Old 24th May 2006, 14:30   #31
Thanked: 440 Times
Originally Posted by panky12345
any inputs on deisel --> CNG conversion. Ok it doesnt affect much in MPFI petrol but wass up for deisel?
Converting a diesel into CNG is a lot more complicated and I don't think is worth the effort. It does not make any economic sense also. In Delhi, the entire bus fleet was converted to CNG not for any economic reason but because of the Supreme Court order which could not be disobeyed. As it is, diesel is some 33% cheaper than petrol and on top of it, the diesel engine is inherently more efficient than petrol by about 33%. So, compared to a petrol engine, you are already 66% better off. (Guys, pardon my arithmatic if it's wrong!)
directinjection is offline   Reply With Quote
Old 24th May 2006, 15:22   #32
Hi zappo
Yeah the fuel economy increased. LPG tuning should be taken seriously. I see lots of people who just use it as a cost saving factor. Infact with proper tuning u can get best results. As LPg does not heat ur engine much in stalled traffics u can get good ac output in carb cars. In my case i have changed the electricals of the car. Put in different relays for fogs, horns and Ac. And that surely helps. With petrol my gypsy in city gives me a average of about 10-11 though i cannot be pretty sure about it. LPG tends to give u low average in initial stages as u get used to gearing with it , improvements are seen. Also visit a LPG expert every 3 monts to check gas flow pressure if u constantly switch between petrol and LPG. I will put up another thread oh the exact costs of reoing my Gypsy with LPG A?C and change of electricals if someone can guide me under which forukm i have to post
lodhra is offline   Reply With Quote
Old 25th May 2006, 00:25   #33
gr8guzzler's Avatar
Thanked: 38 Times
I recently got my Ikon converted and gearing while on gas is a bit different. i was thinking the tuning was not right or something. My engine revvs a bit more when I press the clutch to change gears and the same does not happen when I'm running purely on petrol. Is this what you were referring to?
Also since you are in Mumbai, can you let me know where you got your kit tuned, I would like to get the same done too.
Finally...you can start a new thread under Modifications if you want to provide more details...
Cheers!!!
gr8guzzler is offline   Reply With Quote
Old 25th May 2006, 14:25   #34
Hi gr8
I was given the opinion that the car does not knock in LPG hence maybe u are experiencing the rev up situation. Initially i too got the same problem. I think its just our perception of the car since we have been driving so long with petrol , LPG mode suddenly takes us by surprise. But surely as you experiment it becomes much easier. I did my car at Suman auto LPg which is at link road goregaon. He has his website too http://cng-lpg-conversion.com/
Thank you for the advice will soon post the thread.
lodhra is offline   (1) Thanks Reply With Quote
Old 19th August 2006, 01:33   #35
Guys pls tell......
Lets say i got my car converted to LPG/CNG, either of them. Now imagine my gas is over while running and due to some reason i am not able to fill it. Then i run on petrol. BEcause the tuning is done to suit the LPG or CNG kit will i get VERY poor FE if i drive on petrol. SAy before conversion FE with petrol is 10/Lt. Will it go down drastically if run on petrol after getting the either Kit installed ?
jdutt is offline   Reply With Quote
Old 19th August 2006, 22:30   #36
wolfinstein's Avatar
@ Jdutt, The engine tuning and engine settings remain the same...! The setting for CNG or LPG are done at the Reducer end or the section where the pipes are connecting into the throttle..! My XETA runs same..! Petrol or CNG. The FE is same 11 Kmpl on Petrol and 16-17 on CNG..!
wolfinstein is offline   Reply With Quote
Old 20th August 2006, 21:15   #37
Default Thx
That solves one of my worries..........Wolf, do you seen ANY ANY ANY drop in engine response and power (Used 3 times any to be very specific) when u drive with CNG and whats your top speed with CNG ?
How does Xeta behaves with switching ON a/c while running on gas ? Any sluggish experianced....
Old 20th August 2006, 23:00   #38
All right intial drop in lower gears yes...! I cruise on 80 with AC on 5th..! During traffic times I need to shift into lower gears for a stop and go pickup, however while moving shift into a 3 is sufficient to pick on...! Top speed I clocked with CNG mode and with AC was 100 km...on Noida-Fortis road...! You can get the exact details from my review..!
AC ke saath no performance change in 3/4/5 Gear considering you are above 50 Km..! However if you're in lower speeds Car feels heavier..!
Old 20th August 2006, 23:57   #39
Default Hmm
Not boasting about anything........my TOP speed with petrol 155 Kmph at Noida toll road.
By the way where i can see your review ?
Regards.
Old 21st August 2006, 15:19   #40
esteem_lover's Avatar
Thanked: 447 Times
so i guess, if the driver is 34% more efficient, then the diesel car would be 100% better off than the petrol one , eh ? its not arithmetic, it is fantasticmetic.
Old 21st August 2006, 16:43   #41
ess_a's Avatar
You are actually 50% better off in this scenario!! not 66%....
Ok now i also have a question.... Is CNG good for an Alto.... It is already underpowered especially when the A/C is on.... Do u guys think there wont be a significant loss of power.... secondly what cylinder size should i be fitting if at all i go for CNG???
ess_a is offline   Reply With Quote
Old 9th September 2006, 14:38   #42
ess_a's Avatar
One thing more... Cant euro III cars be retrofitted with CNG kits? The delhi transport authority's site says only cars upto euro II norms can go for the conversion...
Plus does any one know of a good cng intaller in delhi and what kit to go for.... Landi renzo doesnt have kits for euro III cars.... Only Bendini does... Is this true?
Old 9th September 2006, 19:34   #43
Don't you know how Goverment Sites work..! Lol
Well it depends on which Euro 3 Car Kits have been approved as of now- TATA, HM,GM Kits are approved...Waise it really does not matter..You can get a new car converted...just that older cars cannot ..Lets say Current Bharat Stage 3,2,1...Legally not prior to that..!
Ya Bedini is Euro 3 ready, You could visit www.iglonline.com and find approved fitters.
Old 19th September 2006, 17:55   #44
ess_a's Avatar
Checked with Shrimankar in Okhla... The guy said till now the bedini kit they have is not for alto euroIII... He also added that right now the govt has put on hold cng conversions and some new norms are expected to come by 21-22 sept... Now how come if cng kits are available for other euro III cars like xeta and city, they are not for alto? And any review on IMPCO, BRC kits....?
Old 19th September 2006, 18:56   #45
spoke with them again, regarding this New Norm and Was advised that it is expected but can't say when..Since the Kits have to be approved by CRI and ARAI ( Or whatever the Transport Authority of India ( Not RTO) is called) that is why the kits for Alto and Palio is yet awaited, However you can go for a older fittment, the only difference with the Euro 3 kit will be an Advanced Lamda Sensor,which you can ask to be installed later when the kits come up.
What's your stopping factor on a LPG/CNG conversion Surprise Modifications & Accessories 58 2nd July 2010 21:39
CNG conversion for the Optra? Is it wise? beanstalk_230 The Indian Car Scene 10 28th October 2007 20:17
Lancer - CNG conversion... Kinda urgent, Thanks yuv Modifications & Accessories 9 22nd July 2007 13:34
CNG conversion Exo Modifications & Accessories 1 29th May 2006 17:47
