt is offline   Reply With Quote
Old 27th July 2013, 22:36   #963
I suggest give it a try in the morning. It happened with me couple of times and battery got some charge back after 2-3 hours on its own. A good quality non honda service centre typically charges Rs 200 for providing jump start service in Delhi
Victor18 is offline   Reply With Quote
Old 27th July 2013, 22:45   #964
sumeethaldankar's Avatar
Thanked: 1,049 Times
I think you should get the battery charged up.My 800's battery had died due to bad alternator.I simply got it recharged.You could then take the car to HASS for a check up.
sumeethaldankar is offline   Reply With Quote
Old 28th July 2013, 10:27   #965
Habanero City's Avatar
Thanked: 51 Times
Do you have extended warranty (2+2 Years) with Honda Road Side Assistance?
In that case you may call RSA.
Otherwise wait until morning and try starting again.
If the car does not start, ask for jump starting with someone known to you living nearby.
Otherwise call the local battery guy to jump start and get the battery charged either by normal running of the car or by bench charger at the battery shop.
How old is the battery and what make is it?
May be it is time to change, keep a watch on this.
Habanero City is offline   Reply With Quote
Old 28th July 2013, 11:50   #966
bluevolt's Avatar
Venus managed to start on its own this morning after a sluggish crank. I kept the engine on for around 5 minutes. No need to call RSA as of now. Will do same in evening to maintain some charge for Monday morning office drive.
It is stock Amaron battery just over two years old.
Old 28th July 2013, 19:38   #967
Thanked: 51 Times
Good to know that the car started without any problems.
Just keep using it as usual and maintain the battery charge.
If possible please check the battery (water levels, connections, charging volt etc.,)
Amaron should last for some more time and not die in 2 years.
Habanero City is offline   (1) Thanks Reply With Quote
Old 30th July 2013, 19:17   #968
srinivaspai's Avatar
Thanked: 22 Times
i would suggest you get the battery bench charged immediately as starting without a fully charged battery will put heavy load on starter motor and you will spend much more to rep[alced it.charging by running the car is not suffecient. a bench charge will not cost you more than 50 to 100 rs .better be safe now than sorry later
srinivaspai is offline   Reply With Quote
Old 31st July 2013, 13:12   #969
Baddychat's Avatar
Thanked: 128 Times
Precisely. Irrespective of Amaron/Exide they should last for 36 months in most cases. The life of the battery though would be directly proportional to the number of cranks in most cases of regular usage.
Baddychat is offline   Reply With Quote
Old 25th August 2013, 14:15   #970
ad3952n's Avatar
Thanked: 1,837 Times
Dear Mate, I too have 2011 MT Honda City, I too thought of upgrading car's tyre until i met a owner of 2009 SMT honda city who upgraded his car's wheels & alloys and was facing issues like dragging, high fuel consumption. I believe OEM wheels are best suited for any car.
AD
ad3952n is offline   Reply With Quote
Old 1st September 2013, 17:06   #971
bluevolt's Avatar
It's time for 20K KMs service. What all things I need to take care of?
Old 16th September 2013, 14:39   #972
tamsaif's Avatar
The headlamp cluster on the right side of my 2012 City S-MT has seen multiple cases of water deposits (usually at the corners) after servicing at the dealer (Pride Honda, Hyd). This was the case for the last one year, however, in the most recent instance in July, water drops covered the entire head light and the attached indicator shells. In the earlier cases water droplets vanished in a few days. Now, after getting it checked at the dealer, found out there was a crack due impact on the headlamp (even though there was no accident). So no chance of replacement under extended warranty, while the spare costs 5.5k. The service advisor tells me he's tried to seal the crack and it may greatly minimize future seepage. Its been three months now and the corners of the lamps still have several drops. Will this compromise the safety of the car? How can I get rid of the water? Appreciate your responses.
tamsaif is offline   (1) Thanks Reply With Quote
Old 8th October 2013, 13:16   #973
Try to blow hot air from a hair dryer, I dont know it may work.
palani1976 is offline   (1) Thanks Reply With Quote
Old 8th October 2013, 23:22   #974
libranof1987's Avatar
Thanked: 3,094 Times
Eventually, the reflective surface of the headlight might start getting corroded.
When SAs say they have temporarily fixed it, it generally means that they didn't do anything. They want you to replace the assembly!
It might be a good idea to visit a FNG; they might have a fix for that. Esp. the guys who clean headlight assemblies.
libranof1987 is offline   (1) Thanks Reply With Quote
Old 10th October 2013, 14:29   #975
bluevolt's Avatar
Noticed this rusting around the washer nozzle today while giving the car for service. Right now I am at svc only and they are saying that this could have caused due to use of hard water in washer tank or accumulation of water near the nozzle. The other nozzle is perfectly ok. No leakage also as told by them, they have refitted the nozzle/pipe.
I am wondering how it happened. I am using tap water in my six year old wagonr but not faced this kind of rusting at all.
How to control this from further damage?
Jeremy Clarkson against the whole world [compilation] rahul_intlad The International Automotive Scene 112 21st December 2015 12:08
Tiff Needell puts his real world skills against David Baker (UK GT4 champ)!!! Shan2nu Shifting gears 5 16th September 2008 21:15
Wanted: Used Honda City 1.5/VTEC and Maruti Baleno sonic Shifting gears 0 27th January 2005 12:34
