Go Back   Team-BHP > BHP India > What Car? > Luxury, Imports & Niche
Old 29th December 2010, 23:42   #46
PlatzdaTurbo's Avatar
Thanked: 315 Times
Default Re: Vorsprung durch technik or Sheer driving pleasure?
Originally Posted by fre2bpowerless View Post
Its optional like everything else on the CBUs. (B&O, drive select, keyless go, ventilated seats, 18" wheels etc.)
what all have you opted for ? you got the 18 inchers and the ventilated seats ?
PlatzdaTurbo is offline   Reply With Quote
Old 30th December 2010, 00:17   #47
fre2bpowerless's Avatar
Thanked: 81 Times
I got all of these + the 3 spoke steering with paddle shift.
fre2bpowerless is offline   Reply With Quote
Old 2nd June 2011, 18:47   #48
__c_y_p_h_e_r__'s Avatar
Hey Chaps,
My front left tyre has developed a prominent bulge. Is this dangerous? Do I need to get his changed?
If so, any idea as to how much the standard tyres cost? They are Pirelli P7 225/50 R17's.
__c_y_p_h_e_r__ is offline   Reply With Quote
Old 2nd June 2011, 20:49   #49
Akshay1234's Avatar
Thanked: 7,239 Times
Originally Posted by __c_y_p_h_e_r__ View Post
Hey Chaps,
Yes you certainly should get it changed. Pirellis in that size would be around 14k or so. You might be able to get Yokohamas a bit cheaper.
Old 2nd June 2011, 22:47   #50
I spoke to the folks at Audi and they are asking for a whopping 42K for a tyre!
I checked out a few tyre dealers in Bangalore as well and they are quoting between 17-18K. Is this a reasonable rate?
About going in for a different brand, I have this OCD about having everything match
Also, should I not drive the car at all till I get the tyre changed?
Old 2nd June 2011, 23:21   #51
Thanked: 4,140 Times
check these must be covered under Insurance . I had bulge in my 20 inch rear low profiles and drove more than 10 T Km before getting these replaced last week when the bump actually gave away . Insurance paid about 50 % as tread was about 1/2 .
check Michelin pilot Sports - in chandigarh i was getting 18 inches for about 18 thousand
http://www.michelin.in/tyre/pattern/PassengerCar
Turbanator is offline   Reply With Quote
Old 2nd June 2011, 23:27   #52
aah78's Avatar
Thanked: 1,748 Times
Arrow Re: Vorsprung durch technik or Sheer driving pleasure?
Don't mix and match brands. If you change to a different brand or even a different model within the same brand you're better off doing a 4 tyre change.
With a bulging tyre, you risk a blowout. Get it changed as soon as you can.
It gets worse as you drive so avoid driving around long distances.
And especially don't drive fast, or you risk a blowout at high-speed.
Here's a picture of a tyre that has a bulge on the outside:
And this is what it looks like on the inside (notice the tear):
aah78 is online now   Reply With Quote
Old 2nd June 2011, 23:35   #53
Akshay1234's Avatar
Ok so if Pirellis are available then go get those. Yes it is best to have everything match, I would do that myself too. One suggestion is that if you buy the tyre then put the spare tyre (assuming you have one of the same size) along with the new tyre on the front wheels. Then you will have 2 new tyres.
Akshay1234 is offline   (1) Thanks Reply With Quote
Old 2nd June 2011, 23:55   #54
- www.michelin.in
I'll check with the insurance folks tomorrow; hopefully its covered.
Attachment 554285
Attachment 554284
I just got back from a long trip and noticed this when I was getting the car washed. Another trip was on the cards but now that aint gonna happen till the tyre gets replaced.
Do these cuts happen because of manufacturing defects or because of our lovely roads?
Unfortunately, the A4 comes with a space saver.
Old 3rd June 2011, 01:29   #55
aah78's Avatar
If it's a fairly new tire then it's probably a manufacturing defect.
Potholed roads do damage tires but from my experience, not as much when new.
If your rim has damage too, then road damage it is
Check this article -> Tire Rack -Sidewall Separations/Bubbles
BMW 320d- Sheer Driving Pleasure indeed Nitronium Test-Drives & Initial Ownership Reports 117 31st October 2017 16:35
Audi A4 : Vorsprung durch Technik. An Eight Year Saga redeff Long-Term Ownership Reviews 20 8th July 2017 19:29
"Vorsprung Durch Technik" - Audi A4 3.0 TDI PlatzdaTurbo Test-Drives & Initial Ownership Reports 279 5th May 2015 10:37
Vorsprung Durch Technik - How this term was born AlphaKilo The International Automotive Scene 0 19th September 2012 23:57
Sheer Driving Pleasure @ Malshej Ghats quattroa4 Travelogues 9 29th August 2012 02:36
