Old 3rd August 2012, 11:44   #271
Thanked: 30 Times
Infractions: 0/2 (10)
Default Re: Advice on CNG Conversion
Originally Posted by vijay_rodie View Post
Finally made my mind and converted to CNG.
I have installed BRC - closed loop kit with TAP & Lamda. I did it from one of installer from Dange Chowk, Chinchwad (Welcome to Mirajkar CNG GAS fitting Center to Cars, Repair and Maintenance of four wheelers). With RTO registration it costs 32,000.
Its been 1 and half month and I have covered 2000 km, so far no any issue except the 'check engine' light goes on/off.
Very happy to see monthly saving of 5000 rs. (Expected to cover the kit cost within 6 month )
I met Mr. Mirajkar as one of option while opting for CNG for my Spark. However opted for a service provider nearby house considering service requirements. No issues with installation. it was a closed loop lovato.
Today, already cleared of my spark. i didnt have any problem as such, and gone ahead with WagonR CNG. I must say "there is difference in retrofitted and company fitted kits". One should opt for company fitting provided option is executable. I have tasted both world so word of advice.
So where do you fill CNG?
How about few pictures of installation? with lamda and other parts? This will help.
Cylinder Capacity?
idea is offline   Reply With Quote
Old 3rd August 2012, 12:03   #272
vijay_rodie's Avatar
Cylinder Capacity?
Yes you are right. One should consider the installer location. Mr. Mirajkar's is just 6-7 km away from my house.
Cylinder is of 14kg capacity but with several refills, maximum I got was 9.9 kg. I usually fill CNG at Pimple Petrol Pump, Chinchwad. This is online pump and bit fast service compared to others.
I will update the pics soon .. !!!
vijay_rodie is offline   Reply With Quote
Old 3rd August 2012, 12:23   #273
Bass&Trouble's Avatar
Thanked: 71 Times
I'm very curious to know where you fill CNG, and how much time it takes you every time at the gas station.
Old 3rd August 2012, 14:08   #274
I fill CNG at Pimple Petrol Pump, Chinchwad. I usually go in off-peak time like, between 3 to 5 pm or on Sunday's between 12.30 to 2.30 pm.
As per usage one tankful of CNG lasts for 4-5 days to 1 week.
Old 3rd August 2012, 14:36   #275
infotech58's Avatar
Thanked: 217 Times
Originally Posted by pranav4x4 View Post
Thanks man... will check for the port - where does one find an OBD scanner? Also, any chance you could put me in touch with your friend having the converted City? Would be reassuring to talk to someone who has one for a significant period.
location of OBD port on your City is:
http://www.team-bhp.com/forum/techni...ml#post1354408 (OBD (On-board diagnostics) for Indian Cars)
check for a scanner on ebay or buy from US; i bought mine (basic one) from US for 35$.
the friend who had CNGed his City has sold it 8-9 months ago and bought a diesel. if i remember correctly, CNG conversion was done by Rachit Dhawan who deals in lovato kits (i had posted his contact details somewhere on the forum, do a search).
infotech58 is online now   Reply With Quote
Old 3rd August 2012, 14:59   #276
Thanked: 30 Times
Totally depends. At what time and which place you are visiting
I have used facilities in thane and i must say services are way faster than pune.
In pune i spend avg 20 min per fill per week.
I do use that pump in case i am in that area. 9.9 KG is good, am sure you get this when tank is totally or nearly empty.
Will wait for pics.
Old 3rd August 2012, 17:42   #277
CARDEEP's Avatar
Thanked: 1,500 Times
Default Re: Swift CNG Help!
Originally Posted by HimuraKenshin View Post
when warmed up, the engine idles at around 800 RPM
Hi
How do you rate the performance of your car on CNG as compared to petrol? How pronounced is the power loss, or I fear there won't be much?
I feel this could point out to something.
CARDEEP is offline   Reply With Quote
Old 3rd August 2012, 19:18   #278
Thanked: 21 Times
Thanks for updating. Mirajkar is my first choice coz when ever i go to his brothers bike garage i used to see atlest 2 cars for fitment and he clarified all the kit details and rto queries also asked to see a fktment of old honda city.
I havent converted to cng till now. But sooner it will be done.
His brother is also really good with bikes. He solved my honda avaitor morning kick start problem. 2 yrs on kick problem didnt occured.
shabahmad is offline   (1) Thanks Reply With Quote
Old 3rd August 2012, 19:23   #279
Will wait for pics.
Yes, you are right. I go for refill only when tank is totally empty or nearly empty. Usually after reserve (red) light flashes on the gas indicator.
Definitely upload the pics over the weekend.
Old 3rd August 2012, 19:25   #280
Thanked: 21 Times
shabahmad is offline   Reply With Quote
Old 3rd August 2012, 20:28   #281
HimuraKenshin's Avatar
Thanked: 183 Times
Originally Posted by CARDEEP
Hi
Hi, I feel a minimal loss in acceleration when m on cng. No other performance issues...
HimuraKenshin is offline   Reply With Quote
Old 4th August 2012, 09:28   #282
rajeshchand's Avatar
Thanked: 75 Times
Not to be overly pessimistic, but i had two vehicles which was run on LPG (not domestic, factory kit), my experience is that the fuel is economical, good and clean energy but it is to be used only in city driving, never use it for highway driving (read higher speeds for longer duration) and hill driving (load factor on the engine), the engine head gives away within a lakh kilometer or so, i have a vehicle which is asking for engine head change and this is the second time it is happening on a different brand vehicle. I am not sure about the reasons for this, but then one needs to see the cost factor vis-a-vis petrol / diesel, when you run a vehicle on LPG / CNG for almost one lakh km you definitely save quite a lot of money, even much more than what the engine head change would require.
rajeshchand is offline   Reply With Quote
Old 4th August 2012, 09:52   #283
Thanked: 183 Times
hey!
My driving is in the city only! highway driving is for a total of 1/2 hour everyday only. I have another car that i use for so called, 'heavy driving' (Jetta)
Old 4th August 2012, 11:58   #284
CARDEEP's Avatar
I guess your CNG settings need to be tweaked (they call it tuning), your CNG flow is higher than required due to which you aren't experiencing much power loss, which is perceptible generally.
You will observe major loss, say- 15-20%, in the power (basically low end torque), but your mileage will improve, & it would require extracting best from engine before every gear shift. Probably, you won't love your car after this, but, the cost savings will hold you back IMO.
I believe this should help.
Old 5th August 2012, 09:06   #285
giri1.8's Avatar
Thanked: 256 Times
Hi guys,I am planning to install LPG kit for my optra 1.8(CNG is not available in chennai,correct me if I am wrong).I am getting mileage of ~10kmpl right now which means the running cost in about 7.2Rs/km.How much will I be able to save if I install LPG kit
p.s: I am not obsessed with mileage but I just want to reduce money spent on fuel when I go for long rides
giri1.8 is offline   Reply With Quote
What's your stopping factor on a LPG/CNG conversion Surprise Modifications & Accessories 58 2nd July 2010 21:39
CNG conversion for the Optra? Is it wise? beanstalk_230 The Indian Car Scene 10 28th October 2007 20:17
Lancer - CNG conversion... Kinda urgent, Thanks yuv Modifications & Accessories 9 22nd July 2007 13:34
CNG conversion Exo Modifications & Accessories 1 29th May 2006 17:47
