Old 4th July 2011, 19:23   #16
Thanked: 1,059 Times
Default Re: Modifying a Honda Jazz
Originally Posted by adimicra View Post
Step 2- Tuned exhaust. I am not sure about free flows, they give lots of sound which does not necessarily translate into more power
Not sure of your other queries but the tuned exhaust can be made to sound exactly as per your requirements. I have one on my Spark and its a delight every time i start the car. My main requirement was to have a FFE which was not disturbing and loud. The tuners did an amazing job with it.
abhinav.s is offline   Reply With Quote
Old 18th May 2012, 15:24   #17
9thsphinx's Avatar
Thanked: 468 Times
Thanks for bumping me up to this thread @ Selfdrive. I am based out of Ahmedabad and everyone unanimously suggested to take my queries to Neighborhood motors (Mr Tandon). I guess I will be doing that soon. The Jazz by itself has a wonderful silent engine, and gets you the power you need in the upper rev bands. On the flip side, the low end torque literally sucks. My priority is simple. Increase the low-end torque. I really don't need anything else. GTO mentioned a 5 - 7% increase with stage 1 mods. On the road, what does that translate to?
9thsphinx is offline   (1) Thanks Reply With Quote
Old 23rd May 2012, 23:27   #18
Quite often with Honda engines people tend to forget that they develop maximum torque pretty high up the band. So drive enthusiastically, and use the excellent gear shift!
Sorry for asking a very basic question of you. I am new to car-lingo. and googling doesn't yield anything conclusive. Wanted to ask you how is one expected to rev a new Honda engine to overcome the lack of pull at low speeds (what, I think, petrolheads here call lack of low-end torque?). So, when you say 'drive enthusiastically' and use the gear-shift, what am I supposed to be doing?
How does one rev a car? By pressing the clutch and then going after the accelerator?
I am a new driver with a brand new Honda Jazz. Our first servicing is still some time to go so should I try and 'rev' the car rightaway or wait for the run-in to end?
esskay08 is offline   Reply With Quote
Old 7th June 2012, 17:07   #19
9thsphinx's Avatar
Thanked: 468 Times
I am going in for a CAI as the first step of modification. Cant decide between an Injen CAI and Cosworth CAI. The price difference is huge. I have put up the question on my ownership thread too, but I guess I would get better answers on this one. What do you guys think I should do? Installation in both cases will be done locally in Ahmedabad.
Old 7th June 2012, 17:17   #20
selfdrive's Avatar
Thanked: 2,498 Times
look at the rpms. Try to keep them steadily high. No high revving or sudden accelerating for the first x kms. What is x? I dont remember, just check your manual or ask your service advisor.
I would stay clear of ripping the car in the first 1K kms at least
whats the price difference?
selfdrive is offline   Reply With Quote
Old 7th June 2012, 17:37   #21
Sn1p3r's Avatar
Thanked: 230 Times
A new car is just isn't a new engine but a lot if complex systems to gel together. Keep the rev in limit as mentioned in your manual.
Never ride the clutch and accelerator should always be used once clutch action is complete else you will be changing the clutch more often. Normal car engines don't like to rev higher in the range but yours does so what our friend meant by revving high was to keep the torque range handsome and handy. You will have a feeling of it soon as you get acquainted with the character of the engine. Enjoy!
for a new car the RPM should not be steady for a longtime. Keeping it at different range helps the engine bed in better.
Most Honda guys hooked on this thread. Pranav, GTO are experienced campaigners with Honda engines.
To what I know Jazz has 1.5L engine in other countries (the engine in City), and these engines are tuned for mileage in India. Thus nothing much can be done except a complete remap with all the Stage kits that go with it. I am hooked to see your progress.
Cheers!
Sn1p3r is offline   Reply With Quote
Old 7th June 2012, 18:06   #22
srishiva's Avatar
Thanked: 933 Times
You need to shift down to lower gears and that will automatically increased your revs for a given speed. So you need to change gears frequently and it should be a joy on an Honda
srishiva is offline   Reply With Quote
Old 7th June 2012, 23:35   #23
Thanked: 27 Times
Will driving at higher revs result in a lower FE? Should I be upshifting at the earliest opportunity for a higher FE?
qaqa is offline   Reply With Quote
Old 8th June 2012, 08:29   #24
Thanked: 65 Times
Hello,
Has anyone done the remapping and modifications of their Jazz as suggested by fellow bhpians in Kochi? If so , please tell me the end result, the cost and where you got it done. Thanks.
Rameshdude is offline   Reply With Quote
Old 8th June 2012, 11:11   #25
srishiva's Avatar
Thanked: 933 Times
Low rpms will yield better FE but then you need to be in the right gear so that you don't lug the engine.
Revving a smaller engine a bit doesn't consume more fuel than a bigger engine, you need to be at the rpm that is efficient for the engine.
If your car has the eco light or the right gear indicator, just follow that.
Old 9th June 2012, 10:29   #26
Originally Posted by Sn1p3r View Post
...accelerator should always be used once clutch action is complete else you will be changing the clutch more often. Normal car engines don't like to rev higher in the range but yours does so what our friend meant by revving high was to keep the torque range handsome and handy. You will have a feeling of it soon as you get acquainted with the character of the engine...for a new car the RPM should not be steady for a longtime. Keeping it at different range helps the engine bed in better.
Thanks to all the three of you Yes, now that I have driven the car around a few times, I am beginning to get what revving is all about. Though, it is a couple of hundred kms shy of covering a 1000km, we have inadvertently punished it a few times. With two drivers in learning mode, there have been times, even if for a few seconds, when the revs have touched the 3000 rpm mark. Hope that the iVtec does not mind as enthusiasts like you believe.
Surprisingly, the manual that came with the Jazz does not have detailed info on rev-speed matches or anything of that sort :(
Old 9th June 2012, 13:06   #27
Sn1p3r's Avatar
Thanked: 230 Times
It's all about sharing, enjoy the ride. It is good that you have pushed the engine a bit. 3000 is nothing, the car will soon present you to rev it up to 6000 mark. The engine sound post vtec kicks in changes so you will know when you are in the territory.
Honda insist that engines have been tested and then plugged in the cars, no issues with revving it at various rpms. The first 1000km zone is for making sure every other component of the car is also ready.
Enjoy!
Sn1p3r is offline   (2) Thanks Reply With Quote
Old 11th June 2012, 11:35   #28
selfdrive's Avatar
Though I am not sure if the Fit manual has these details, I would recommend you to search TBHP for the 'Fit manual' pdf. I do have a copy somewhere on my old laptop, but it will take me some time to locate it and put it up here. Mught be quicker for you to look it up here or elsewhere online.
selfdrive is offline   (1) Thanks Reply With Quote
Old 12th June 2012, 10:49   #29
3000 is nothing, the car will soon present you to rev it up to 6000 mark. The engine sound post vtec kicks in changes so you will know when you are in the territory.Enjoy!
The older Fit manual (2006) with most probably the 1.2 litre engine, says:-
1st to 2nd - 24 km/h
2nd to 3rd - 43 km/h
3rd to 4th - 62 km/h
4th to 5th - 85 km/h
While driving to office today, I tried to keep these in mind (I didn't cross 60 kmph) and drove, and no where did the rpms cross 2k.
However, our driver, who supervises our driving for now, kept getting impatient whenever I was driving a li'l above 20 in the second gear. I even drove in the 4th gear when a li'l below 60 kmph.
Now, I know one can't be too bookish and his experience is years ahead of ours, but for Indian roads and Honda 1.2 engines what are the realistic gear-shift ratios?
Earlier, I used to get an engine sound and automatically used to think that the car was 'racing' (what the driver calls racing is probably revving that is harmful?). That would make me upshift quickly. But today when I was trying to match it according to the chart above, I found that I still got the sound without any drastic increase in rpm or speed. But yes, the driver insisted that I upshift.
Which style should I follow? Because if not changed now, this will become a habit and the way I drive...
Thanks very much
Old 12th June 2012, 13:44   #30
selfdrive's Avatar
I am sorry I cannot help much here; I am too moody a driver to rely on for speeds at gearshift.
Most of the times I am a sedate driver, so I would be matching the numbers given in the Fit manual. A majority of these too I shift a bit early, so I am in top gear around 60.
What I do ensure is optimal gear changes; it does help in mileage.
On the odd day that my doppelganger takes over me, all gearshifts are totally irrelevant to vehicle speed and done more out of the Vtec roar. Needless to say mileage goes for a toss but then mileage doesnt always bring a smile
Disclaimer: my Jazz has done 35k + kms.
Honda slashes price on Jazz as well ? EDIT: Launch pics of new Jazz Pg.56 swiftnfurious The Indian Car Scene 1441 17th September 2011 15:03
Got Jazz'd! - Tafeta White Honda Jazz JRD Test-Drives & Initial Ownership Reports 32 25th November 2010 17:14
Honda to raise car prices, and Jazz launch soon. EDIT : Jazz spotted testing on pg.14 GeekSrik The Indian Car Scene 463 9th March 2010 11:17
HONDA JAZZ Specs : Sometimes, we have to pay to be (jazz)y in our country sidindica The Indian Car Scene 507 10th June 2009 15:32
