Go Back   Team-BHP > Indian Cars > What Car? > Luxury, Imports & Niche
Luxury, Imports & Niche Camry, 5 Series, Supra, 911 etc.
Thread Tools
Old 1st November 2009, 21:26   #1 (permalink)
Default Mercedes W203 C220CDI or W211 E200K
Given the options, given the budget, of a choice between the following two vehicles:
(1) 2005 C220CDI 45000Km in what appears to be excellent condition. No known issues.
(2) 2004 E200K 55000Km in "ok" condition. The known issues are: (a) One of the centre AC blower vents seemed partially blocked, which leads me to believe it was manahandled or for some reason the Dash panel was removed. (b) Vibration related to the engine & gear mounts only at idle, which makes me wonder how a petrol engine could have worn out mounts as early as this. So has the odo been tampered with...
Obviously from the above the C is a better buy. However, I am more "fond" of the E (the added space in the rear / status value etc.) and hence have following queries:
(1) Say a year or so down the line, which in your opinion would depriciate more? The E on account of it being a petrol/2004 or the C on account of it being a C?
(2) Also, which would be an easier sell later...I presume the C, however your views would help. Intention being to swap, when affordable, with an E220CDI, E 270CDI or 280CDI.
(3) Have also "heard" the C suspension tends get loose no matter how easy you drive around 50,000Kms. is this true? Personally, its hard to believe as I feel if your drive behaviour is careful your suspension will last.
Thanks in advance.
__________________
Drive Safe !
Mohnish is offline   Reply With Quote
Old 1st November 2009, 22:07   #2 (permalink)
S350L-E240's Avatar
2004 E200K I assume is before the facelift? My answer = Avoid!
2005 C220CDI is the facelifted car I guess, so get that. MB sorted a lot of problems in the C and E after their facelifts and believe me you dont want to get close to any of these cars before their midlife facelift.
About the depreciation etc, I honestly don't know much but considering your description about the E, it already has issues so I'm pretty sure years down the line when you do try to upgrade those issues may haunt you?
And about the selling easy part? Both!
And about the suspension on the C, I don't know much I never owned the previous gen C so no comments but I'm sure GTO or someone else who owned the car will answer you better.
P.S If you dont mind me asking what is the budged? have you considered the BMW 320i when they were launched? those cars should go for a good deal, and reliable as a platinum ring!
__________________
You drive what you can...
S350L-E240 is offline   Reply With Quote
Old 1st November 2009, 22:16   #3 (permalink)
speedy's Avatar
The Ac problem does come in the cars after 38,000kms if it is done they are back to original. It is just cleanup rquired and people neglect it due to the cost. I had the same on my E at 39,000kms. The vibrations are due to the gear mounts that need to be replaced. They do get affected due to our kind of roads. I have had mine replaced too. The odo has not been tampered but i am guessing due to the cost involved the owner has decided to sell the car and let the buyer deal with it.
The E would dpriciate more than the C. Primarily cause it is a Petrol and secondly it is a 200.
The E to E swap would be better as you are already used to the size of the car. Both cars a few years down the line would be at a difference of a Lakh of rupees. It really makes no difference as you would be loosing money on both.
The C does have suspension issues regardless of it being driven hard or easy. his was a company fault and has nothing to do with the Driver. I think GTO would be a better person to answer that as he has a C220 cdi.
If it is not a bother to disclose the price of the E200k as a friend of mine has a 05 E200k done 47,000kms and wants to change it. The car is one owner black with black and always chauffer driven. Thank you
__________________
lots to learn so little time
speedy is offline   Reply With Quote
Old 2nd November 2009, 12:26   #4 (permalink)
canonball's Avatar
Stay away from E200, I have been advised by MB insider to stay away from any C as after 65k the music starts! All sorts of issues related to suspension and mechanicals typically come up with any C (pre/post facelift). Diesel E's are better bets and hold on to their values slightly better than C's. So if you bump up your budget a little you will get E220 CDI's (04 onwards).
Do share prices you are being offered cars at. thx
canonball is offline   Reply With Quote
Old 2nd November 2009, 14:25   #5 (permalink)
Originally Posted by Mohnish View Post
Given the options
Between the two, I'd go for the C220. Way more power + torque, a newer car, lower mileage and seems to be in better condition.
The E200K is very underwhelming to drive. That 1.8 super-charged engine does alright in the city, but on an open road / highway, its the worst one could ask for Link to comparo between the two (Short drive with the C220 and the E200K). The previous E Class' interiors were smaller than that of the W210; fact is, the space really isn't all that much more than the C.
Plus, when its time to sell, diesel Benz' move quicker.
I drive my car VERY hard and the suspension never really went "loose". However, I did need to overhaul the front at about 50,000 kms. Expenses that you should expect:
- The C & the E, both, need new evaporators every 2 - 3 years.
- The C220 will need new engine mounts at 50K. Rs. 7,000 at an independent, Rs. 30,000 at authorised.
Budget for a total of 50 - 75K each year in maintenance (after-market pricing of course) and you are all set.
__________________
Work backward from your imagination, not forward from the past!
  • Please don't PM for support. Use the Contact Form instead.
  • Please read the *NEW* Team-BHP FAQ section for all your queries.
Old 2nd November 2009, 14:32   #6 (permalink)
Sahil's Avatar
Pardon my lack of knowledge but what are the symptoms felt that lead to replacement of engine mounting?
__________________
______________
__________
______
__
Old 2nd November 2009, 14:33   #7 (permalink)
I had picked up a 2005 C220 in Jan with 32k on the odo. I have hardly driven the car and its only done 4k in 10 months. I had to change the front shocks, left engine mounting, brake pads and even after changing the shocks the right suspension is still making some noise. After talking to a few people they told me that if you do not drive the car much the shocks are bound to get spoilt, is this true?
Angad_kalra is offline   Reply With Quote
Old 2nd November 2009, 15:35   #8 (permalink)
canonball's Avatar
Sahil some level of driveline and general viberation that can be felt in the cabin whilts idling, accessive during gear change or whilst engaginging drive/reverse. If this is not happening then early telltale signs are radom viberation coming whilst driving or more than normal viberation felt in steering wheel whilst driving. Hope this helps
Old 2nd November 2009, 16:24   #9 (permalink)
Sahil's Avatar
What about engine shut-down shuddering/shake? Is that a sign of engine mount wearing out?
__________________
______________
__________
______
__
Old 2nd November 2009, 19:03   #10 (permalink)
Smile Got the C220CDI
Thanks a ton for all the replies...
I got the 2005 facelift C220CDI...(44K on the odo, full service history, single owner etc etc)..."looks" and "drives" very very clean, but let see what the stars foretell!!!
Swapped it with my 98 E250D (about 75K on the odo, 3rd owner) + 7L on top.
@GTO : Your thread (E200K vs C220CDI) and experience regards the C220CDI was pretty much a clincher for me, considering I have no experience of the Cs.
Obviously, considering I am new to this variant I will post a few queries as I stumble across them in a seperate and appropriate thread.
Have always been in an E since about 20 years now, from the 123s, 124s to the W210s (non CDI as well as CDI). Will post my thoughts on a comparison between the W210s and the W203 in a few days after the dust settles.
btw: did also try a 07 320 BMW. Found the suspension setup too hard for our roads. Not my kind of drive.
Thanks again.
__________________
Drive Safe !
Old 2nd November 2009, 21:09   #11 (permalink)
canonball's Avatar
Hi Mohnish I am on the look out for a W210 E250 Auto, was yours the same? What color was it?
Old 2nd November 2009, 21:11   #12 (permalink)
canonball's Avatar
If the shutdown viberation/shudder is high (read more than normal) yes the mounts need to be changed
Old 2nd November 2009, 22:18   #13 (permalink)
Have responded to your pm on above query.
__________________
Drive Safe !
Old 2nd November 2009, 22:27   #14 (permalink)
Default W203 C220CDI user queries.
As some of you already are aware, I have recently aquired a 2005 W203 C220CDI and its a helluva drive!!!! Absolutely love it, but thats another thread.
This thread is for you'll to help me get aquainted as thought he PO has the entire documentation right form original invoice upto service history etc. he has "misplaced" the owner's manual!!! just my luck!!!
Ok so here are my newbie queries :
Query No. (1): There is this Auto button on the AC console. I have a rough idea as to what it does but require a detialed clarification and instructions as to how / when it is to be used. Photo below for your easy identification, howver the Team BHP logo has covered part of it. Its the centre button.
Query No. (2): There is an AC vent controller like rotary dial in a longitudanal orientatinon the flat centre part of the dash below the perforated speaker lke fitting. What does that do?
Thanks in advance...I am sure there will be more questions form my end, so please bear with me!!!
@mods: If I've goofed on the correct forum for this post kindly redirect...my apologies.
__________________
Drive Safe !
Old 3rd November 2009, 21:32   #15 (permalink)
redeff's Avatar
Congrats on your new ride!!
I'm sure our inhouse C220 CDI expert GTO will be be able guide you best . Look through his ownership thread. It is a treasure trove!
__________________
'Vorsprung durch Technik' - Love it.
redeff is online now   Reply With Quote
Thread Tools
A Gamble that Paid off: C-Class Mercedes W203 aatish Super-Cars & Imports in India 45 16th November 2009 14:34
Want To Buy Mercedes W211 E Class E220 Cdi Budget About 15 To 18 Lakhs. rah1735 Luxury, Imports & Niche 9 13th March 2009 14:36
Short drive with the C220 and the E200K GTO The Indian Car Scene 21 1st August 2006 13:53
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607
