Old 26th February 2015, 12:05   #526
ghodlur's Avatar
Thanked: 1,822 Times
Question Re: Advice on CNG Conversion
Originally Posted by HimuraKenshin View Post
All engines can be converted to CNG.
I would request you to not say things like
This is complete rubbish.
It just depends completely on the installation.
I appreciate your views. I had visited the best installer in my place who was RTO approved and day in day out used to install the latest technology CNG kits. But most of his customers were Suzuki, Hyundai or Honda owners. And Ford customers was a rarity. The CNG installation on the Ford Ikons were a big failure with many post installation issues (read significant drop in engine performance/reduced mileage). It was the installer himself who distanced from installing one on a Ford car citing the very issues which had been faced with earlier CNG converted Ford cars. How many CNG converted Ford cars owners have put their ownership thread on the forum? And are happy with it?
ghodlur is offline   Reply With Quote
Old 26th February 2015, 20:23   #527
ptaneja's Avatar
Thanked: 226 Times
Default Re: Advice on CNG Conversion
Originally Posted by usatya View Post
Any body converted Fiesta 2011-14 petrol 1500 cc automatic car to cng.I want to convert mine which has just done 8500km only since 2012. many including converters told,not to bother converting unless the drive is high.mine is 8000km/year max. pl advice
With just 8K running, doesn't make a sense installing it. You'll probably end up selling the car before the investment of kit pays off.
ptaneja is offline   Reply With Quote
Old 4th March 2015, 22:18   #528
HimuraKenshin's Avatar
Thanked: 179 Times
Just because he is certified by the RTO does not mean that he is knowledgeable. Getting a piece of paper is not that difficult in India.
All i want to tell you in that i've seen v6 chevys, v6 dodges on CNG and also seen a Jaguar running on LPG. It is very much possible to convert a ford to CNG. Its just the type of kit and installation that needs to be done properly.
HimuraKenshin is offline   Reply With Quote
Old 27th March 2015, 20:18   #529
Recently, I enquired about CNG fitment in my 2008 sx4.
One of the dealers quoted 30k for lovato lambda conventional kit and told sequential kit is not supported for this model.
Another dealer quoted 42k for Tomasetto sequential kit. Both prices are exclusive of RTO charges.
Are these prices appropriate?
Which one should I go for?
Any good CNG fitters in Delhi someone might know of?
arjunbagga7 is offline   Reply With Quote
Old 30th March 2015, 16:27   #530
Thanked: 179 Times
Go in for the sequential kit.
Make sure it is installed from a reputed installer.
the SX4 has a drive by wire throttle, a venturi based kit is a strict no no.
Old 30th March 2015, 17:07   #531
amitpunjani's Avatar
Thanked: 93 Times
The best and most experienced, from my personal experience is AA CNG. He is in GT Karnal road. Prices a bit on the higher side, but won't take you for a ride.
amitpunjani is offline   Reply With Quote
Old 30th March 2015, 22:26   #532
@himurakenshin thanks for your advice.
@amitpunjani interestingly, the price that i am telling for the conventional kit was quoted by AA cng. A car dealer and a trusted mechanic both referred me to the same person, and now a referral from someone on tbhp, I feel I won't need to worry their expertise now. Thanks for your advice
Old 31st March 2015, 23:09   #533
Thanked: 93 Times
I installed Cng in Santro from AA, extremely satisfied with his work. Owner name is Amit Aggarwal, you can quote my name, also Amit to him, he might offer some discount. Infact he has installed the kit in his own sx4, ask for a trail, surely he won't deny.
Old 1st April 2015, 00:19   #534
Now, I would surely quote him your name. And, if he agrees to the trial of his car, all my doubts against cng would be solved, I believe.
By the way, how much did it cost you to fit the cng in your santro. Which company, type is it?
Old 1st April 2015, 00:47   #535
akshaymahajan's Avatar
Thanked: 56 Times
I have a CNG Santro which suddenly stopped running on CNg yesterday evening. Runs well on Petrol
Took the car to one CNG guy and he said something on the lines of: The reducer is running very cold. We will need to route a pipe from the radiator around it to warm it up.
This sounded weird so went for a second opinion. The second guy said that the stepper motor isnt functioning properly and thus changed it to a manual value. The car is running now but I am not convinced. The mechanic said its the same thing but easier to tune.
Did we not just cut off the feedback loop that regulates gas flow?
Replies will be appreciated.
akshaymahajan is online now   Reply With Quote
Old 1st April 2015, 09:55   #536
Thanked: 93 Times
I did the installation in 2009, touch wood no problems at all because of CNG kit. The kit was BRC.
Old 1st April 2015, 14:44   #537
Thanked: 179 Times
Yes, what the mechanic essentially did was cut the feedback loop. You now have an open loop system, instead of the previous closed loop.
Most CNG kits used outside of india have the coolant flowing through the reducer to increase the temperature.
When a highly pressurized gas is released through a small orifice it causes sudden drop in temperature. Since the ambient temperature in India is relatively high, usually they do not run the coolant through the reducer.
If you car is running fine on open loop, you can keep it this way. Else try swapping out the stepper motor and check if it was really the stepper motor at fault.
It is very strange for the reducer to suddenly start freezing up in our temperature, if this happens, it is probably time for you to service the reducer, which would involve replacing all springs and diaphragms.
Do post some detailed pictures for the engine bay, ill try to guide you.
HimuraKenshin is offline   (1) Thanks Reply With Quote
Old 15th May 2015, 20:23   #538
Max
Thanked: 85 Times
Saw an totaled CNG Car, glad to see no damage to CNG cylinder. Looks like CNG is safe during crash accident. What are your thoughts?
Max is offline   (1) Thanks Reply With Quote
Old 15th May 2015, 21:15   #539
kisharchit's Avatar
Thanked: 330 Times
Would a sequential CNG kit work on the Accord AT (2009-2010 onwards) 2.4 engine? How big of a tank am I looking at and theoretical range per tank?
kisharchit is offline   Reply With Quote
Old 15th May 2015, 23:15   #540
Thanked: 179 Times
Attachment 1371014
The CNG Cylinder is the safest part of the car and the most structurally sound. No authorised or approved CNG cylinder would burst even if you set off a stick of dynamite under it.
Yes, it would work very well. Hondas are quite easy to convert. You can put a 19 Litre tank..This tank can store up to 14-15 Kgs of CNG if im not mistaken
You will get upto 40% of an increase of your petrol mileage on each KG of gas.
HimuraKenshin is offline   (2) Thanks Reply With Quote
What's your stopping factor on a LPG/CNG conversion Surprise Modifications & Accessories 58 2nd July 2010 21:39
CNG conversion for the Optra? Is it wise? beanstalk_230 The Indian Car Scene 10 28th October 2007 20:17
Lancer - CNG conversion... Kinda urgent, Thanks yuv Modifications & Accessories 9 22nd July 2007 13:34
CNG conversion Exo Modifications & Accessories 1 29th May 2006 17:47
