Old 10th June 2011, 09:28   #16
swiftboost's Avatar
Thanked: 43 Times
Default The original PDF files sent from Quartermile magazine May 2011
Posted below are the original PDF files of the article in Quartermile May 2011
swiftboost is offline   Reply With Quote
Old 10th June 2011, 10:39   #17
Ricky_63's Avatar
Thanked: 394 Times
Thumbs up Re: My Turbo Baleno featured in the Quartermile plus magazine in the May 2011 issue
Very nice build, the best part being that you were hands on - literally. What brake pads are you running ? Upgraded or stock ? You have 12 psi on stock internals, is that not a tad over the safe limit ?
Nice car - congratulations on the build !!
Old 10th June 2011, 11:24   #18
swiftboost's Avatar
Thanked: 43 Times
Default Re: My Turbo Baleno featured in the Quartermile plus magazine in the May 2011 issue
@ Ricky_63 - Thanks.
Brake pads are stock - Ive been looking for better ones for some time now.
I have tried the setup at 10 -12 psi a few times. But presently its wastegated at 8psi for added safety.
Old 10th June 2011, 12:16   #19
brraj's Avatar
Thanked: 354 Times
congrats on the turbo baleno. What is the quartermile figures?
brraj is offline   Reply With Quote
Old 10th June 2011, 13:13   #20
Fordmanchau's Avatar
Thanked: 302 Times
Congrats Joe on featuring in the Quarterm ile magazine.
Your Baleno looks clean and is indeed a sleeper. I liked the alloys too.
What's the upside on the performance that you have achieved in BHP and torque ?
Also any performance Air filters ?
For a basic low cost mod, what all can be done at the least and can you give a estimate of the cost for the same ?
Fordmanchau is offline   Reply With Quote
Old 10th June 2011, 15:23   #21
swiftboost's Avatar
Thanked: 43 Times
@ brraj - Thanks. I have not timed it as yet. Besides, its not that quick/powerful - but its a fun daily driver turbo setup without compromising on reliability.
@ Fordmanchau - Thanks. I have not dyno'ed it, so I dont have the BHP & torque figures.
I have retain the stock air filter box and use the stock air filter for the daily drive setup but change to a performance air filter (modified to fit in the stock box) when I plan to push it a bit more.
Old 10th June 2011, 17:27   #22
kutlee's Avatar
Thanked: 202 Times
Hey, what's your boosted FE average. I am not talking very spirited driving. I am running emanage and getting low FE. I don't mind since my usage is ultra low. Thinking whether RD901 or Hondata on P28 will give slightly more FE. When i checked the AFR, it get rich only after 4k rpm and taking it above 4k is rare.
kutlee is offline   Reply With Quote
Old 10th June 2011, 19:48   #23
swiftboost's Avatar
Thanked: 43 Times
@ Kutlee - The car has been giving me reasonably good FE. About 16-17 kmpl on out station drives and about 11-12 kmpl otherwise.
I prefer to tune it slightly on the leaner side for low rpm/part throttle and cruising and marginally on the richer side on the on-set of boost and a still richer later with higher boost.
Emanage blue is quite capable for a piggyback. Im sure you can get the desired performance/FE by tweaking the maps, tuning it further.
Im using the RD 901 ECU and its quite a capable hardware. But if you are using anything else other than a Piggyback - it may take a bit longer to get it to a desirable state of tune since you need to build the Fuel and ignition map cell by cell in most cases. Unless the setup has auto-tune or similar feature that can run Target AFR/ closed loop.
I have not used Hondata personally. But, I have seen it on many rides and Im of the opinion that options like Hondata or other similar setup that can run chrome, Neptune, ECtune etc can almost give you the advantages of both Piggyback and standalone. Besides, you may also find tons of info and usable maps thats often found on the internet.
Maybe you should try tweaking the maps in your emanage blue. you never know !!
Old 10th June 2011, 22:07   #24
Ricky_63's Avatar
Thanked: 394 Times
Thanks for the reply. I am running stock but new brake pads, which hold up well unless one is in the high 3 digit territory. Was thinking of going for Mintex from RRP that should be safer with one off high speed highway runs.
My car returns not more than 10 kmpl in city runs. I am using a Haltech ECU, I think your FE figures are great considering Baleno being bigger than Swift
Old 11th June 2011, 07:11   #25
swiftboost's Avatar
Thanked: 43 Times
@ Ricky_63 - I have heard that Mintex are better than what we get as OEM. Also heard that green stuff is supposed to be good.
Haltech is one of the better ECUs available in the market. Its likely that they have tuned it on the safe side (richer AFR) to ensure reliability and long term safety. Besides, Tuning usually take a bit longer for achieving fuel economy and stock like idle and part throttle response as compared to tuning for out right performance at WOT/ high RPM.
Maybe you could get the ECU remapped - at least in the low boost/ part throttle range to deliver better FE.
Old 12th June 2011, 00:37   #26
m4ugr8's Avatar
Thanked: 123 Times
Congrats Joe, the article was an absolute joy to read. I like the rims and the complete stock look.
m4ugr8 is offline   Reply With Quote
Old 12th June 2011, 11:31   #27
swiftboost's Avatar
Thanked: 43 Times
@ m4ugr8 - Thanks. Yeah, I like the simple clean look.
Team Bhp featured on Auto Car Special Project Magazine vishnu.csk The Indian Car Scene 9 1st December 2011 19:16
Video footage: Opel Corsa vs Ferrari Modena quartermile. Guess who won? sAP Modifications & Accessories 26 24th June 2011 15:37
Deccan Quartermile Drag - January 17 & 18th 2009 DKG Indian Motorsport 413 21st February 2010 15:59
Deccan Quartermile Drag II- June 20th and 21st 2009 suren181 Indian Motorsport 161 21st September 2009 13:17
