Old 30th March 2012, 16:45   #121
naveen.raju's Avatar
Thanked: 3,725 Times
Default Re: Philips India launches Daytime running lamps & an In-cabin Air purification syste
Originally Posted by abhimanyu_singh View Post
Would installing a DRL void my Honda warranty?
If the wires are cut then it will be a problem. DRL's are direct fitment that requires no cutting of the wires. Just make sure that they do it properly.
naveen.raju is offline   Reply With Quote
Old 30th March 2012, 17:03   #122
abhimanyu_singh's Avatar
Thanked: 102 Times
Sounds fair, but in such case how do they link it to ignition or the parking light switch?
abhimanyu_singh is offline   Reply With Quote
Old 30th March 2012, 22:56   #123
Both will work. I was given the option to connect it to the ignition for opted for the parking light switch. Moreover, the installer will know all latest kits are plug n play devices and the stock wires need not be cut.
Old 2nd May 2012, 22:11   #124
fiat_tarun's Avatar
Thanked: 640 Times
Got the Telefunken DRLs installed on my Zen today. Went for wipers and boy were these tempting.
Well, money spent on the car is always justified, isn't it..
Got these for 3600 with fitting. Have connected them to the parking lights.
Philips India launches Daytime running lamps & an In-cabin Air purification system-20120502_205329_253.jpg
Philips India launches Daytime running lamps & an In-cabin Air purification system-sam_0466.jpg
Philips India launches Daytime running lamps & an In-cabin Air purification system-sam_0455.jpg
fiat_tarun is online now   (1) Thanks Reply With Quote
Old 17th May 2012, 12:26   #125
motomaverick's Avatar
Thanked: 868 Times
Planning for a DRL on the Manza, problem is there is an OEM fog lamp (not that i mind). I was planning on the L-shaped design to complement the front looks somewhat, so need a vote on which of the drls will look good as per the mock up photo below.
Any ideas about the current offline market price? I was quoted about 3.5k for some unknown brand, thatís daylight robbery.
Old 17th May 2012, 12:44   #126
.anshuman's Avatar
Thanked: 9,159 Times
You are using the DRL for the exactly opposite purpose they are meant for. DRL should automatically switch off the moment headlamps are turned on.
.anshuman is offline   (1) Thanks Reply With Quote
Old 17th May 2012, 13:22   #127
fiat_tarun's Avatar
Thanked: 640 Times
Correct Anshuman. I didn't want them on all the time, so decided to connect them to my parking lights. These lights if connected as per diagram, will dim when the parking lights are switched on and not switch off.
fiat_tarun is online now   Reply With Quote
Old 18th May 2012, 13:14   #128
Thanked: 868 Times
Yesterday went on search of the drls Sachins Autoshop as well as Glamour cars and relaized that offline the drls are priced quite high, something that is avaialble for 1k bucks in ebay the same is being sold for 2k.
Anyone knows a shop where the prices might be decent.
Old 16th July 2012, 14:29   #129
cityvic's Avatar
Thanked: 2,613 Times
Recently got the DRL's fitted on my Honda City type 2.
Got them from S&S.
I have got them connected to a switch from which they can be switched ON/OFF whenever I want instead of connecting it to the ignition and it getting switched off whenever the headlights are switched on.
Philips India launches Daytime running lamps & an In-cabin Air purification system-dsc_1012.jpgPhilips India launches Daytime running lamps & an In-cabin Air purification system-dsc_1034.jpgPhilips India launches Daytime running lamps & an In-cabin Air purification system-img2012071000543.jpgPhilips India launches Daytime running lamps & an In-cabin Air purification system-img2012071100547.jpgPhilips India launches Daytime running lamps & an In-cabin Air purification system-img2012071200548.jpgPhilips India launches Daytime running lamps & an In-cabin Air purification system-img2012071200549.jpg
Philips LED4 on a friends Corolla Altis Diesel.
cityvic is offline   (1) Thanks Reply With Quote
Old 16th July 2012, 14:39   #130
carfreak77's Avatar
Thanked: 129 Times
Does anybody know whether the DRLs void the warranty on the car? I am thinking of getting them fitted (LED4).
Is there any cutting of wires required?
carfreak77 is offline   (1) Thanks Reply With Quote
Old 16th July 2012, 14:46   #131
Thanked: 56 Times
Got them from S&S.
Looks neat! Did you also change your HL bulbs to something other than stock? They're looking nice and whie too!
Vandit is offline   Reply With Quote
Old 16th July 2012, 15:53   #132
Vid6639's Avatar
Thanked: 21,048 Times
Got them from S&S.
I did not understand this? If what you have are original Philips DRL then you don't need a switch and no wiring to ignition and all.
The philips DRL's are connected directly to the battery with no other connection. The DRL's work on vibration sensors since DRL's are meant to be always on.
When you start the car the DRL's switch on due to the engine vibrations and will turn off when the car is parked and ignition is off.
That's why they will never void any warranty since the connection is directly to battery with no OEM wire splicing or cutting.
Vid6639 is offline   (3) Thanks Reply With Quote
Old 16th July 2012, 16:00   #133
cityvic's Avatar
Yes,I have installed Philips Crystal Vision.
Yes they are 100% Genuine stuff.
There is no Splicing and cutting of wires involved in my install.The mechanic installed them by connecting them to the battery and then providing me a switch to switch it on and off whenever I want.
But the car will have to be switched on first to switch on these drl's.They cant be switched on when the car is off.
Is there anything important I should get checked surely?Plus my car is 9.5 years old.Warranty is long gone.
Old 16th July 2012, 16:06   #134
Vid6639's Avatar
Warranty part I was replying to carfreak77. :-)
My question was that you don't need a switch at all since they are vibration based. Maybe in your case he did not use the vibration circuit at all and used the switch instead?
Old 16th July 2012, 16:35   #135
cityvic's Avatar
Thanks Vid.Just checked.There is vibration circuit installed in my car.Should I get rid of the switch and get it installed that way?
cityvic is offline   Reply With Quote
The DRL Thread: Everything about daytime running lights zenren Technical Stuff 133 28th June 2018 18:01
How do you dispose of CFL lamps & Fluorescent lamps? Klub Class Shifting gears 13 19th April 2017 16:57
Projector Lamps(Low Beam) as Fog Lamps for Ritz LDI alexpaul Modifications & Accessories 17 13th September 2012 20:23
The Air Car - Cars Running On Compressed air ? santhoshx The International Automotive Scene 30 15th December 2009 15:26
