Old 27th April 2011, 21:45   #136
Mpower's Avatar
Thanked: 1,687 Times
Default re: Finally a modern hatch: Hyundai i10 Sportz AT
Originally Posted by blackasta View Post
sorry to know about such a problem - maybe this can help:
1998 Honda Civic The Car Shakes when shift from N or P > R D? - Yahoo! Answers
If its an busted engine mount, then every time you hit the accelerator while in motion, you will get the jerk.
Old 29th April 2011, 19:04   #137
Samurai's Avatar
Thanked: 15,769 Times
Until yesterday, every thing that could have gone wrong has been checked. Nothing came out of it.
Today, two fellows from Advait Hyundai Mangalore came to inspect the car, one of them was an auto-transmission expert. They checked every wire, used the scanner to check any possible error, and found nothing. Now they suspect malfunction in the ECM. Since this car has immobilizer, they can't just swap the ECM from another car. Some kind of re-coding has to be done, not sure what that means.
Therefore, tomorrow they will be driving the car from Udupi to Mangalore. At Advait's service center they are somehow going to put a different ECM and see if the AT box acts differently. It is really depressing to see all this happening to a 2 month old car.
My former Santro Xing AT didn't have a single major issue until the 7th year. That too was caused by a torn CV joint boot. And here I am with a two month i10 AT, major problem after just two months.
Did I just get unlucky or is there a general deterioration in Hyundai quality?
Old 29th April 2011, 19:28   #138
Vid6639's Avatar
Thanked: 21,065 Times
Samurai, why do you want them to drive the car to Mangalore. They should arrange for a flat bed truck. If there is any major issue with the transmission driving up may aggravate the issue further.
Hyundai should tow it on a flat bed truck.
Old 29th April 2011, 19:30   #139
supremeBaleno's Avatar
Thanked: 1,709 Times
I would think it is just a one-off instance - especially since we have many i10-AT owners on the forum who haven't seen any such issues.
BTW, just shooting in the dark - but would it help to reset the ECU and see if it helps ?
Old 30th April 2011, 00:53   #140
Samurai's Avatar
All the experts who worked on it so far feel it can be safely driven.
They have been at it for 4 days now. I am sure they would have done that by now.
For now I will let all the Hyundai authorized professionals to work on it without me getting in the way. The vehicle is under warranty and it is their job to fix it. If they can't fix it in another week, then I will have to escalate it to the company.
Old 30th April 2011, 02:44   #141
Furebo's Avatar
Thanked: 54 Times
Sorry to hear about the issues you are facing. Hope the outcome is positive, That said you have very little to worry about (Warranty).
A bit of both if I may add. But I doubt it as a one off for the simplest reason as over time I have seen Hyundai quality deteriorating (Steering rattles etc).
Have you asked them for a Loaner car? If not do so immediately.
Furebo is offline   Reply With Quote
Old 30th April 2011, 09:38   #142
Samurai's Avatar
Don't need a loaner car as of now. But I would need one if this saga doesn't end before my family returns to Bangalore.
Old 30th April 2011, 10:43   #143
Furebo's Avatar
Thanked: 54 Times
Why take a chance? They will have to provide one to you. That being said the loaner may make them solve the issues ASAP.
My 2
Old 1st May 2011, 09:26   #144
Samurai's Avatar
Yesterday i10 was driven to Mangalore by the same AT technician who worked on it previous day.
My 2
My i10 is primarily used in Bangalore. At Manipal it was just parked and not used. If I take the loaner now, it will suffer the same fate. But in 15 days my family has to return to Bangalore, where i10 is our only vehicle. That is where I'll need a loaner, if at all if it comes to that. Let's hope it doesn't come to that.
Old 2nd May 2011, 19:01   #145
Samurai's Avatar
Got an update from Autoland today. Advaith Mangalore is getting a ECM kit by tomorrow afternoon from Bangalore. Apparently this includes the immobilizer too. Then they will replace the ECM and test it.
Ok, I have a question here. In immobilizer equipped cars, the ECM can't be swapped so easily. This is because mismatch will occur between the car key and the ECM. Now if they are changing the ECM, will they replace the key too? Don't they have to replace the entire lock assembly. How does this work?
Old 2nd May 2011, 19:53   #146
MCR
Thanked: 237 Times
The ECM just needs to be reprogrammed with the key code. The key code is normally provided printed on a card during the time of delivery.
MCR is offline   Reply With Quote
Old 3rd May 2011, 12:57   #147
Samurai's Avatar
The culprit has been found!
Today morning I got a call directly from Advaith Hyundai, Mangalore. Once they swapped the ECM, the problem vanished into thin air. It was a faulty ECM after all. How it went bad right after first service is a mystery, but that is not important now. Since the i10 AT ECM is not in stock, they have put in an emergency order with the Factory in Chennai. It should be here within 3-4 days.
I was asked to submit the other key too, since both keys need to be re-programmed.
I asked about that. They didn't want any key code. I was just asked to send my second key.
Old 3rd May 2011, 13:13   #148
anekho's Avatar
Thanked: 661 Times
Good to know the problem has been identified. Just curious, how exactly was the faulty ECM causing that jerk (from the transmission)?
anekho is offline   Reply With Quote
Old 3rd May 2011, 13:18   #149
noopster's Avatar
Thanked: 9,597 Times
Congrats Samurai! Was watching your thread closely and a little anxiously- it would be pitiful if our engineers didn't know how to handle a standard AT. Anyway all's well that ends well. Wishing you many more miles with your beauty!
noopster is offline   Reply With Quote
Old 3rd May 2011, 13:21   #150
Thanked: 57 Times
Good to hear that the problem was identified. Any idea what is the cost of the ECM. I just want to get an idea, if this happens beyond warranty period (hope it never comes to that, I own a Santro AT).
mohan41 is offline   Reply With Quote
Hyundai i10 AT Sportz - Hyundai Stock / Brand Value in the Eyes of a customer ACM Test-Drives & Initial Ownership Reports 16 18th November 2012 13:53
Finally finally finally finally... s4ch Introduce yourself 3 29th March 2012 19:44
i10 Magna (1.2 Kappa) Vs i10 Sportz (1.2 Kappa) MutantX Hatchbacks 52 12th September 2010 00:55
